    Bad question
    64 Posts 5 Posters 72.0k Views 4 Watching
    • F
      Fonfon
      ok i understand my another problem is with the whitelist but i try to solve 1 problem after 1 problem
      thank mykle1
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Fonfon
        @Fonfon yup, one thing at a time. Lets get your config.js working first
        F 1 Reply Last reply
        • F
          Fonfon @Mykle1
          @Mykle1 can you give me the original config file please
          • Mykle1M
            @Fonfon ok, one sec
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Mykle1
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: 'en',
              	timeFormat: 24,
              	units: 'metric',
              			module: 'alert',
              			module: "updatenotification",
              			position: "top_bar"
              			module: 'clock',
              			position: 'top_left'
              			module: 'calendar',
              			header: 'US Holidays',
              			position: 'top_left',
              						symbol: 'calendar-check-o ',
              			module: 'compliments',
              			position: 'lower_third'
              			module: 'currentweather',
              			position: 'top_right',
              				locationID: 'GOES HERE',  //ID from http://www.openweathermap.org
              				appid: 'YOUR_OPENWEATHER_API_KEY'
              			module: 'weatherforecast',
              			header: 'Weather Forecast',
              			module: 'newsfeed',
              			position: 'bottom_bar',
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true
              • Mykle1M
                Copy the entire message
                • F
                  Fonfon
                  thanks mikle i copied the entire message i paste it
                  rename my config file like config.js
                  go to command
                  npm start
                  allways the message in a black screen
                  please create a config file
                  magic mirror2
                  see readme for more information…
                  • Mykle1M
                    @Fonfon your config.js file that you just pasted the code into is inside your config folder, yes?
                    • F
                      Fonfon
                      yes but i think the copie/pasted is not correct i re-try
                      • F
                        Fonfon
                        yes he’s inside the folder
                        he don’t work…
                        • cowboysdudeC
                          To save yourself time and double check do this…
                          go to your MagicMirror/config directory
                          type in terminal window:
                          cp config.js.sample config.js
                          Then restart your mirror… lets make sure it’s working first :)
                          • F
                            Fonfon
                            it’s ok !! now i have the starting config file
                            thanks !!!
                            Mykle1M 2 Replies Last reply
                            • Mykle1M
                              @Fonfon I got him going bro. See? I can do things! (Godfather reference)
                              • Mykle1M
                                @Fonfon said in Bad question:
                                thanks
                                You’re welcome :thumbsup:
                                • F
                                  Fonfon @Mykle1
                                  • F
                                    Fonfon
                                    Ok i try to the change clock
                                     * MIT Licensed.
                                    var config = {
                                    	port: 8080,
                                    	language: 'en',
                                    	timeFormat: 24,
                                    	units: 'metric',
                                    			module: 'alert',
                                    			position: "top_bar"
                                    			module: 'clock',
                                    				timezone: 'france/paris'
                                    			module: 'calendar',
                                    				locationID: '',  //ID from http://www.openweathermap.org
                                    				locationID: '5128581',  //ID from http://www.openweathermap.org
                                    			module: 'newsfeed',
                                    				feeds: [
                                    is it the great form ?
                                    • Mykle1M
                                      @Fonfon I think it should be ‘France/Paris’ with capitals, and a comma after ‘top_left’,
                                      Also, I think that if you leave the default at ‘none’ it will use your system clock
                                      module : ‘clock’,
                                      position : 'top_left’,
                                      timezone: ‘France/Paris’
                                      timezone Specific a timezone to show clock.
                                      Possible examples values: America/New_York, America/Santiago, Etc/GMT+10
                                      Default value: none
                                      • F
                                        Fonfon
                                        That’s right capitals and comma needed
                                        you are the boss thanks !!
                                        • Mykle1M
                                          Just trying to be helpful. You’re welcome :thumbsup:
                                          • cowboysdudeC
                                            @Fonfon
                                            Just a suggestion that I give all new people… before you make changes to a working config.js make a copy of it… that way if you can’t figure out or you need something to compare it to you have your backup :)
                                            • 2 / 4
