    config.js
    14 Posts 5 Posters 5.6k Views 4 Watching
    • G
      geo
      hi,in this config i am unable to add a line under position in compliments to insert config.
      i can do this in config.sample and config.file which is a copy.
      can anyone explain this please.
      cheers,
      geo
      S B 2 Replies Last reply Reply Quote 0
        sdetweil @geo
        @geo sorry, don’t understand the question…
        what editor are you using on the config.js file?
        • B
          bhepler Module Developer @geo
          @geo said in config.js:
          If you are using the nano editor, you can go to the end of the line above where you want to insert the new line and then press enter. That will give you a new line to play with.
          For starters, the name of the file is config.js. It has to be named exactly that in order for the system to work. So I would recommend that you copy your config.sample to config.js by entering cp config.sample config.js and then start your mirror process.
          Once you have a working config file, we can work on modifying it.
          S G 2 Replies Last reply Reply Quote 0
            sdetweil @bhepler
            @bhepler he has a working system… now wants to add more
            • G
              geo @bhepler
              @bhepler hi thx for that
              however when i try to copy using cp config.sample config.js i get the message no such file or directory
                sdetweil @geo
                @geo its
                cp config.sample.js config.js
                warning, its will overwrite the file on the right side of that command…
                it will NOT warn you
                u need to learn the linux commands
                so u can find files, copy , edit, create
                do a search on youtube “learn basic linux commands”
                G 2 Replies Last reply Reply Quote 1
                • G
                  geo @sdetweil
                  @sdetweil i tried yours and that was the message got
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @geo
                    @geo
                    1. Open a new terminal
                    2. type cd MagicMirror/config
                    3. Press Enter key
                    4. type cp config.sample.js config.js
                    5. Press Enter key
                    6. type cd ..
                    7. Press Enter key
                    8. type npm start
                    9. Press Enter key
                    10. Say thank you. :-)
                    • G
                      geo @sdetweil
                      @sdetweil hi looked looked a linux only recognised 4 commands.,but unless you understand code and know how to write it and what does then it means nothing to someone like me and thats why i have to ask for help.i have loaded another sd card withmm to practice but once the dreaded create a config appears i’m back to square one and have to delete mm and start again,ugh.
                      cheers
                      • G
                        geo @Mykle1
                        @Mykle1 as they say in yorkshire " Ta very much"
                          sdetweil @geo
                          @geo unlike windows, linux is case sensitive on filenames and command names…
                          here are some linux commands compared to windows
                          ls = dir , LS is nothing
                          cd = cd
                          rm = delete
                          cp = copy
                          mv = move
                          almost every command has help built in , using the --help parameter
                          cp --help
                          you can also ‘read the manual’ for commands by using the man command
                          man cp (to get out its the letter q)
                          in graphical mode, gedit is a pretty decent editor
                          in text mode (or over ssh) i hate vi, so I use nano… but it doesn’t support mouse actions like a graphical app.
                          • B
                            BD0G @geo
                            @geo Dont delete the full Magic Mirror image and start over!
                            Thats a waste of time.
                            Instead
                            change directories to the Magic Mirror directory like this
                            cd MagicMirror (press enter)
                            then run this command
                            npm run config:check (press enter)
                            This will run a build in linter (which is a fancy way of saying a program that checks the entries in a file to determine if there are errors)
                            Then view the results and the errors presented. Typicallly there is one symbol missing right above where the errors are reported. Pay attention to the line numbers that are listed where the errors start and look one or two lines up from that line number and see if you can perceive an issue.
                            • Mykle1M
                              @geo
                              Here is some help with creating a working config. It’s a short read but helpful.
                              https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                              • G
                                geo @BD0G
                                @BD0G hi,great thankyou
