    MMM-TouchNavigation, A Touch Activated Profile/Layout Changer
    touchnavigationmodulelayoutprofilebuttonswitch
    43 Posts 9 Posters 47.5k Views 10 Watching
    • tosti007T Offline
      tosti007 Module Developer
      @all IMPORTANT NOTE: Unfortunatly setting this module to full screen does not work. The menu floats in the top left corner and you cannot press any buttons! I might be able to fix this, but since there is no audience currently wanting this feature I will wait for the new MagicMirror version (where this issue will be fixed). Let me know if you want to have it full screen aswell and I will see what i can do!
      Edit: thanks to @broberg this issue was solved :)
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • brobergB Offline
        broberg Project Sponsor @tosti007
        @tosti007 add z-index: -1 or 0 to the region fullscreen above, it blocks everything beneath so it can’t be clicked ( or add z-index: 2 to the module div)
        tosti007T 2 Replies Last reply Reply Quote 0
        • tosti007T Offline
          tosti007 Module Developer @broberg
          @broberg yea I thought that would work too, however when I set z-index to -1 on region fullscreen nothing much happened. I will try that z-index of 2 on the module dif aswell
          • tosti007T Offline
            @broberg Only setting region fullscreen to 0 worked. Not entirely sure tho. Anyways ty for the tip! Updated my module :)
              shashank @tosti007
              @tosti007 hi, after git pull, module working great, Thanks for your quick response , keep rocking…
                shashank @tosti007
                @tosti007 , Any possibility of using JPG photos of users instead of symbols in the TouchNavigation module, this will give a good interaction with the mirror
                tosti007T 1 Reply Last reply Reply Quote 0
                • tosti007T Offline
                  tosti007 Module Developer @shashank
                  @shashank you are welcome :) and about the images: yes I think that would be most definitely possible. However then the button size might become a problem if it’s too big, but I can give it a try.
                    shashank @tosti007
                    @tosti007 hi, other modules are ovelapping on to Touch Profile , how to move touch profile icons to extreme bottom or top
                    • tosti007T Offline
                      @shashank a way would be to change the z-index in teh css file to a higher number, I will have a look at it
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @tosti007
                        @tosti007 when you just change the zindex the modules are still overlapping
                        you could create a class left center and right and then classes for top middle bottom and let the user decide which position it has like bottom right
                        • 2 / 5
