    3 tries 3 fails Raspberry b+
    28 Posts 7 Posters 29.4k Views 7 Watching
    • I
      infamoustiggr
      Ho gang.
      I’m having problems getting this to work on my pi b. I’ve installed raspbian, and the mirror files themselves direct, but can’t get the mirror to start! In not sure if it’s because I’m missing something, missing a step, or just plain shouldn’t be rusted with computers any more!
      Is there a tutorial that’s for the b+ knocking around? I’ve searched and can’t seem to find anything.
      Thanks! Nick
      D 1 Reply Last reply
      • I
        infamoustiggr
        Ah. Am I right in thinking the tutorial for the pi 0 will do it? Might get out of bed and have a play…
        Mykle1M 1 Reply Last reply
        • cowboysdudeC
          cowboysdude Module Developer
          Does everything install correctly?
          What do you mean you can’t get it to start? What happens?
          • I
            infamoustiggr
            I’ve followed the guide from
            http://blog.dylanjpierce.com/raspberrypi/magicmirror/tutorial/2015/12/27/build-a-magic-mirror.html
            And
            http://michaelteeuw.nl/post/83916869600/magic-mirror-part-vi-production-of-the
            And neither work I’m afraid. No error messages, nothing notes a file/programme missing, nada. Just get to the point where it should “work” and nothing happens.
            I’ll try the pi 0 tutorial and see how that goes. It’s just that I have a spare pi b and all parts, and it’s a shame I can’t get it to go…
            cowboysdudeC 1 Reply Last reply
            • cowboysdudeC
              cowboysdude Module Developer @infamoustiggr
              @infamoustiggr Well that’s because you need to do this way…
              https://github.com/MichMich/MagicMirror
              The instructions are in full and easy to follow there ;) The other places may not be up-to-date. The instructions in the link above are for this mirror exactly …
              There’s two ways:
              Automatic Installer (Raspberry Pi Only!)
              or
              Manual Installation
              Reply Quote 1
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @infamoustiggr
                @infamoustiggr
                Yup, cowboydude is absolutely right. I went with the Automatic installer on my Raspberry Pi 3
                Worked perfectly, and the directions are damn good
                Reply Quote 1
                • I
                  infamoustiggr
                  I know, but I’ve got a Pi 1 model b. Unfortunately the easy install option is unavailable…
                  I’ve got as far as the npm install, but it’s throwing up lots of error in a log file… Any hints?
                  • Mykle1M
                    @infamoustiggr
                    This is from the main installation page at https://github.com/MichMich/MagicMirror#manual-installation
                    Raspberry Pi Support
                    Electron, the app wrapper around MagicMirror², only supports the Raspberry Pi 2 & 3. The Raspberry Pi 1 is currently not supported. If you want to run this on a Raspberry Pi 1, use the server only feature and setup a fullscreen browser yourself.
                    Server Only:
                    In some cases, you want to start the application without an actual app window. In this case, execute the following command from the MagicMirror folder: node serveronly. This will start the server, after which you can open the application in your browser of choice.
                    I hope this helps
                    I 1 Reply Last reply
                    Reply Quote 1
                    • I
                      infamoustiggr @Mykle1
                      @Mykle1 ho there! I had read this bit too, but, being as I am to programming what a brick is to top flight springboard diving, I’m getting stuck on what parts of the instructions apply to me and which don’t. For example, the npm install comes up with a horrific number of errors, but I don’t know if I actually need it…
                      Once I’ve got this working I’ll write it up… I’m sure there’s a while bunch of people who bought the Pi 1 b and have since upgraded!
                      • AlvingerA
                        Alvinger
                        Hi all,
                        I’m running my mirror on an original Pi B 256MB with no issues at all!
                        The Raspbian version I use is DietPi which is really great on a 256MB Pi. Note that the standard user in DietPi is “root” rather than “pi”. If you use standard Raspbian just replace all occurences of “root” with “pi” in the scripts below.
                        As the documentation states you start off with installing the Server Only option. If I remember correctly I had to manually install many of the node module dependencies as they weren’t installed correctly otherwise
                        I use matchbox as the window manager because it suited my needs best. It uses less resources which again is great for a 256MB Pi.
                        I’m using systemd scripts rather than pm2 as I think they work better. My scripts:
                        magicmirror.service:
                        [Unit]
                        Description=Node.js Magic Mirror Server
                        [Service]
                        ExecStart=/usr/bin/node /root/MagicMirror/serveronly/index.js
                        WorkingDirectory=/root/MagicMirror
                        Restart=always
                        RestartSec=20
                        StandardOutput=syslog
                        StandardError=syslog
                        SyslogIdentifier=nodejs-magicmirror
                        Environment=NODE_ENV=production PORT=1337
                        [Install]
                        WantedBy=multi-user.target
                        matchbox.service:
                        [Unit]
                        Description=X11
                        After=X.service
                        [Service]
                        Environment=DISPLAY=:0.0
                        ExecStart=/usr/bin/matchbox-window-manager -use_titlebar no -use_cursor no
                        User=root
                        Restart=on-failure
                        [Install]
                        Kioskbrowser.service:
                        [Unit]
                        Description=Kiosk Browser
                        After=matchbox.service magicmirror.service
                        Requires=magicmirror.service
                        [Service]
                        User=root
                        # Don't activate screensaver
                        ExecStartPre=/usr/bin/xset s off
                        # Disable DPMS (Energy Star) features
                        ExecStartPre=/usr/bin/xset -dpms
                        # Don't blank the video device
                        ExecStartPre=/usr/bin/xset s noblank
                        ExecStart=/root/kioskbrowser http://localhost
                        Restart=on-failure
                        [Install]
                        Note that the kioskbrowser service relies on a user script called /root/kioskbrowser. This script has some extra logic to avoid the initial white screen when midori has loaded but not fetched any magic mirror content. The script perform a curl call to see if the magic mirror module is responding. If not it waits for a few seconds and then tries again. Once the magic mirror responds it starts midori in fullscreen mode.
                        /root/kioskbrowser:
                        #!/bin/bash
                        status=1
                        url="$1"
                        wait="10s"
                        tries=0
                        # URL must be first argument
                        if [ -z "$url" ]; then
                          exit 1
                        fi
                        # Make sure that the url is reachable
                        while [ $status -ne 0 ]; do
                          let tries++
                          curl --fail --progress-bar -o /dev/null --url "$url"
                          status=$?
                          if (($tries > 10)); then
                            wait="30s"
                          fi
                          if (($tries > 20)); then
                          wait="5m"
                          fi
                          if (($tries > 30)); then
                          echo "$0: Can't load URL $url"
                            exit 2
                          fi
                          sleep "$wait"
                        done
                        # Start browser in fullscreen mode
                        /usr/bin/midori -e Fullscreen -a "$url"
                        Hope this helps.
                        Reply Quote 2
                        • I
                          infamoustiggr
                          Hi Alvinger,
                          That sounds exactly what I need thanks, with the only problem being that, being a complete learner, I don’t know what to do with it…
                          Do I need to put the scripts into a particular file or just write them into the command line itself?
                          On the whole I’ve managed most projects independently thanks to the mighty google and suitable search terms, got my media centre and a pi in my van as a music/film hub, but this is the first thing that’s been a bit more complicated and I’ve failed miserably to this point…
                          I’ve been trying to learn this sort of thing for years and just never seem to have the time. I’m a physio by trade, so I don’t even have something close to this as my day job.
                          Thanks for your patience!
                          Nick
                          AlvingerA 1 Reply Last reply
                          • AlvingerA
                            Alvinger @infamoustiggr
                            @infamoustiggr,
                            Installed packages
                            If you are running dietpi or Raspbian Jessie systemd should already be installed. Otherwise you need to install and enable it. Google is your friend.
                            Midori should also be installed but Matchbox most likely isn’t. Install it with:
                            sudo apt-get install matchbox-window-manager
                            Systemd
                            The systemd scripts are all located in /etc/systemd/system. To create magicmirror.service enter the following command (I’m using the editor nano):
                            sudo nano /etc/systemd/system/magicmirror.service
                            Paste script from above and edit to suit your needs.
                            Make the script executable with the following command:
                            sudo chmod +x /etc/systemd/system/magicmirror.service
                            Repeat these steps for the other scripts by replacing magicmirror.service with the appropriate name.
                            Custom script
                            For DietPi the scripts are located in /root and for Raspbian they are located in /home/pi. Change to the appropriate directory with cd.
                            nano kioskbrowser
                            Paste the code from above and save/exit
                            Make the script executable by running:
                            chmod +x kioskbrowser
                            MagicMirror config
                            Make sure that MagicMirror has the correct port set in config.js. (Look for “port”: in config/config.js and make sure it is set to 80. Otherwise modify kioskbrowser.service and change the url http://localhost to http://localhost:port where port is the port number of MagicMirror.)
                            Scheduled on/off times
                            If you’re like me and do not want your mirror active during the night you can either use a module such as MMM-ModuleScheduler or a cron script that turns the monitor power on/off at set times. I use the latter. To do that you enter the command:
                            crontab -e
                            and paste the following lines
                            59 05 * * *     /usr/bin/vcgencmd display_power 1
                            09 23 * * *     /usr/bin/vcgencmd display_power 0
                            Exit and save.
                            The first line turns the monitor ON at 05:59 and the second line turns if OFF at 23:09. Modify according to needs.
                            Reboot your pi and enjoy!
                            Reply Quote 1
                            • I
                              infamoustiggr
                              That is honestly amazing that you would take the time. Thanks!
                              • AlvingerA
                                @infamoustiggr, thanks!
                                Just make sure sure to pay it forward if you have the opportuniy to help someone else here in the forums.
                                Reply Quote 4
                                • I
                                  infamoustiggr @Alvinger
                                  @Alvinger Really sorry! I’ve swapped to dietpi on fresh install and then follows your fine instructions a few times, clean install x3 at least, but keep getting same error:
                                  Xinit: giving up
                                  Xinit: unable to connect to X server: connection refused
                                  Xinit: server error
                                  Then it dumps me to the command line…
                                  Any idea how I’ve screwed up your fine instructions?
                                  Ta!
                                  Nick
                                  johnnyboyJ 1 Reply Last reply
                                  • johnnyboyJ
                                    johnnyboy @infamoustiggr
                                    This post is deleted!
                                    • AlvingerA
                                      Alvinger @johnnyboy
                                      @johnnyboy
                                      Of course you could always buy a Pi 3 and not worry, but what’s the fun in that? It’s much more rewarding to make it run on a Pi 1! :-)
                                      @infamoustiggr
                                      The first rule of troubleshopting is to eliminate all things that ARE working! What’s left must be the error.
                                      I would start with running all commands from the shell, i.e. do not create the systemd scripts, rather run the respective commands from the shell bybtyping them in, that way you will get feedback from each command.
                                      The error messages you post do not have any context so it’s hard to know when they occur. From where did you cut the errors?
                                      When installing raspbian or dietpi you should NOT install X or any desktop environment, the relevant packages will be installed when you install the other components.
                                      • johnnyboyJ
                                        johnnyboy @Alvinger
                                        • AlvingerA
                                          Alvinger @johnnyboy
                                          @johnnyboy
                                          That’s technology development for you. Of course, in this case @infamoustiggr has the luxury of having someone with the exact same equipment already having the solution running.
                                          As to the speed issue, apart from taking a few extra seconds on boot, I have no issues whatsoever with speed for functionality on my Pi 1. But I must admit it took me a number of tries to get there! Doing it with little to no experience with Linux is really tough.
                                          Reply Quote 1
                                          • I
                                            I would go for the pi3 option, but it goes against my eco principles! Spare computer must have a job somewhere!
                                            Thanks, I’ll try one line at a time and see how things go! Just out of interest though, how much fiddling did it take you? And how did you know the nodes hadn’t downloaded properly?
