    Face Recognition with inferred light
    52 Posts 5 Posters 49.4k Views 4 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      Yeah, if that didn’t work around the camera, then you’ll need to add them to the frame (or in front of the mirror essentially.)
      • KirAsh4K Offline
        KirAsh4 Moderator
        Maybe something like this embedded in the frame?
        http://amzn.com/B019QTDDH2
        • F Offline
          feuerball
          Saw this too :)
          I think i will create a new frame with a larger monitor and a real mirror glas anyway so i gonna try to get more IR-Light into this.
          The only doubt i got is the power consumption… Tons of IR-Lights = Tons of W/h :D
          • KirAsh4K Offline
            KirAsh4 Moderator
            Problem solved! 80-100 METERS of illumination!
            • F Offline
              feuerball
              :D a bit too strong for a 4x1.5m corridor :D
              • KirAsh4K Offline
                KirAsh4 Moderator
                This might work though, if you’re using either an rPi camera, or something similar. If you’re going to put the camera in the frame, you’ll be drilling a hole. Why not two more for the IR lights as well. And at 3W each, that’s mighty bright. http://amzn.com/B00ZEFIU6C
                • F Offline
                  feuerball
                  hmmmm. thanks sounds like a plan.
                  I think i have to drill one larger hole, otherwise the photodiode cant see wether its dark or not hm?
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    A small hole next to the large one, enough for light to go through, should work. Usually it’s a tiny pinhole, but that’s also assuming the sensor is literally right up against the pinhole.
                    • F Offline
                      feuerball
                      so still the problem with not logging in correctly :(
                      • paviroP Offline
                        paviro Admin
                        Is there any log in the Web inspector?
                        We're all stories in the end. Just make it a good one, eh?
                        – The Doctor
                        • 6
                        • 2 / 6
