    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 114.8k Views 18 Watching
    • johnnyboyJ Offline
      johnnyboy @STEFF92
      This post is deleted!
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @STEFF92
        @STEFF92 none is not a valid js value either use
          module: 'MMM-PIR-Sensor',
            sensorPIN: 23,
            powerSaving: true,
            relayPIN: false,
            relayOnState: 1
        or like this, because relayPIN is set to false by default
            sensorPIN: 23,
            powerSaving: true,
            relayOnState: 1
          STEFF92 @strawberry 3.141
          @strawberry-3.141 Thanks, now the config file and the magic mirror surface are running but there is no response from the sensor. i have moved the potentiometer but the screen doesnt turn off. Do you know any possible mistake i could have made?
            @STEFF92 I guess you might defined the wrong pin number according on your setup you use gpio23 which is pin 16 in this diagram https://forum.magicmirror.builders/uploads/files/1485851152518-raspberry-pi-15b.jpg, but I never did something with the gpio of the pi
            • O Offline
              Oliver_Tooth
              Hi all,
              I’ve been trying to instal this module, but i’m bumping into the issue of needing node module 53, as it was compiled with 48. I’ve been at this all day and i’m really struggling. Can anyone offer any advice? Thanks in advance!
              • Y Offline
                yawns Moderator @Oliver_Tooth
                @Oliver_Tooth
                Please search this forum for “version mismatch”. I’m on my smartphone right now, otherwise I would post the command necessary.
                You need to rebuild the module with a special command providing the version info related to your system
                • O Offline
                  Oliver_Tooth @yawns
                  @yawns Cheers for this. I’ve had a quick browse but i’m struggling to find anything that works. If your able to post the command whenever you’re able to i’d really appreciate it! thanks.
                  Y 2 Replies Last reply Reply Quote 0
                  • Y Offline
                    @Oliver_Tooth
                    Sure, tomorrow morning
                    • Y Offline
                      @Oliver_Tooth
                      all right …
                      Open a terminal and do this:
                      cd ~/MagicMirror
                      npm list | grep electron
                      You will see something like this:
                      ├─┬ electron-prebuilt@1.4.5
                      │ ├─┬ electron-download@3.0.1
                      npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
                      Note the version of electron, in this case it is 1.4.5, if it is different for you please replace the version accordingly.
                      Afterwards run this:
                      cd modules/MMM-PIR-Sensor
                      npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
                      Now the module should not throw a version mismatch error any more.
                      O 2 Replies Last reply Reply Quote 0
                      • O Offline
                        Oliver_Tooth @yawns
                        @yawns Hi! my prebuilt version was slightly different, so i changed that in the target= field, does the abi= number need to be 53, not 50? I’ve tried it as 50 and it’s still throwing the error.
                        • O Offline
                          Oliver_Tooth @yawns
                          @yawns I’ve been reading up further on this, and i’ve found that version 53 doesn’t actually exist yet, and 51 is currently the latest. Have you any idea how i’d get this to work with this information? thanks.
                          • T Offline
                            thoimi
                            hi there,
                            finally i had the time to work / finish my magic mirror.
                            Just the PIR-Sensor-Plugin doesn’t work… After I updated the MM to 2.1.1 I did a fresh install of the script which worked without an error. Yay!
                            BUT the script is not turning off my monitor… I connected the sensor to GPIO04 / BCM07 and tried to change the SensorPin-Number (from 4 to 7)
                            I put the sensor in a black box so the display should shut down after starting Magic Mirror, right?
                              Richard238
                              Hmmmm, black screen, and nothing on a browser at http://192.168.n.nn:8080/ either.
                              		sensorPIN: 22,
                                              powerSaving: true,
                                              relayPIN: false,
                                              powerSavingDelay: 0,
                                              relayOnState: 1
                              • P Offline
                                pepemujica
                                Do I need anything else than the raspi, cable and pir sensor?
                                An arduino for example?
                                Kind regards
                                • Y Offline
                                  yawns Moderator @pepemujica
                                  @pepemujica
                                  No. You can connect the PIR sensor to the GPIO pins of your raspberry (make sure your wiring is proper) and work with the PIR sensor after installing the specific libraries
                                  • 4 / 4
