    Bullseye
    45 Posts 8 Posters 26.0k Views 9 Watching
    • BKeyportB Offline
      Installing helper tools ...
      Updating packages ...
      [     <=>        ]Check current Node installation ...
      Node.js is not installed.
      Installing Node.js ...
      chmod: cannot access '/usr/share/doc/nodejs/api/embedding.json.gz': No such file or directory
      Reading package lists... Done
      Building dependency tree... Done
      Reading state information... Done
      The following packages were automatically installed and are no longer required:
        libc-ares2 libjs-highlight.js nodejs-doc
      Use 'sudo apt autoremove' to remove them.
      The following NEW packages will be installed:
        nodejs
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 0 B/22.9 MB of archives.
      After this operation, 116 MB of additional disk space will be used.
      Selecting previously unselected package nodejs.
      (Reading database ... 99829 files and directories currently installed.)
      Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
      Unpacking nodejs (14.18.1-deb-1nodesource1) ...
      dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
       trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      node version is bash: line 227: node: command not found
      bash: line 229: node: command not found
      Node.js installation Done! version=
      Check current NPM installation ...
      NPM currently installed. Checking version number.
      /usr/bin/env: ‘node’: No such file or directory
      Minimum npm version: V6.0.0
      Installed npm version: V
      npm should be upgraded.
      Installing npm ...
      E: Unable to correct problems, you have held broken packages.
      npm installation Done! version=V
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Enumerating objects: 325, done.
      remote: Counting objects: 100% (325/325), done.
      remote: Compressing objects: 100% (290/290), done.
      remote: Total 325 (delta 53), reused 146 (delta 22), pack-reused 0
      Receiving objects: 100% (325/325), 477.94 KiB | 4.78 MiB/s, done.
      Resolving deltas: 100% (53/53), done.
      Cloning MagicMirror Done!
      touch: cannot touch '/etc/chromium-browser/customizations/01-disable-update-check': No such file or directory
      Installing dependencies ...
      log added to issue…
        sdetweil @BKeyport
        @bkeyport wonderful…
          sdetweil @BKeyport
          @bkeyport think I fixed it… give it a try, still bullseye in the urls
          • bugsounetB Offline
            bugsounet Banned @sdetweil
            @sdetweil said in Bullseye:
            @bert269 we need node 14 for MM… the bullseye is only node 12
            are you sure ?
              sdetweil @bugsounet
              @bugsounet i get v12.22.5 right after boot up, image downloaded yesterday
                sdetweil @bugsounet
                @bugsounet did u select yes to install updates during setup? I selected no… do it later
                reflashing SD card now.
                  I get on 1st boot after config, enabling ssh , and setting hostname
                  node -v
                  v12.22.5
                  cat /etc/apt/sources.list.d/nodesource.list
                  cat: /etc/apt/sources.list.d/nodesource.list: No such file or directory
                  ls /etc/apt/sources.list.d
                  raspi.list vscode.list
                    bugsounet Banned
                    curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                    can help ?
                      sdetweil @bugsounet
                      @bugsounet i got it in the latest script… different approach, but understand
                      • O Offline
                        OberfragGER @sdetweil
                        Sorry for asking but i dont get the point.
                        1 day before the release of Bullseye i installed busetr an used your script to get MM working. That worked flawless. Glad i made a backup then with my config.
                        Days later, i upgraded to Bullseye and MM was not working any longer. I thought due some autostart things or something like that.
                        When i now make a fresh bullseye install and use your script- is that working? No, or?
                          sdetweil @OberfragGER
                          @oberfragger yes, if you use the bullseye adjusted url (note the word master is replaced by bullseye i the url)
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
                          I don’t want to break the current version while we test this out…
                          I just updated the instructions with this link
                            DJBOOB66
                            Ok i tried
                            And it did not work. What I did was use the master version then rename MM folder after install then use above code and then it work?
                              sdetweil @DJBOOB66
                              @djboob66 can u post the ~/install.log?
                                DJBOOB66
                                I have to do it again but will do it as soon as i can or is log found on file and were?
                                • BKeyportB Offline
                                  @sdetweil Failed all over the place.
                                  I’ll upload install.log, then nuking card and starting over.
                                    sdetweil @BKeyport
                                    @bkeyport did u use the bullseye link ?
                                    before then if u used the old link, things get messed up w no recovery (well there is but it’s half an hour of ugly work)
                                    reflash
                                    • BKeyportB Offline
                                      @sdetweil Yes, I used the bullseye link. installing a new card now.
                                        DJBOOB66
                                        the install went without problem this time only thing did diff was i SSH not VNC will test VNC install and see if error.
                                        the only think i get is
                                        “Installing dependencies …
                                        npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforke d package instead: postcss-markdown
                                        npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older v ersions may use Math.random() in certain circumstances, which is known to be pro blematic. See https://v8.dev/blog/math-random for details.
                                        npm notice created a lockfile as package-lock.json. You should commit this file.
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^2.3.2 (node_modules/je st-haste-map/node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”} )
                                        npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta | | >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dep endencies yourself.”
                                        Do i need to fix anything??
                                        Hope this helps.
                                          sdetweil @DJBOOB66
                                          @djboob66 no, nothing to fix
                                          • BKeyportB Offline
                                            BKeyport Module Developer @BKeyport
                                            On new card it worked flawlessly. I’m assuming the old conditions of partial installs and whatnot had the old install broke things.
                                            Nothing but warnings about depreciated modules.
                                            • 2 / 3
