3rd Party Modules with APIs not loading.
32 Posts 3 Posters 9.3k Views 3 Watching
    Mykle1 Project Sponsor Module Developer @bflbarlow
    @bflbarlow
    Going out for a smoke. I’ll be back in 10.
      bflbarlow
      That URL worked great on the browser.
      I really appreciate the help troubleshooting.
      M 1 Reply Last reply Oct 18, 2019, 1:11 AM Reply Quote 0
        @bflbarlow
        No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using npm start dev and see if it reports receiving the data from the api. It should look something like this
        >Array (60)
          bflbarlow
          No errors a few minutes in.
            @bflbarlow said in 3rd Party Modules with APIs not loading.:
            Sucks! You should see it right away. I’m stumped. I can’t reproduce this behavior with my module. You CAN get data, based on the url test. But, for you, the module is not getting the data. Thus, it’s not loading.
            I don’t think this is a module issue. I’ll ask my friend on the forum to look into this for you. He is amazing at troubleshooting MM and modules. I’m sure he will take a look at this. I’m sorry I couldn’t figure this out for you.
            B 1 Reply Last reply Oct 18, 2019, 1:23 AM Reply Quote 0
              bflbarlow @Mykle1
              Sounds good and no worries.
              Thanks for giving it a shot!
              M 2 Replies Last reply Oct 18, 2019, 1:24 AM Reply Quote 0
                @bflbarlow
                You’re welcome. I’m sure it will get worked out when the right people take a look at it.
                Peace.
                  @bflbarlow
                  I’ve sent you a private message
                  • S Away
                    sdetweil
                    edit the ~/MagicMirror/modules/MMM-MyStandings/node_helper.js
                    replace the getData function with this
                    	getData: function (notification, url) {
                    		var self = this;
                    		console.log('requesting:' + url);
                    		request({ url: url, method: 'GET' }, function (error, response, body) {
                    			if (!error && response.statusCode == 200) {
                    				var result = JSON.parse(body);
                    				console.log("have data from api size="+body.length);
                    				self.sendSocketNotification(notification, result);
                    			} else {
                    				console.log("MMM-MyStandings : Could not load data."+" error="+error+" status="+response.statusCode);
                    open a terminal window
                    stop mirror , pm2 stop 0
                    then start manually
                    npm start dev
                    you should see
                    MMM-MyStandings helper started ...
                    Launching application.
                    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                    [14416:1017/204410.405574:ERROR:CONSOLE(2564)] "The given range isn't in document.", source: chrome-devtools://devtools/bundled/shell.js (2564)
                    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    requesting:http://site.web.api.espn.com/apis/v2/sports/basketball/nba/standings?level=3&sort=gamesbehind:asc,winpercent:desc
                    have data from api size=126499
                    or something
                    please advise
                    S 1 Reply Last reply Oct 19, 2019, 6:04 PM Reply Quote 0
                    • S Away
                      @bflbarlow did u see my message above?
                      • 3 / 4
                      3 / 4
