    Blank mm after update
    48 Posts 4 Posters 25.6k Views 4 Watching
    • K
      kvicksson
      After updated to 2.8.0 I have trouble with a blank screen. I comment out every module one at a time and found out that mmm-weatherchart was the problem. Is there something wrong in my code?
      		module: 'mmm-weatherchart',
      		position: 'bottom_left',
      			country: 'Sweden',
      			area: 'Halland',
      			city: 'Stråvalla',
      			updateInterval: '3600000',
      			hideBorder: 'true'
      • evroomE
        evroom
        @kvicksson said in Blank mm after update:
        It should be Holland :-)
        No, just joking, try:
        			country: 'Sweden',
        			area: 'Halland',
        			city: 'Stråvalla',
        			updateInterval: 3600000,
        			hideBorder: true
        And this should be part of your tool-set:
        cd ~/MagicMirror; npm run config:check
        MagicMirror version: 2.37.0
        • lavolp3L
          lavolp3 Module Developer @evroom
          @evroom well with the config:check he would not have found the error, would he? It’s a pure semantic check, not a logic one.
          Isn’t there some Troubleshooting guide around to reference to everytime these questions come up?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          evroomE 1 Reply Last reply Reply Quote 0
          • K
            kvicksson
            Just to be clear, I’m a girl… ;)
            The module worked as a charm before the update. So you think I should just skip the apostrophe on the updateInterval and hideBorder?
              sdetweil @kvicksson
              @kvicksson ok… before the update it worked…
              does the module contain a package.json file?
              if so you must also run npm install in the module folder as the version of electron changed in 2.8.0
              in the future, i hope my update script will help solve these problems…
              see
              https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                sdetweil @kvicksson
                @kvicksson the rules are text needs quotes (’ or " matching)
                numbers and true/false should NOT have quotes… as they become strings and not numeric or logical values
                if variable == true will fail with quoted values…
                • evroomE
                  evroom @lavolp3
                  @lavolp3 said in Blank mm after update:
                  In this case perhaps not, but it cannot hurt to run it in order to exclude error(s) before and after this part of the config.
                  Normally a 'true' versus true would not cause a black screen, but I might be wrong.
                  And a trouble shooting guide would have to start with the config:checkIMHO.
                    sdetweil @evroom
                    @evroom said in Blank mm after update:
                    Normally a ‘true’ versus true would not cause a black screen
                    u don’t know how the module code might fail…
                    which is what causes the blackscreen to begin with
                    • evroomE
                      evroom
                      @sdetweil said in Blank mm after update:
                      Tried the module myself.
                      https://github.com/paphko/mmm-weatherchart
                      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 100
                      0|mm       | Starting MagicMirror ...
                      0|mm       |
                      0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
                      0|mm       | > sh run-start.sh
                      0|mm       |
                      0|mm       | Starting MagicMirror: v2.8.0
                      0|mm       | Loading config ...
                      0|mm       | Loading module helpers ...
                      0|mm       | No helper found for module: alert.
                      0|mm       | Initializing new module helper ...
                      0|mm       | Module helper loaded: updatenotification
                      0|mm       | Whoops! There was an uncaught exception...
                      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      0|mm  | Launching application.
                      Indeed a black screen.
                      Now how to help the girl from Stråvalla ?
                        sdetweil @evroom
                        0|mm | Initializing new module helper …
                        0|mm | Loading module helpers …
                        0|mm | Whoops! There was an uncaught exception…
                        seems odd that there would be two invocations of these modules…
                        but as a test, in MagicMirror/config/config.js add
                            disabled: true,
                        to both those modules, and restart mm and see what happens
                          sdetweil
                          missing a required node package ‘del’
                          no package.json to inform the user
                            sdetweil
                            warning, warning… copy and save
                            MagicMirror/modules/node_modules/node_helper (folder, which contains index.js)
                            then
                            cd ~/MagicMirror/modules/mmm-weatherchart
                            npm install del
                            check for a missing
                            MagicMirror/modules/node_modules/node_helper folder
                            and if so, copy it back
                            i opened an issue with mmm-weatherchart
                            • evroomE
                              evroom
                              I have only one mmm-weatherchart module present.
                              When disabled everything is fine.
                              However, I forgot to remove the single quotes, as I just copy/pasted the config from the thread.
                              Corrected it, but now I get even stronger things.
                              0|mm  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
                              I do not have any string with ‘del’ in my config :worried_face:
                                sdetweil @evroom
                                @evroom see my prior most about the missing module
                                • evroomE
                                  evroom
                                  I was typing while you answered.
                                  Will have a look at it and try it out.
                                  • evroomE
                                    evroom
                                    The module is running now, but I get this error:
                                    0|mm  | Downloading weather map with signal: FETCH_MAP From URL: www.yr.no/place/Germany/Bavaria/Nuremberg/meteogram.png
                                    0|mm  | Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1567097174409.png'
                                    pi@raspberrypi:~/MagicMirror/modules/mmm-weatherchart $ ll /home/pi/MagicMirror/modules/mmm-weatherchart/cache
                                    total 12
                                    4 drwxr-xr-x 2 pi pi 4096 Aug 29 18:49 .
                                    4 drwxr-xr-x 4 pi pi 4096 Aug 29 18:44 ..
                                    4 -rw-r--r-- 1 pi pi    6 Aug 29 18:44 .gitignore
                                    Then I read somewhere there is a clone of this module that is more recent, so I tried that:
                                    https://github.com/szech/mmm-weatherchart
                                    Same result: module runs but no file in the cache dir.
                                    When opening the URL in the browser, it does show the picture that I do not see on my screen.
                                    Oh boy/girl, thought it was a simple syntax thingy in config.js …
                                      sdetweil
                                      the module doesn’t work, but doesn’t kill MagicMirror anymore…
                                      • evroomE
                                        evroom
                                        Correct.
                                        I have a few questions.
                                        In the original module there is no package.json file, where in the cloned one there is.
                                        So, when using the original module, you should NOT use npm install, right ?
                                        First of all it will no do anything useful, but it WILL delete your /home/pi/MagicMirror/modules/node_modules/node_helperdirectory and its index.js file.
                                        When using the cloned module, you should run npm installin order to install the dependencies mentioned in it, right ?
                                        No harm is done to the node_helper dir.
                                        Or is it all BS I am telling here (and made the wrong observations) ??
                                          sdetweil @evroom
                                          @evroom i cloned and got no package.json
                                          i cloned this
                                            sdetweil @evroom
                                            @evroom yes, to all your observations…
                                            • 1 / 3
