    Bad question
    64 Posts 5 Posters 63.9k Views 4 Watching
    • F Offline
      Fonfon @Mykle1
      This post is deleted!
      • F Offline
        Fonfon
        Ok i try to the change clock
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
        	language: 'en',
        	timeFormat: 24,
        	units: 'metric',
        			module: 'alert',
        			module: "updatenotification",
        			position: "top_bar"
        			module: 'clock',
        			position: 'top_left'
        				timezone: 'france/paris'
        			module: 'calendar',
        			header: 'US Holidays',
        			position: 'top_left',
        						symbol: 'calendar-check-o ',
        						url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
        			module: 'compliments',
        			position: 'lower_third'
        			module: 'currentweather',
        			position: 'top_right',
        				locationID: '',  //ID from http://www.openweathermap.org
        				appid: 'YOUR_OPENWEATHER_API_KEY'
        			module: 'weatherforecast',
        			header: 'Weather Forecast',
        				locationID: '5128581',  //ID from http://www.openweathermap.org
        			module: 'newsfeed',
        			position: 'bottom_bar',
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true
        is it the great form ?
          Mykle1 Project Sponsor Module Developer @Fonfon
          @Fonfon I think it should be ‘France/Paris’ with capitals, and a comma after ‘top_left’,
          Also, I think that if you leave the default at ‘none’ it will use your system clock
          module : ‘clock’,
          position : 'top_left’,
          timezone: ‘France/Paris’
          timezone Specific a timezone to show clock.
          Possible examples values: America/New_York, America/Santiago, Etc/GMT+10
          Default value: none
          • F Offline
            Fonfon
            That’s right capitals and comma needed
            you are the boss thanks !!
              @Fonfon said in Bad question:
              Just trying to be helpful. You’re welcome :thumbsup:
              • cowboysdudeC Offline
                cowboysdude Module Developer
                @Fonfon
                Just a suggestion that I give all new people… before you make changes to a working config.js make a copy of it… that way if you can’t figure out or you need something to compare it to you have your backup :)
                  Mykle1 Project Sponsor Module Developer @cowboysdude
                  @cowboysdude said in Bad question:
                  Excellent advice, and I agree. We were just trying to get him a working config.js in the first place
                  • F Offline
                    Fonfon
                    Is it necessary to rename the config.js to config.js.sample every time you want to modify it?
                    Or is there a simpler manipulation.
                    yes now i do this !! i have a copy of my config.js ;)
                      @Fonfon - No, you don’t have to rename your config.js file to edit it but you might want to back it up BEFORE you edit it. This way, if anything goes wrong you’re safe
                      F 1 Reply Last reply Reply Quote 1
                      • F Offline
                        Fonfon @Mykle1
                        @Mykle1 for sure i understand how i can do for editing file without rename it ?
                        • 6
                        • 7
                        • 5 / 7
