    MMM-Tado wrong units
    28 Posts 3 Posters 8.8k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      Can anybody help me to set metric units…in the config I have set
      units:  “metric“,
      but it does not work
      https://github.com/WouterEekhout/MMM-Tado
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe
              units: 'metric',
        is the default setting in the module config
        and it does this in the code
          if (zone.state.setting.temperature == null) {
                                var temperatureTextWrapper = document.createTextNode(zone.state.setting.power);
                            } else {
                                if (self.config.units === "metric") {
                                    var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.celsius + "°");
                                } else {
                                    var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.fahrenheit + "°");
          @Stoffbeuteluwe
          actually there is a bug in the code
          change MMM-Tado.js
              start: function () {
                  var self = this      //    add this line -----------------------
                  if (this.config.updateInterval < this.defaults.updateInterval){
                      this.config.updateInterval = this.defaults.updateInterval;
                  this.config.units = self.config.units;   // ----------- otherwise this wipes out the config setting
                  this.sendSocketNotification('CONFIG', this.config);
            Stoffbeuteluwe Project Sponsor @sdetweil
            @sdetweil Thanks Sam works …:folded_hands_medium-light_skin_tone:
              @Stoffbeuteluwe I posted an issue to his repo
              https://github.com/WouterEekhout/MMM-Tado/issues/9
              • W Offline
                WouterEekhout
                @Stoffbeuteluwe
                I cannot reproduce the problem. In my case the self.config.units reads out the units from the config.js correctly. If I add var self = this, then it will read out the defaults set in the MMM-Tado.js and not from the config.js.
                My config.js looks like the following:
                var config = {
                	units: "metric",
                			module: 'MMM-Tado',
                			position: 'top_right',
                			header: 'My Home',
                				username: 'X',
                				password: 'X',
                				updateInterval: 300000,
                  sdetweil @WouterEekhout
                  @WouterEekhout that is not how it works…
                  at module startup time, before init is called, the MM module loader will take the module supplied defaults and merge on top the config.js config:{} section for the module. using Object.assign ({}, default, config())
                  and CREATE and item in the module namespace called config… it is a replace config =
                  Object.assign() is a replace operation, whatever was there before is replace with the same object from the
                  // MM/js/module.js
                  	setConfig: function (config) {
                  		this.config = Object.assign({}, this.defaults, config);
                  the statement above creates an empty object {}, then assigns on top the module defaults section,
                  then assigns values from the config.js config object on top of those (replacing any same named items)
                  your module does not HAVE a config object defined… it has a defaults object, which is not touched…
                  the problem is at start time in your module
                  self has not been explicitly set. so, you have NO idea where it is pointing, but this IS set,
                  and this.config is the merged result from the setConfig function above…
                  so, you stomp on (replace, not merge) the this.config object with whatever is pointed to by self.config.
                  AFTER getDom() is called once (long after start) then self is set
                  /// MMM-Tado.js
                      // Override dom generator.
                      getDom: function () {
                          let self = this;
                  now this and self point to the same thing, the instance of module which is MMM-Tado.js AND including the dynamically created (and over written in start) config object.
                  • W Offline
                    WouterEekhout
                    @sdetweil I don’t think we are on the same page. Your solution is not working for me, therefor I cannot reproduce it.
                    I tested it by setting my units in the config.js as following:
                    var config = {
                       units: 'lipsum',
                    I add your recommendation and debug it:
                    As you can see, the self.config.units is not ‘lipsum’.
                    If I keep my code like it is now:
                    As you can see now self.config.units contains ‘lipsum’. Also the output on the screen is correct (It shows the temp in fahrenheit, because it is not equal to ‘metric’).
                    I might be overlooking something. But as far as I am seeing, it works correctly.
                      @WouterEekhout according to the doc
                      https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
                      this.config	Boolean	The configuration of the module instance as set in the user's config.js file. This config will also contain the module's defaults if these properties are not over-written by the user config.
                      and my experience matches this and depends on it.
                      from my 2.11 system with your latest module installed
                      config
                              module: 'MMM-Tado',
                              position: 'top_right', // This can be any of the regions.
                                  username: 'your_tado_username',
                                  password: 'your_tado_password',
                                  units:"freddy"
                      this.config
                      self.config
                      notice that self.config is THE mm config.js in object form and it HAS a ‘units’ value, so when the assignment happens
                      this.config.units=self.config.units
                      units will change from ‘freddy’ to ‘metric’
                      • W Offline
                        WouterEekhout
                        @sdetweil Thank you for the clarification. Now it is clear why there is miscommunication. I use the units from the general config settings: https://docs.magicmirror.builders/getting-started/configuration.html#general .
                        To clarify my config looks like this:
                        var config = {
                        	address: "localhost",
                        	port: 8080,
                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
                        	language: "en",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: 'MMM-Tado',
                        			header: 'My Home',
                        				username: 'x',
                        				password: 'x',
                        Notice that the units-config is outside modules-config. And not in the module-config. I think this makes more sense. Because of this self.config.units does contain the correct value. I will update the readme about the units-config, so it will be more clear.
                          @WouterEekhout ok, but… i don’t think that is what the USER wanted… their system is in metric, but they wanted your module display to be Fahrenheit, so I would use some other varname, and check to see if they specified that, and use IT over the system value…
                          or because u have it as a default, if u set it to some invalid value, then check if its what you allow,
                          then if invalid, use system, otherwise allow users value…
                          • W Offline
                            WouterEekhout
                            @sdetweil I disagree, it is unclear if the current config is not working or if he wanted a custom units setting for the app. @Stoffbeuteluwe Can you clarify if you wanted to set a different unit for the app?
                              Stoffbeuteluwe Project Sponsor @WouterEekhout
                              @WouterEekhout I am from Germany and I need metric unit but Sam helped me to fix and now it’s working for me.
                              It would be cool to have the choice in module config. Metric or imperial
                              Thanks to you guys
                                @Stoffbeuteluwe what is your main config.js units set to? up near address:
                                  @sdetweil it is metric
                                    @Stoffbeuteluwe so, the original code should have worked…
                                      @sdetweil without your fix it does not work in my case
                                        @Stoffbeuteluwe hmm…
                                        can u share the top of your config.js, before the modules:[ line
                                        thanks
                                          @sdetweil Hello, after module update same problem
                                          and your fix don’t work anymore…can you help me again?
                                          var config = {
                                          	address: "0.0.0.0", // Address to listen on, can be:
        // - "0.0.0.0", "127.0.0.1", "::1" to listen on loopback interface
        // Default, when address config is left out, is "0.0.0.0"
                                          	port: 8080,
                                          	ipWhitelist: [], // Set [] to allow all IP addresses
                                          	language: "de",
                                          	timeFormat: 24,
                                          	units: "metric",
                                            @Stoffbeuteluwe ok, need an editor for this…
                                            line 26 of MMM-Tado.js, leave alone
                                            change all the other this.config.units to self.config.units
                                            change them all, then change line 26 back to this.
                                            I have opened issue 11
                                            https://github.com/WouterEekhout/MMM-Tado/issues/11
