    new update/upgrade script, ready for testing
    328 Posts 27 Posters 729.5k Views 24 Watching
      @sdetweil said in new update/upgrade script, ready for testing:
      cool… did u have extra modules also ?
      Meaning other than the defaults? I have nearly all of my modules installed, as well as my favorites from other devs. Did something happen to them? hahah
        sdetweil @Mykle1
        @Mykle1 no. Just checking on how it was handled.
        Could u email me the Upgrade log
          Where is it saved to? I can’t seem to find it in Home or the MagicMirror dir
            sdetweil @Mykle1
            @Mykle1 in the installers folder… (where the install script is and where the upgrade and pm2 scripts should go
            dang it… u mean you didn’t READ the message the script put out about where the log is? lol…
              uhhhh . . . real men don’t read messages. ;-)
              Sent the file to your gmail
                bhepler Module Developer @sdetweil
                @sdetweil - Hmm. Curious. Test run of the script looked good. Added the apply keyword and I’m getting a git error.
                any *-lock.json files do not need to be saved
                do you want to save these files for later   (Y/n)?n
                fatal: Unable to create '/home/pi/MagicMirror/.git/index.lock': File exists.
                Another git process seems to be running in this repository, e.g.
                an editor opened by 'git commit'. Please make sure all processes
                are terminated then try again. If it still fails, a git process
                may have crashed in this repository earlier:
                remove the file manually to continue.
                there were merge errors
                you should examine and resolve them
                using the command git log --oneline --decorate
                a31546b (HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
                Then a bunch of commit statements. There is no git process running at the moment, but that index.lock file does exist. After deleting that file, it worked like a charm. Thanks!
                  sdetweil @bhepler
                  @bhepler said in new update/upgrade script, ready for testing:
                  to git that means it is already running… on exit it cleans up…
                  should I add handling this error to the script?
                  I can tell if its there and git is not running.
                  great feedback… thanks
                    sdetweil @bhepler
                    @bhepler i added handling for the git lock file…
                    if git is NOT running, I erase the dangling lock file
                    if git IS running, and this is an APPLY run, i change the run back to test mode, and advise to correct the problem
                      I just did another run of your upgrade script, Sam. All went well.
                      MM 2.8.0 --> 2.9.0
                      Ubuntu 16.04.6 (downgraded from 18.04)
                        sdetweil @Mykle1
                        @Mykle1 on the 1st run, no modules were updated… there should have been a message in the log… i didn’t see it… did u see any this time??
                          Sorry, I was distracted here, Sam. I just emailed you the upgrade.log
                            sdetweil @Mykle1
                            @Mykle1 thanks… they(last night and today) actually look good
                            i did make one change, the merge results generated one LONE line… i added some formatting to make it readable
                              sdetweil @Mykle1
                              @Mykle1 well, there is installed modules, and there is active modules…
                              i only update the ACTIVE (ie, not disabled: true) modules with package.json files
                                Understood. :thumbsup:
                                  bobwilliams
                                  for some reason, it updates me to version 2.8.0, although it seems like version 2.9.0 has already been released.
                                  MagicMirror installation successful!
                                  magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                                  cd fonts && npm install
                                    sdetweil @bobwilliams
                                    @bobwilliams can you show me the MagicMirror/installers/upgrade.log
                                    or send it to me mail, same userid as here on gmail, thanks
                                      bobwilliams
                                      Upgrade started - Sun Oct 6 11:26:51 +05 2019
                                      user requested to apply changes
                                      doing test run = false
                                      saving custom.css
                                      remote name = origin
                                      upgrading from version 2.8.0 to 2.9.0
                                      fetching latest revisions
                                      current branch = master
                                      there are 7 local files that are different than the master repo
                                      installers/mm.sh
                                      modules/default/calendar/calendar.js
                                      modules/default/currentweather/currentweather.js
                                      modules/default/weather/weather.js
                                      modules/default/weatherforecast/weatherforecast.js
                                      package-lock.json
                                      run-start.sh
                                      save/restore files selection = y
                                      test merge result rc=‘’ if empty, no conflicts
                                      executing merge, apply specified
                                      merge result rc= 0n Updating a31546b…500147e
                                      updating MagicMirror runtime, please wait
                                      magicmirror@2.8.0 install /home/pi/MagicMirror
                                      cd vendor && npm install
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                                      audited 220 packages in 53.517s
                                      found 5 vulnerabilities (4 low, 1 high)
                                      run npm audit fix to fix them, or npm audit for details
                                      magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                                      sh installers/postinstall/postinstall.sh && npm run install-fonts
                                      ^[[32mMagicMirror installation successful!
                                      audited 1 package in 3.78s
                                      found 0 vulnerabilities
                                      npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                                      audited 3573 packages in 310.648s
                                      found 16 vulnerabilities (1 moderate, 15 high)
                                      processing dependency changes for active modules with package.json files
                                      processing for module MMM-WeeklySchedule please wait
                                      audited 1 package in 3.297s
                                      processing complete for module MMM-WeeklySchedule
                                      processing for module MMM-MyPrayerTimes please wait
                                      audited 3 packages in 4.211s
                                      processing complete for module MMM-MyPrayerTimes
                                      restoring custom.css
                                      we stashed a set of files that appear changed from the latest repo versions. you should review them
                                        This post is deleted!
                                          @bobwilliams do a git pull, and show the results…
                                          looks like git lied on the return code of the merge…
                                          lets try the output of this
                                          git merge-tree `git merge-base master HEAD` HEAD master
                                          thanks
                                            bobwilliams
                                            no change … I’m a simple user so don’t judge strictly
                                            • 6
                                            • 16
                                            • 17
                                            • 4 / 17
