    MM2 launch without internet
    11 Posts 5 Posters 8.3k Views 4 Watching
    • C
      cianoo45
      Wanted to build one of these mirros for a friend, but its a suprise so i wont be able to configure it to connect to her internet, Will it still work without internet?
      • cowboysdudeC
        cowboysdude Module Developer
        Some of it yes… like the clock but the rest if primarily internet data driven…
        yawnsY 1 Reply Last reply
        • yawnsY
          yawns Moderator @cowboysdude
          @cowboysdude said in MM2 launch without internet:
          Won’t even the clock reset to some dummy value? The raspberry does not have a realtime clock and does not know date and time once power was removed.
          It uses NTP to update its clock
          • C
            cianoo45
            Could I plug one of those USB wifi things into it, would that work?
            • yawnsY
              yawns Moderator
              You could, but that won’t change anything, because you still need to make sure it connects to the wifi around.
              Or are you talking about a wireless wan (umts/3g) stick?
              • C
                cianoo45
                Yeah one of those little router things for 3g
                • yawnsY
                  yawns Moderator
                  I never set up one of these on a raspberry, but that should work if reception is good.
                  • brobergB
                    broberg Project Sponsor
                    why not connect it to your own network first and when ready just connect it to hers ?
                    C 1 Reply Last reply
                    Reply Quote 1
                    • C
                      cianoo45 @broberg
                      Because I’m shipping it to her so i cant be there to set it up
                      brobergB aschulz90A 2 Replies Last reply
                      • brobergB
                        broberg Project Sponsor @cianoo45
                        @cianoo45 Hmm, Okey, so you want it to connect right out of the box. Then I guess a 3g/4g modem would do the trick (unless it acts up and lacks signal at her place).
                        but when configuring and assembling your mirror just use your own network to start with.
                        If I were you I would get someone to configure the wifi on the pi for her when it has arrived.
                        • aschulz90A
                          aschulz90 @cianoo45
                          @cianoo45
                          That is actually one of the use case i am covering with my app and BLE module:
                          https://forum.magicmirror.builders/topic/1497/magicmirrorapp/2
                          One of the features is, that you can connect a MagicMirror to a wifi network over bluetooth.
                          Only downside is, that there is currently only an app for Android and not for IOS or Windows Phone (i currently have neither, so can’t develop one in the near future).
