    NPM run start cannot be used
    44 Posts 4 Posters 19.5k Views 4 Watching
    • 史 Offline
      史新瑞 @sdetweil
      @sdetweil I mean only the weather API, that is, the key of your openweather. I will come back to you for advice in nine hours, that is, around 8:00 p.m. us time. I hope you have time, and I hope you don’t hate me. Thank you again. I wish you good health and good luck. I’ll be with you all the time
        sdetweil @史新瑞
        @史新瑞 no opinion of you. just working on problems. many new users come and we work thru things…
        see u later
        史 1 Reply Last reply Reply Quote 0
        • 史 Offline
          史新瑞 @sdetweil
          Good evening. I just woke up
          /* MagicMirror² Config Sample
          * By Michael Teeuw https://michaelteeuw.nl
          * MIT Licensed.
          * see https://docs.magicmirror.builders/configuration/introduction.html
          * and https://docs.magicmirror.builders/modules/configuration.html
          let config = {
             address: "localhost", 	// Address to listen on, can be:
             port: 8080,
             basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
             ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
             language: "zh-cn",
             locale: "zh",
             timeFormat: 24,
             units: "metric",
             		module: "alert",
             		module: "updatenotification",
             		position: "top_bar"
             		module: "clock",
             		position: "top_left"
             		header: "US Holidays",
             					symbol: "calendar-check",
             					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
             //		module: "compliments",
             //		position: "lower_third"
             	module: "weather",
             		weatherProvider:"weatherbit",
             		weatherEndpoint:"/current/forecast/daily",
             		apiKey:"aa03f670e4944ac3a086f92482a5e25e",
             		lat:"40.5",
             		lon:"116.5",
             		showSun:"true",
             		colored:"true",
             		maxNumberOfDays:"5"
             	/*  显示图片
             			module: "MMM-ImagesPhotos",
             			position: "middle_center",
             				opacity: 0.5,
             				animationSpeed: 1000,
             				updateInterval: 5000,
             				maxWidth:"500px",
             				maxHeight:"200px",
             				backgroundColor: 'grey',  // not used if fill is true
             				fill: false,   // fill around image with blurred copy of image
             				blur: 10,   // only used if fill is true
             	module: "helloworld",
             	position: "bottom_bar",	// This can be any of the regions.
             		text: "Hi! May I help you?"
          	module: 'MMM-SimpleText',
          	position: 'bottom_right',
             		fontURL: {
             		  'value': 'Tahoma, Geneva, sans-serif'
             		fontSize: {
             		  'value': 'small'
             		fontStyle: {
             		  'value': 'italic'
             		color: {
             		  'value': '#FFFFFF'
             		refreshMs: {
             		  'value': '10000'
             		filePath: {
             		  'value': '123.txt'
            sdetweil @史新瑞
            @史新瑞 remove the weatherEndpoint
            add
            type:'current'
            • 史 Offline
              史新瑞 @sdetweil
              Is that so?
                sdetweil @史新瑞
                @史新瑞 no. in the weather config… that is the issue we are working on
                make it look like mine, use your apikey
                and your provider
                https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used/14?_=1660526689873
                • 史 Offline
                  史新瑞 @sdetweil
                  The first or the second?
                    sdetweil @史新瑞
                    @史新瑞 either, both, whatever
                    just trying to get it to work
                    • 史 Offline
                      史新瑞 @sdetweil
                      @sdetweil Different weather configurations should be configured in different ways。https://docs.magicmirror.builders/modules/weather.html#configuration-options
                      The way I learned from here
                        sdetweil @史新瑞
                        @史新瑞 there are two options current weather and forecast
                        the new module eliminates having to use a lot of parms…
                        just try it my way, for a test
                        • 史 Offline
                          史新瑞 @sdetweil
                          @sdetweil I tried it just now, but it didn’t work. It will always show that it is loading
                            sdetweil @史新瑞
                            @史新瑞 ‘loading’ is the default message, until some data arrives.
                            can u show me what you did
                            • 史 Offline
                              史新瑞 @sdetweil
                              			module: "weather",
                              				type: "current",
                              				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                              				apiKey: "???"
                              			module: "weather",
                              			header: "Weather Forecast",
                              				type: "forecast",
                              				apiKey: "???"
                                sdetweil @史新瑞
                                @史新瑞
                                just the weather config
                                ok, this module is stupid… requires parms, but then doesn’t use them…
                                			module: "weather",
                                				updateInterval: 15*1000,
                                				initialLoadDelay: 2,
                                				weatherProvider: "weatherbit",
                                				weatherEndpoint:"/forecast/daily",
                                				type: "forecast",
                                				lat: 30.4548443,
                                				lon: -97.6222674,
                                				apiKey: "67f41759a9c74d8a917ac984155286f0",
                                also, forecast has a long old bug , make sure to set
                                and a short interval for testing
                                you can use this apikey… I will kill it in an hour or so…
                                I opened this issue
                                https://github.com/MichMich/MagicMirror/issues/2899
                                type: current (default) worked on with my apikey
                                • 史 Offline
                                  史新瑞 @sdetweil
                                  1.png Using NPM run start will:
                                    sdetweil @史新瑞
                                    @史新瑞 open the developers window.
                                    ctrl-shift-i on the keyboard
                                    select the console tab and enter weath
                                    in the filter field
                                    • 史 Offline
                                      史新瑞 @sdetweil
                                      @sdetweil I don’t know how to open the developer window.
                                        sdetweil @史新瑞
                                        @史新瑞 I just told you how
                                        • 史 Offline
                                          史新瑞 @sdetweil
                                          @sdetweil I pressed ctrl-shift-i, but the raspberry pie didn’t respond
                                            sdetweil @史新瑞
                                            @史新瑞 on the pi keyboard, right?
                                            all keys at once
                                            with MagicMirror on the screen
                                            • 2 / 3
