    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 80.8k Views 19 Watching
      sdetweil @Mr.Gysy
      @Mr-Gysy ok. Check the address of the pi
      sudo ifconfig
        Mr.Gysy
        sudo ipconfig
        sudo: ipconfig: Command not found
        thats not good :/
          Mr.Gysy
          ifconfig worked
          alt text
            sdetweil @Mr.Gysy
            @Mr-Gysy not ip, if
            sudo ifconfig
              Mr.Gysy
              dont work
              alt text
                sdetweil @Mr.Gysy
                @Mr-Gysy please read and copy/paste
                sudo ifconfig
                U are typing iPconfig
                Not p
                  Mr.Gysy
                  thats the screen above :)
                    sdetweil @Mr.Gysy
                    @Mr-Gysy no screen above shows 2 times the command
                    ipconfig
                    I need you to use
                    ifconfig
                    Windows system uses ipconfig
                    Linux does not
                      Mr.Gysy @Mr.Gysy
                      @Mr-Gysy said in [MMM-Remote-Control] Can not access remote control module:
                      ifconfig worked
                      alt text
                      that is “ifconfig”
                        sdetweil @Mr.Gysy
                        @Mr-Gysy ok. U have two interfaces.
                        What is address: in config.js?
                          Mr.Gysy
                          you mean this? 0.0.0.0 or?
                          alt text
                          • O Offline
                            OldSunGuy @Mr.Gysy
                            @Mr-Gysy
                            config.js has a typo
                            adresss: “0.0.0.0”,
                            should be.
                            address: “0.0.0.0”,
                              Mr.Gysy
                              @OldSunGuy said in [MMM-Remote-Control] Can not access remote control module:
                              address: “0.0.0.0”,
                              what a shit failure.
                              THANKS VERY MUCH!!!
                                sdetweil @Mr.Gysy
                                @Mr-Gysy hm … the default according to the API used is 0.0.0.0 if not specified.
                                The typo would make it not specified…
                                • O Offline
                                  OldSunGuy
                                  Isn’t the default localhost?
                                  General property option
                                  On my rpi I get the ::1 IPv6 address
                                  pi@raspberrypi ~ % getent hosts localhost
                                  ::1             localhost ip6-localhost ip6-loopback
                                  pi@raspberrypi ~ %
                                  Both IPv4 and IPv6 addresses are in my local /etc/hosts file:
                                  pi@raspberrypi ~ % grep localhost /etc/hosts
                                  127.0.0.1       localhost
                                  pi@raspberrypi ~ %
                                  • W Offline
                                    Welle05 @Mykle1
                                    @Mykle1 said in [MMM-Remote-Control] Can not access remote control module:
                                    Thank you so much, also from my side! I spent hours to look for the mistake and it was again the wrong written “address”
                                    • 4 / 4
