    V2.10.0 - Impressive...
    18 Posts 3 Posters 4.6k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      First time EVER I’ve seen this… Great job in squashing vulnerabilities
      “found 0 vulnerabilities”
      smooth as silk upgrade, too.
        sdetweil @BKeyport
        @BKeyport how did u do the upgrade?
        • BKeyportB Offline
          git pull && npm install per instructions.
            sdetweil @BKeyport
            @BKeyport any reason u didn’t use the upgrade script?
            • BKeyportB Offline
              @sdetweil because I read the post, saw “Note: This update uses new dependencies. Please update using the following command: git pull && npm install”, and TL;DR the rest.
                sdetweil @BKeyport
                @BKeyport thanks
                • BKeyportB Offline
                  @sdetweil honestly, I forgot about your script work - twice over… Just recently installed a test install of MM too, and I was gonna use your work - That pi is annoying me a bit, so I may reinstall.
                  As I get update notices, I pop on here to make sure I’m gonna do things right, then follow the post instructions after a quick read to confirm.
                    sdetweil @BKeyport
                    @BKeyport yeh, I posted updated instructions shortly after Mich posted
                      sdetweil @BKeyport
                      @BKeyport the 2.10 release installer is the updated one, so u won’t miss it anymore!
                      • C Offline
                        chassain 0
                        hello sdetweil,
                        After your script i have this
                        0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                        0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                        0|mm | A JavaScript error occurred in the main process
                        0|mm | Uncaught Exception:
                        it’s ok for the new version of magic but no start mm…
                        happy new year
                          sdetweil @chassain 0
                          @chassain-0 can u post the installers/upgrade.log
                          looks like one of the modules is having trouble…
                          someone else reported a problem with the MMM-PIR-Sensor module…
                          • C Offline
                            chassain 0
                            i’ve seen the log…a "npm instal"l has resolved this…sorry ! thanks
                              @chassain-0 but the upgrade was supposed to handle this… can I see the log?
                              u have to run the script twice, right? once to test and once to apply
                              • C Offline
                                chassain 0
                                Upgrade started - jeu. janv. 2 00:47:49 CET 2020
                                system is Linux raspberrypi 4.19.83-v7l+ #1277 SMP Mon Nov 11 16:41:20 GMT 2019 armv7l GNU/Linux
                                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                user requested to apply changes
                                doing test run = false
                                saving custom.css
                                not english or locale not set, set git alias
                                remote name = origin
                                local version 2.10.0 already same as master 2.10.0
                                restoring custom.css
                                removing git alias
                                Upgrade ended - jeu. janv. 2 00:48:00 CET 2020
                                Upgrade started - jeu. janv. 2 01:12:46 CET 2020
                                doing test run = true
                                saving custom.css
                                upgrading from version 2.10.0 to 2.10.0
                                fetching latest revisions
                                git fetch rc=0
                                current branch = master
                                Sur la branche master
                                Votre branche est à jour avec ‘origin/master’.
                                Modifications qui ne seront pas validées :
                                (utilisez “git add …” pour mettre à jour ce qui sera validé)
                                (utilisez “git checkout – …” pour annuler les modifications dans la copie de travail)
                                modifié :         modules/default/calendar/README.md
                                modifié :         modules/default/weather/README.md
                                modifié :         modules/default/weather/current.njk
                                modifié :         modules/default/weather/providers/README.md
                                modifié :         modules/default/weather/providers/darksky.js
                                modifié :         modules/default/weather/providers/openweathermap.js
                                modifié :         modules/default/weather/providers/ukmetoffice.js
                                modifié :         modules/default/weather/providers/weathergov.js
                                modifié :         modules/default/weather/weatherobject.js
                                Fichiers non suivis:
                                (utilisez “git add …” pour inclure dans ce qui sera validé)
                                %logfile
                                css/customDGA.css
                                css/customHF.css
                                css/customboucherie.css
                                css/customboutique.css
                                css/customdefault
                                css/customhome.css
                                css/customimmo.css
                                css/custommedecin.css
                                css/customsalon.css
                                css/customshoes.css
                                css/save_custom.css
                                installers/dumpactivemodulesoldjs
                                modules/default/calendar/calendaroldjs
                                package-lockoldjson
                                aucune modification n’a été ajoutée à la validation (utilisez “git add” ou “git commit -a”)
                                no files different from github version
                                test merge result rc=‘’ , if empty, no conflicts
                                skipping merge, only test run
                                processing dependency changes for active modules with package.json files
                                processing for module MMM-DarkSkyForecast please wait
                                skipped processing for MMM-DarkSkyForecast, doing test run
                                processing complete for module MMM-DarkSkyForecast
                                processing for module mmm-suncalc please wait
                                skipped processing for mmm-suncalc, doing test run
                                processing complete for module mmm-suncalc
                                processing for module MMM-MovieListings please wait
                                skipped processing for MMM-MovieListings, doing test run
                                processing complete for module MMM-MovieListings
                                processing for module MMM-soccer please wait
                                skipped processing for MMM-soccer, doing test run
                                processing complete for module MMM-soccer
                                processing for module MMM-rfacts please wait
                                skipped processing for MMM-rfacts, doing test run
                                processing complete for module MMM-rfacts
                                processing for module MMM-SmartWebDisplay3 please wait
                                skipped processing for MMM-SmartWebDisplay3, doing test run
                                processing complete for module MMM-SmartWebDisplay3
                                processing for module MMM-SmartWebDisplay4 please wait
                                skipped processing for MMM-SmartWebDisplay4, doing test run
                                processing complete for module MMM-SmartWebDisplay4
                                processing for module MMM-SmartWebDisplay please wait
                                skipped processing for MMM-SmartWebDisplay, doing test run
                                processing for module MMM-SmartWebDisplay2 please wait
                                skipped processing for MMM-SmartWebDisplay2, doing test run
                                processing complete for module MMM-SmartWebDisplay2
                                processing for module MMM-pages please wait
                                skipped processing for MMM-pages, doing test run
                                processing complete for module MMM-pages
                                removing git alias
                                Upgrade ended - jeu. janv. 2 01:12:49 CET 2020
                                Upgrade started - jeu. janv. 2 01:13:07 CET 2020
                                saving custom.css
                                removing git alias
                                Upgrade ended - jeu. janv. 2 01:13:07 CET 2020
                                • C Offline
                                  chassain 0
                                  i will try on another raspberry
                                    @chassain-0 local version 2.10.0 already same as master 2.10.0
                                    so, it looks like u did the test (no parms)
                                    and it worked
                                    but then did not do the rerun with ‘apply’, but did a pull?
                                    and then tried to run with apply, but already upgraded,
                                    u can use ‘force’ as another parm to apply over same version
                                    • C Offline
                                      chassain 0
                                      apply after the test…i don’t why i had this pb…thanks for response…I will see next time on an another raspberry…Thanks again
                                        @chassain-0 it says you must have done the git pull before doing the upgrade-script…
                                        (already at 2.10.0 when script started)
                                        test doesn’t change any files, but apply runs were aborted as the installed version was already at 2.10.0, so no npm install was done by script
