    Bad question
    64 Posts 5 Posters 72.0k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Fonfon
      @Fonfon said in Bad question:
      That’s right capitals and comma needed
      you are the boss thanks !!
      Just trying to be helpful. You’re welcome :thumbsup:
      • cowboysdudeC
        @Fonfon
        Just a suggestion that I give all new people… before you make changes to a working config.js make a copy of it… that way if you can’t figure out or you need something to compare it to you have your backup :)
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @cowboysdude said in Bad question:
          Excellent advice, and I agree. We were just trying to get him a working config.js in the first place
          • F
            Fonfon
            Is it necessary to rename the config.js to config.js.sample every time you want to modify it?
            Or is there a simpler manipulation.
            yes now i do this !! i have a copy of my config.js ;)
            • Mykle1M
              @Fonfon - No, you don’t have to rename your config.js file to edit it but you might want to back it up BEFORE you edit it. This way, if anything goes wrong you’re safe
              F 1 Reply Last reply
              • F
                Fonfon @Mykle1
                @Mykle1 for sure i understand how i can do for editing file without rename it ?
                • Mykle1M
                  @Fonfon – Double click your config.js file. It will open. Do your editing, then choose Save from the File menu
                  • F
                    Fonfon @Mykle1
                    @Mykle1 I will end up owing you a bottle of wine ;)
                    • Mykle1M
                      @Fonfon - Nah, just trying to help you like people helped me.
                      • F
                        Fonfon
                        ARfff now problem with MMMGlobe
                        i don’t have earth but i have 3 lines…
                        can you help me please…
                        • F
                          Fonfon @Fonfon
                          @Fonfon sorry it’s ok
                          module: ‘MMM-Globe’,
                          position: ‘center’,
                          style: ‘geocolor’,
                          imageSize: 600,
                          ownImagePath:‘’,
                          updateInterval: 10601000
                          ‘style geocolor’ does not ok
                          i try another one ans it’s ok !!
                          • cowboysdudeC
                            cowboysdude Module Developer @Fonfon
                            Try this… :)
                             module: 'MMM-Globe',
                             		position: 'center',
                            			style: 'geocolor',
                            			imageSize: 600,
                             			updateInterval: 10*60*1000
                            • F
                              Fonfon
                              On github when someone say:
                              Execute npm install to install the node dependencies.
                              I don’t understand that can you explain to me please.
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @Fonfon
                                @Fonfon open a terminal and change directory cd ~/MagicMirror/modules/MMM-Globe then npm install
                                • F
                                  Fonfon @strawberry 3.141
                                  @strawberry-3.141 so simply thanks…
                                  • F
                                    Fonfon
                                    Hi !
                                    i have a 16/9 screen and i’d like to turn it a 90° is it possible to turn the view at 90° ???
                                    thanks.
                                    brobergB 1 Reply Last reply
                                    • brobergB
                                      broberg Project Sponsor @Fonfon
                                      @Fonfon Yes, how to is described in the MM documentation on how to set up your MagicMirror :
                                      https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
                                      • F
                                        Fonfon
                                        i didn’t find it ! thanks :)
                                        • F
                                          Fonfon
                                          hello
                                          i edit that: sudo nano /boot/config.txt
                                          where i add the line:
                                          display-rotate=1
                                          under frame ? hdmi ??
                                          because when i save and reboot no rotating
                                          thanks.
                                          • F
                                            Fonfon @Fonfon
                                            @Fonfon ok i find after 2 hours :)
                                            at the end bottom
                                            after
                                            crtl x
                                            y
                                            enter
                                            sudo reboot
                                            rotate_display=1 90°
                                            rotate_display= 3 270°
                                            • 3 / 4
