    Bad question
    64 Posts 5 Posters 72.0k Views 4 Watching
    • F
      Fonfon
      Ok i try to the change clock
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: 'en',
      	timeFormat: 24,
      	units: 'metric',
      			module: 'alert',
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'clock',
      			position: 'top_left'
      				timezone: 'france/paris'
      			module: 'calendar',
      			header: 'US Holidays',
      			position: 'top_left',
      						symbol: 'calendar-check-o ',
      			module: 'compliments',
      			position: 'lower_third'
      			module: 'currentweather',
      			position: 'top_right',
      				locationID: '',  //ID from http://www.openweathermap.org
      				appid: 'YOUR_OPENWEATHER_API_KEY'
      			module: 'weatherforecast',
      			header: 'Weather Forecast',
      				locationID: '5128581',  //ID from http://www.openweathermap.org
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      is it the great form ?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Fonfon
        @Fonfon I think it should be ‘France/Paris’ with capitals, and a comma after ‘top_left’,
        Also, I think that if you leave the default at ‘none’ it will use your system clock
        module : ‘clock’,
        position : 'top_left’,
        timezone: ‘France/Paris’
        timezone Specific a timezone to show clock.
        Possible examples values: America/New_York, America/Santiago, Etc/GMT+10
        Default value: none
        • F
          Fonfon
          That’s right capitals and comma needed
          you are the boss thanks !!
          • Mykle1M
            @Fonfon said in Bad question:
            Just trying to be helpful. You’re welcome :thumbsup:
            • cowboysdudeC
              @Fonfon
              Just a suggestion that I give all new people… before you make changes to a working config.js make a copy of it… that way if you can’t figure out or you need something to compare it to you have your backup :)
              • Mykle1M
                @cowboysdude said in Bad question:
                Excellent advice, and I agree. We were just trying to get him a working config.js in the first place
                • F
                  Fonfon
                  Is it necessary to rename the config.js to config.js.sample every time you want to modify it?
                  Or is there a simpler manipulation.
                  yes now i do this !! i have a copy of my config.js ;)
                  • Mykle1M
                    @Fonfon - No, you don’t have to rename your config.js file to edit it but you might want to back it up BEFORE you edit it. This way, if anything goes wrong you’re safe
                    F 1 Reply Last reply
                    • F
                      Fonfon @Mykle1
                      @Mykle1 for sure i understand how i can do for editing file without rename it ?
                      • Mykle1M
                        @Fonfon – Double click your config.js file. It will open. Do your editing, then choose Save from the File menu
                        • F
                          Fonfon @Mykle1
                          @Mykle1 I will end up owing you a bottle of wine ;)
                          • Mykle1M
                            @Fonfon - Nah, just trying to help you like people helped me.
                            • F
                              Fonfon
                              ARfff now problem with MMMGlobe
                              i don’t have earth but i have 3 lines…
                              can you help me please…
                              • F
                                Fonfon @Fonfon
                                @Fonfon sorry it’s ok
                                module: ‘MMM-Globe’,
                                position: ‘center’,
                                style: ‘geocolor’,
                                imageSize: 600,
                                ownImagePath:‘’,
                                updateInterval: 10601000
                                ‘style geocolor’ does not ok
                                i try another one ans it’s ok !!
                                • cowboysdudeC
                                  cowboysdude Module Developer @Fonfon
                                  Try this… :)
                                   module: 'MMM-Globe',
                                   		position: 'center',
                                  			style: 'geocolor',
                                  			imageSize: 600,
                                   			updateInterval: 10*60*1000
                                  • F
                                    Fonfon
                                    On github when someone say:
                                    Execute npm install to install the node dependencies.
                                    I don’t understand that can you explain to me please.
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @Fonfon
                                      @Fonfon open a terminal and change directory cd ~/MagicMirror/modules/MMM-Globe then npm install
                                      • F
                                        Fonfon @strawberry 3.141
                                        @strawberry-3.141 so simply thanks…
                                        • F
                                          Fonfon
                                          Hi !
                                          i have a 16/9 screen and i’d like to turn it a 90° is it possible to turn the view at 90° ???
                                          thanks.
                                          brobergB 1 Reply Last reply
                                          • brobergB
                                            broberg Project Sponsor @Fonfon
                                            @Fonfon Yes, how to is described in the MM documentation on how to set up your MagicMirror :
                                            https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
                                            • 3 / 4
