    My first project
    12 Posts 6 Posters 9.7k Views 6 Watching
    • CynicC Offline
      Cynic
      Hi guys!
      I am making my first mirror. Now I am in the process of experimenting on the location of the modules. Experimenting on a 19-inch monitor. I want to make an information panel on a small display from a 15-inch laptop. This panel will display the weather information I need, a list of tasks, and my activity.
      I used the modules:
      Default clock
      ToDoist
      Strava
      WallberryTheme
      darksky forecast
      I am not a wizard. I am just learning.
        sdetweil @Cynic
        @Cynic cool… nice work!
        • CynicC Offline
          Cynic
          Thank you friend! I need experienced advice. This project is a bulletin board. Can I use glass and black film?
          S Mykle1M 2 Replies Last reply Reply Quote 0
            sdetweil @Cynic
            @Cynic i do not know… i am using large TVs, where the mirror glass is very expensive, so have not done it yet
            • buzzkcB Offline
              buzzkc
              Looks nice. I’m not using any glass either, just a wood frame around the monitor screen.
              Darren
              My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
                Mykle1 Project Sponsor Module Developer @Cynic
                @Cynic said in My first project:
                My opinion
                If it’s a bulletin board then why use glass at all? Many people have made use of MM without a mirror. Film of any kind is difficult to deal with, at best. If you search the forum you will find an overwhelming majority of people who attempted film were disappointed with the final outcome.
                Good luck, mate.
                • CynicC Offline
                  Cynic
                  Hello to all! I keep building. Thanks for the tips on glass. I will try to do without it. But with dark film, the image is more contrasting. I will experiment.
                    mielu80
                    @Cynic
                    Hi Cynic,
                    Nice build,keep up the good work.
                    For my mirror I used normal glass and Oracal MIR 500 film and the results are satisfying.
                    Of course you can not compare the result with a two way mirror but just keep in mind the price,also not comparable.
                    Good luck!
                    CynicC 1 Reply Last reply Reply Quote 0
                    • CynicC Offline
                      Cynic @mielu80
                      @mielu80
                      Hello! Thanks for the advice. I plan a black film of 20% clearance. This will give a contrasty image and hide damage to the old monitor. I continue to build.
                      • buzzkcB Offline
                        buzzkc
                        That looks nice!
                        Darren
