    MMM-TouchNavigation, A Touch Activated Profile/Layout Changer
    touchnavigationmodulelayoutprofilebuttonswitch
    43 Posts 9 Posters 47.5k Views 10 Watching
    • tosti007T Offline
      tosti007 Module Developer @Snille
      @Snille thank you for pointing out about the css file, I read over that!
      @shashank what @Snille says is right. The css file should remain as it is and you should put his css in css/custom.css file
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • G Offline
        GorramRob
        Hi! Thanks for writing this! I’m trying to get it running but am having some troubles. I have a handful of modules listed as ignored in the profile switcher module (including the clock so at least something should be showing all the time) but as soon as I enable the TouchNavigation module all I see is a black screen. No modules are displayed/visible.
        I double checked the MODULE_DATA from the remote-control module, it appears all the modules are loading correctly. Any thoughts on what might be going on?
        tosti007T 1 Reply Last reply Reply Quote 0
        • tosti007T Offline
          tosti007 Module Developer @GorramRob
          @GorramRob hmmm that’s fairly odd. Try doing a fresh clone and make sure that your config file it right. Did you add the touchnavigation to the ignore modules aswell, is ne spelling correct (case sensitive) and is the ignoremodules config an array? In the meantime I will have another look at the module trying to figure out what might be wrong.
          • G Offline
            GorramRob @tosti007
            @tosti007 Huh… I’m not sure what was going on but I cloned a new copy of it and everything seems to be working fine. I thought I had done that before, but maybe not. Thank you for replying so quickly!
            • tosti007T Offline
              After the new update of the MagicMirror framework and this issue I updated the css. This means that you can finally use the fullscreen positions for this module!
              • cowboysdudeC Offline
                cowboysdude Module Developer
                Fine module Sir… I’ll be playing with this very soon ;)
                • tosti007T Offline
                  Hello everybody! I made a new module that is basically a rewrite of this one, but it allows for custom notifications. You can find more info about it here. MMM-TouchNotifications has the same features as MMM-TouchNavigation (the one you are looking at now).
                  • SnilleS Offline
                    Snille Module Developer
                    @tosti007 Darn you! :) Now I have to start using this instead!! Thank you, need to get my mirror up and running again so I can reconfigure it (building frame for the moment). :)
                    If you cant find it, make it and share it!
                    Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                    • tosti007T Offline
                      @Snille well you don’t have to, it’s just an option :P both still work. The other just allows for more possiblies but does take some more configuration than this module
                        Binog
                        Hey, can someone please help, or just post their config file?
                        1.: I have this, and it does not show anything:
                        and
                        2.: What does the payload has to look like? that seems incorrect,… !?
                                   module: "MMM-TouchNavigation",
                                   position: "bottom_right",
                                   classes: 'default you me',
                           			picturePlacement: "right",
                           			minWidth: "30px",
                           			direction: "row",
                           			//border-radius: "1px",
                           			//border-radius: "50%",
                           			buttons: {
                           				"me": {
                           					img: "http://file to jpg",
                           					width: 40,
                           					height: 40,
                           					profilename: "me",
                           					text: "me",
                           				"You": {
                           					img: "https://file to .jpg",
                           					width: 40,
                           					height: 40,
                           					NOTIFICATION: {
                           						payload: {
                           							//this.sendNotification('CURRENT_PROFILE', 'You')
                           						profilename: "You",
                        • 4 / 5
