    Advent Module not working for me...?
    8 Posts 3 Posters 4.8k Views 3 Watching
    • V Offline
      valid8r
      Caveat: this is the first module I have added to my mirror. I believe I have followed the instructions correctly. I did the git pull to get the MMM-Advent files into my /modules folder and I see the MMM-Advent folder. I modified config.js to add the module to my array. I did not use any configuration parameters at all and did not include “config:” in my config.js file.
      When I reboot my mirror, nothing displays at all and if I comment out the lines in my config.js file that I added my MM returns to normal. Is there a requirement for a config: parameter that I don’t know about?
      Thanks in advance,
      lolobyteL 1 Reply Last reply Reply Quote 0
      • lolobyteL Offline
        lolobyte @valid8r
        @valid8r
        Maybe this will help you.
        It’s my part of config with the Advent module after updating by the developer with the possibility to implement 4 candles.:
                            module: 'MMM-Advent',
                            position: 'bottom_center',
                                    updateInterval: 10 * 60 * 1000,
                                    marks: 0, //default is 24
                                    height: 400,
                                    showFlameBeforeStart: false,
                                    start: ["2016-11-27 00:00:01", "2016-12-11 00:00:01", "2016-12-18 00:00:01", "2016-12-04 00:00:01"],
                                    end: ["2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59"],
            //                      start: "2016-11-25 00:00:01", //Geburtstag Anfang
            //                      end: "2016-11-25 23:59:59", //Geburtstag Ende
            //                      start: "2016-12-01 00:00:01", //Eine Kerze; default is "2016-12-01 08:00:00"
            //                      end: "2016-12-24 23:59:59", //Eine Kerze; default is "2016-12-24 22:00:00"
                                    enableAnimation: true,
                                    fontColor: "#000000", //default is #000000 (black)
                                    candleColor: "#FFFFFF", //default is #FFFFFF (white)
          Jopyth Moderator
          @valid8r Did you copy and paste the example config from the readme? The section should work as is. If you did not copy it exactly, pay attention to the braces and commas, maybe you have got a syntax error.
          Full disclosure: I am the author of the module.
          Helpful sticky: How to troubleshoot
          • V Offline
            valid8r
            Thanks guys - I’m embarrassed to admit that I had typed “bottom-center” instead of “bottom_center”!
            lolobyteL 1 Reply Last reply Reply Quote 1
            • lolobyteL Offline
              lolobyte @valid8r
              @valid8r
              have u tried the snow module?
              looks nice with advent together.
              https://github.com/nhubbard/MagicPlugins/tree/master/snow
              • V Offline
                valid8r @lolobyte
                @lolobyte Thanks!!! This helped. I saw from this that I had mis-typed “bottom_center” as “bottom-center”!
                You would think that as an Engineer, details would be something I would excel at, apparently that is not the case!
                @lolobyte said in Advent Module not working for me...?:
                @valid8r
                I’m having trouble using git clone with the https:// link you provided. can you confirm that is the correct fork? Also does the module use position: ?
                • lolobyteL Offline
                  lolobyte
                  @valid8r
                  Hi, thats the web link. There is no fork link.
                  Create a folder “snow” in your module folder.
                  Copy snow.js and snow.css in this folder.
                  Edit your config.js an put folowing code into
                      module: 'snow',
                  restart your mm with
                  pm2 restart mm
                  Good luck
                  • V Offline
                    valid8r @lolobyte
                    @lolobyte Got it! Thanks! Wife love it.
