    used the amazing complete setup but after 'npm start'.....
    17 Posts 6 Posters 12.1k Views 4 Watching
    • alonshwartz1966A
      alonshwartz1966
      I’ve received error messages (see below). WHat should I do?
      sh: 1: electron: not found
      npm ERR! Linux 4.4.34-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      npm ERR! node v6.9.2
      npm ERR! npm v3.10.9
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      N 1 Reply Last reply
      • N
        nuckinfutz @alonshwartz1966
        @alonshwartz1966 you either are tring to start the mirror from the root folder or you didn’t install node.js correctly I believe. I’m on my cell sorry I could give a better answer. I’ll check later tonight
        • brobergB
          broberg Project Sponsor
          Run the install script again.
          alonshwartz1966A 1 Reply Last reply
          • N
            nem1
            please check if you had a stabile connection to the internet while running the install process of the mirror. just try it again if you are sure. Thix fixed my problem in the beginning
            • A
              Ancient
              I’ve got the same Problem.
              Fresh installation of Raspian on an Raspberry Pi3.
              Running the install Script again doesn’t help.
              brobergB 1 Reply Last reply
              • brobergB
                broberg Project Sponsor @Ancient
                @Ancient said in used the amazing complete setup but after 'npm start'.....:
                Even if you remove the magicmirror folder before running it again?
                I had a similar issue (don’t know if it was exactly the same, since I didn’t save the log).
                It seems like the Electron.js is the issue, in my case it was missing for some reason, removing the magicmirror folder and running the install script again did the trick for me.
                • A
                  Ancient
                  Yep,
                  deleteing as well as renaming the MagicMirror Folder won’t do the trick for me.
                  Maybe it’s related to this Issue https://github.com/MichMich/MagicMirror/issues/567
                  Where should the electron.js be located, i believe it’s missing here too.
                  • brobergB
                    Yep,
                    In the magicmirror folder, node_modules and then electron or electron-prebuilt
                    maybe try to install it manually?
                    npm install electron --save-dev
                    • brobergB
                      also, are you all running the X GUI or are you trying to start it directly from the prompt it boots in to?
                      • A
                        Ancient
                        I try to start it directly from the prompt
                        electron@1.4.12 postinstall /home/pi/MagicMirror/node_modules/electron
                        node install.js
                        magicmirror@2.0.0 /home/pi/MagicMirror
                        ├── electron@1.4.12
                        └── UNMET PEER DEPENDENCY grunt@1.0.1
                        npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
                        • alonshwartz1966A
                          alonshwartz1966 @broberg
                          @broberg the install of what? the entire process of the MagicMirrir?
                          • alonshwartz1966A
                            alonshwartz1966 @nem1
                            @nem1 thanks for the feedback. My connection was OK during the installation
                            • brobergB
                              broberg Project Sponsor @alonshwartz1966
                              @alonshwartz1966
                              Yes, remove the entire magicmirror folder and run the install script again, for me the script stopped (without errors) several times,
                              Also, when you are trying to start it, do you try to start it via the LXterminal in the desktop environment or directly in the boot prompt?
                              • H
                                Heretic
                                I get a very similar error if I’m just running at the CLI. With the GUI running NPM START (from a local terminal window) is successful, I never did get it going from CLI.
                                I also never got PM2 to successfully work without manually kicking it off after the gui has launched.
                                I’ve taken about 4 runthroughs at the install, so at this point I’ve no idea what the issue is.
                                pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                                magicmirror@2.0.0 start /home/pi/MagicMirror
                                npm ERR! Linux 4.4.32-v7+
                                npm ERR! node v6.9.1
                                npm ERR! npm v4.0.2
                                npm ERR! Exit status 1
                                npm ERR!
                                • N
                                  nuckinfutz
                                  Here is what I would do as I’ve been in your shoes’
                                  This is how I do it and I’ve done it close to 50 times.
                                  Ignore everyone else for now. You will be starting from scratch. Again.
                                  Go here and follow the Noobs install procedure. You want the full Noobs NOT Noobs Lite
                                  https://www.raspberrypi.org/downloads/noobs/
                                  When you boot this choose the first option (raspian) After it finishes
                                  Dont add users or change anything else leave all defaults with the exception of the following
                                  Make sure you set your localization, keyboard, wireless etc. by going to
                                  Preferences -> Raspberry Pi Configuration
                                  Open a terminal session
                                  Your prompt should look like the following
                                  pi@raspberrypi:~ $
                                  copy and paste the following into a terminal. This is one line. accept any defaults if a question comes up.
                                  curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                                  Now Copy and paste
                                  cd /home/pi/MagicMirror
                                  DISPLAY=:0 npm start dev
                                  If you dont want the Console running omit “dev” from the end
                                  I always start the MM using this method.
                                  • alonshwartz1966A
                                    alonshwartz1966 @nuckinfutz
                                    @nuckinfutz Hi. Thanks for the instructions. I’ve managed to run the MagicMirror. Now I just need to work on adjustments.
                                    • alonshwartz1966A
                                      @broberg Hi. Thanks for the instructions. I’ve managed to run the MagicMirror. Now I just need to work on adjustments.
