    Bad question
    64 Posts 5 Posters 72.0k Views 4 Watching
    • F
      Fonfon
      yes he’s inside the folder
      he don’t work…
      • cowboysdudeC
        To save yourself time and double check do this…
        go to your MagicMirror/config directory
        type in terminal window:
        cp config.js.sample config.js
        Then restart your mirror… lets make sure it’s working first :)
        • F
          Fonfon
          it’s ok !! now i have the starting config file
          thanks !!!
          Mykle1M 2 Replies Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Fonfon
            @Fonfon I got him going bro. See? I can do things! (Godfather reference)
            • Mykle1M
              @Fonfon said in Bad question:
              thanks
              You’re welcome :thumbsup:
              F 1 Reply Last reply
              • F
                Fonfon @Mykle1
                • F
                  Fonfon
                  Ok i try to the change clock
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: 'en',
                  	timeFormat: 24,
                  	units: 'metric',
                  			module: 'alert',
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: 'clock',
                  			position: 'top_left'
                  				timezone: 'france/paris'
                  			module: 'calendar',
                  			header: 'US Holidays',
                  			position: 'top_left',
                  						symbol: 'calendar-check-o ',
                  			module: 'compliments',
                  			position: 'lower_third'
                  			module: 'currentweather',
                  			position: 'top_right',
                  				locationID: '',  //ID from http://www.openweathermap.org
                  				appid: 'YOUR_OPENWEATHER_API_KEY'
                  			module: 'weatherforecast',
                  			header: 'Weather Forecast',
                  				locationID: '5128581',  //ID from http://www.openweathermap.org
                  			module: 'newsfeed',
                  			position: 'bottom_bar',
                  				feeds: [
                  						title: "New York Times",
                  				showSourceTitle: true,
                  				showPublishDate: true
                  is it the great form ?
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    @Fonfon I think it should be ‘France/Paris’ with capitals, and a comma after ‘top_left’,
                    Also, I think that if you leave the default at ‘none’ it will use your system clock
                    module : ‘clock’,
                    position : 'top_left’,
                    timezone: ‘France/Paris’
                    timezone Specific a timezone to show clock.
                    Possible examples values: America/New_York, America/Santiago, Etc/GMT+10
                    Default value: none
                    • F
                      Fonfon
                      That’s right capitals and comma needed
                      you are the boss thanks !!
                      • Mykle1M
                        Just trying to be helpful. You’re welcome :thumbsup:
                        • cowboysdudeC
                          @Fonfon
                          Just a suggestion that I give all new people… before you make changes to a working config.js make a copy of it… that way if you can’t figure out or you need something to compare it to you have your backup :)
                          • Mykle1M
                            @cowboysdude said in Bad question:
                            Excellent advice, and I agree. We were just trying to get him a working config.js in the first place
                            • F
                              Fonfon
                              Is it necessary to rename the config.js to config.js.sample every time you want to modify it?
                              Or is there a simpler manipulation.
                              yes now i do this !! i have a copy of my config.js ;)
                              • Mykle1M
                                @Fonfon - No, you don’t have to rename your config.js file to edit it but you might want to back it up BEFORE you edit it. This way, if anything goes wrong you’re safe
                                • F
                                  Fonfon @Mykle1
                                  @Mykle1 for sure i understand how i can do for editing file without rename it ?
                                  • Mykle1M
                                    @Fonfon – Double click your config.js file. It will open. Do your editing, then choose Save from the File menu
                                    • F
                                      Fonfon @Mykle1
                                      @Mykle1 I will end up owing you a bottle of wine ;)
                                      • Mykle1M
                                        @Fonfon - Nah, just trying to help you like people helped me.
                                        • F
                                          Fonfon
                                          ARfff now problem with MMMGlobe
                                          i don’t have earth but i have 3 lines…
                                          can you help me please…
                                          • F
                                            Fonfon @Fonfon
                                            @Fonfon sorry it’s ok
                                            module: ‘MMM-Globe’,
                                            position: ‘center’,
                                            style: ‘geocolor’,
                                            imageSize: 600,
                                            ownImagePath:‘’,
                                            updateInterval: 10601000
                                            ‘style geocolor’ does not ok
                                            i try another one ans it’s ok !!
                                            • 3 / 4
