    3rd Party Modules with APIs not loading.
    32 Posts 3 Posters 12.5k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @bflbarlow
      @bflbarlow
      Going out for a smoke. I’ll be back in 10.
        bflbarlow
        That URL worked great on the browser.
        I really appreciate the help troubleshooting.
          @bflbarlow
          No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using npm start dev and see if it reports receiving the data from the api. It should look something like this
          >Array (60)
            bflbarlow
            No errors a few minutes in.
              @bflbarlow said in 3rd Party Modules with APIs not loading.:
              Sucks! You should see it right away. I’m stumped. I can’t reproduce this behavior with my module. You CAN get data, based on the url test. But, for you, the module is not getting the data. Thus, it’s not loading.
              I don’t think this is a module issue. I’ll ask my friend on the forum to look into this for you. He is amazing at troubleshooting MM and modules. I’m sure he will take a look at this. I’m sorry I couldn’t figure this out for you.
                bflbarlow @Mykle1
                Sounds good and no worries.
                Thanks for giving it a shot!
                Mykle1M 2 Replies Last reply Reply Quote 0
                  @bflbarlow
                  You’re welcome. I’m sure it will get worked out when the right people take a look at it.
                  Peace.
                    @bflbarlow
                    I’ve sent you a private message
                      sdetweil
                      edit the ~/MagicMirror/modules/MMM-MyStandings/node_helper.js
                      replace the getData function with this
                      	getData: function (notification, url) {
                      		var self = this;
                      		console.log('requesting:' + url);
                      		request({ url: url, method: 'GET' }, function (error, response, body) {
                      			if (!error && response.statusCode == 200) {
                      				var result = JSON.parse(body);
                      				console.log("have data from api size="+body.length);
                      				self.sendSocketNotification(notification, result);
                      			} else {
                      				console.log("MMM-MyStandings : Could not load data."+" error="+error+" status="+response.statusCode);
                      open a terminal window
                      stop mirror , pm2 stop 0
                      then start manually
                      npm start dev
                      you should see
                      MMM-MyStandings helper started ...
                      Launching application.
                      Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                      [14416:1017/204410.405574:ERROR:CONSOLE(2564)] "The given range isn't in document.", source: chrome-devtools://devtools/bundled/shell.js (2564)
                      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                      requesting:http://site.web.api.espn.com/apis/v2/sports/basketball/nba/standings?level=3&sort=gamesbehind:asc,winpercent:desc
                      have data from api size=126499
                      or something
                      please advise
                        @bflbarlow did u see my message above?
                          bflbarlow
                          I did.
                          Sorry, I haven’t had the time to pick up troubleshooting.
                          Will hope to sometime this weekend.
                            sdetweil @bflbarlow
                            @bflbarlow cool. thanks for the feedback… i just noticed that I hadn’t tagged you…
                            no rush
