    Is it possible to ad an Arduino?
    55 Posts 4 Posters 27.2k Views 4 Watching
      Shinji0912
      Hi, for school we need to build a project using an Arduino.
      For me the Arduino itself is boring thats why i decided to build a MagicMirror using Raspberry Pi and i wanted to integrate functions from Alex, different Sensor-stats like Temperature and the PIR
      But everything i tried didn’t worked and now im Wondering if it’s even possible to connect both.
      Sensors i have and want to use :
      DHT11, for Temperature in Room,
      HC-SR501, for Timeouts when not standing infont of it
      ESP8266 ESP-12E, to Connect to the Alexa
      Im Using a Raspberry Pi3
      and an Arduino Uno R3 with the ELEGOO Ultimate Starter kit and a few other modules.
      i would really appreciate if someone helps me and if you have good ideas to what i should add to get a good grad xD i would really appreciate it aswell.
      This is my Current Config :
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "de",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",
      		module: 'MMM-TelegramBot',
      			telegramAPIKey: 'api token changed so you can't use it xD',
      			allowedUser: ['same for here'],
      			adminChatId: 'xxx'
      			module: "MMM-Online-State",
      			module: "updatenotification",
      			position: "bottom_bar"
      			module: "clock",
      			position: "top_right"
                  module: 'MMM-RBB-Weather',
                               days: "0",
                               updateInterval: "600",
      			header: "Events",
      						symbol: "calendar-check-o ",
      						url: "my ical adress changed it aswell",
      						maximumEntries: "5",
      						maximumNumberOfDays: "7"
        module: "MMM-NowPlayingOnSpotify",
        position: "bottom_left",
          showCoverArt: false,
          clientID: "nothing to see here",
          clientSecret: "pls help me get a good grade",
          accessToken: "xD",
          refreshToken: "xxx"
      EDIT:
      And oh before i forget i would like to add some w2812b RGB Strips
      S wishmaster270W 2 Replies Last reply Reply Quote 0
        sdetweil @Shinji0912
        @Shinji0912 there are a bunch of arduino modules on github
        google search
        mmm-arduino github
        some are general (arduport)
        some are more specific MMM-temphumidity
        • wishmaster270W Offline
          wishmaster270 Module Developer @Shinji0912
          @Shinji0912 Hi, I wrote a module which converts messages received at serial interfaces to notifications (https://github.com/Tom-Hirschberger/MMM-Serial-Notifications). I have two Arduinos connected to my Pi with gesture and distance sensors.
          My temperature module (https://github.com/Tom-Hirschberger/MMM-Temperature) can receive notifications to update the values.
          Edit: The notification feature is only available in the development branch at the moment. I will mere it to the master the next days.
          There are examples integrated which show how to connect an esp32 board with WiFi to get temperature and humidity.
          Currently I am working on a module which should use MQTT to control an WS2801 LED Strip. But this one is in a very early state and will take a while to develop.
            Shinji0912 @wishmaster270
            @wishmaster270 Wow thank you very much , im completly new to this and first of all this helps me out very much and im going to try to make my own module showing an API from our school , is it okay if i ask you questions when i need help?
            and btw. rrealllyy appreciate your help :)
              Shinji0912 @sdetweil
              @sdetweil I tried the “Arduports” one but for some reason it didn’t worked for the sensors im using ^^
                @Shinji0912 u have to have code running in the Arduino sending the data, doesn’t just happen
                  @sdetweil I know I’ve set it up but it didn’t worked.
                  S S 2 Replies Last reply Reply Quote 0
                    @Shinji0912 seems pretty simple, connect serial port for arduino to serial port for PI…
                    arduino send 10
                    https://www.arduino.cc/reference/en/language/functions/communication/serial/write/
                    pi read 10
                    https://www.npmjs.com/package/serialport
                    u can test that without MagicMirror
                      Shinji0912 @Shinji0912
                      This post is deleted!
                        @sdetweil Thats my Current Arduino code :
                        volatile int32_t m_counter = 0;
                        bool WasStarted = false;
                        static const char *pcDHT11Prefix = "[sensor:DHT11:";
                        static const char *pcPostfix = "]";
                        void setup() {
                          Serial.begin(9600);
                          while(!Serial);
                          Serial.println("[status:setup:starting]");
                          Serial.println("[sensor:DHT11:11]");
                          int test = 1;
                          m_counter = test;
                          if(test > 1) {
                            WasStarted = false;
                            Serial.println("[status:setup:failed]");
                            return;
                          delay(3000);
                          WasStarted = true;
                          Serial.println("[status:setup:started]");
                          delay(100);
                        void loop() {
                          Serial.print(m_counter + 11);
                          Serial.println(pcPostfix);
                          if(m_counter % 3 == 0) {
                            delay(1000);
                            Serial.print(pcDHT11Prefix);
                            delay(2000);
                          if(m_counter >= 60) m_counter = 0;
                          m_counter++;
                          delay(1000);
                        and i got the ArduPorts running on the MM itself
                        now it is running but always searching for the module … see Picture.
                        alt text
                          @Shinji0912 and the config for the port ??
                                          portname: "/dev/ttyUSB0",
                          ls /dev | grep -i usb
                          I don’t see a ttyUSB0 on my pi4…
                          is that the right one on pi?
                          i would guess that is for a USB plugin serial port, not direct serial port…
                          I do have a /dev/serial1 (on all 3 of my pi devices, Pi0, Pi3, and Pi4)
                            Shinji0912
                            I have it plugged in on my Raspberyy Pi3 and the config on the Pi itself is
                            	          module: 'MMM-ArduPort',
                            	          position: 'bottom_right',
                                          header: 'Arduino Sensors',
                                            updateInterval: 1,
                                            animationSpeed: 1000,
                                            displayIcons: true,
                                            showDescription: true,
                                            hideLoading: false,
                                            hideWaiting: false,
                                            useColors: true,
                                            sensors: [
                                                    description: "Temperature",
                                                    maxValue: 50,
                                                    maxFormat: "({0}°C) VERY HIGH",
                                                    highestValue: 30,
                                                    highestFormat: "({0}°C) HIGH",
                                                    highValue: 15,
                                                    highFormat: "({0}°C) NORMAL",
                                                    lowValue: 10,
                                                    lowFormat: "({0}°C) LOW",
                                                    lowestValue: 5,
                                                    lowestFormat: "({0}°C) VERY LOW",
                                                    minValue: 0,
                                                    minFormat: "({0}°C) OK"
                            and im not pretty sure what u want to tell me (im not an native english speaker) i come from germany
                              @Shinji0912 said in Is it possible to ad an Arduino?:
                              I think that is the wrong device name for the serial port on the pi. if you are using the gpio header pins
                              Ich denke, das ist der falsche Gerätename für die serielle Schnittstelle auf dem Pi. wenn Sie die GPIO-Header-Pins verwenden
                                @sdetweil Im not using the Gpio header pins i have the Arduino connected to the Pi using usb?
                                  @Shinji0912 i have never seen arduino connected via USB… none of my arduino devices have USB plugs
                                  did u check the available device names on your pi?
                                  from a terminal window do
                                    @sdetweil https://www.conrad.de/de/p/arduino-ag-usb-2-0-anschlusskabel-1x-usb-2-0-stecker-a-1x-usb-2-0-stecker-b-1-80-m-schwarz-95068.html?hk=SEM&WT.srch=1&WT.mc_id=google_pla&s_kwcid=AL!222!3!418522360024!!!g!!&ef_id=CjwKCAjwkoz7BRBPEiwAeKw3qy_SdRSLbXPZvYvpwSlJoKKFL-pjesNMeK_-wcbD8RJ4kJ7A1uo9ghoCmeUQAvD_BwE%3AG%3As&gclid=CjwKCAjwkoz7BRBPEiwAeKw3qy_SdRSLbXPZvYvpwSlJoKKFL-pjesNMeK_-wcbD8RJ4kJ7A1uo9ghoCmeUQAvD_BwE
                                      @Shinji0912 this is my arduino experience
                                      https://www.antratek.com/nodemcu-v2-lua-based-esp8266-development-kit
                                        @sdetweil Oh ok , the school told us to buy the Uno R3 and it’s the first one i’ve used so far ^^
                                          Shinji0912
                                          @sdetweil alt text
                                            @Shinji0912 don’t see ttyUSB0
                                            are there any message on the console where u start mm? npm start? or pm2 logs --lines=???
                                            ??? is a number, default is 15
                                            • 1 / 3
