    Bad question
    64 Posts 5 Posters 71.3k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Fonfon
      @Fonfon yup, one thing at a time. Lets get your config.js working first
      F 1 Reply Last reply
      • F
        Fonfon @Mykle1
        @Mykle1 can you give me the original config file please
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @Fonfon ok, one sec
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Mykle1
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: 'en',
            	timeFormat: 24,
            	units: 'metric',
            			module: 'alert',
            			module: "updatenotification",
            			position: "top_bar"
            			module: 'clock',
            			position: 'top_left'
            			module: 'calendar',
            			header: 'US Holidays',
            			position: 'top_left',
            						symbol: 'calendar-check-o ',
            			module: 'compliments',
            			position: 'lower_third'
            			module: 'currentweather',
            			position: 'top_right',
            				locationID: 'GOES HERE',  //ID from http://www.openweathermap.org
            				appid: 'YOUR_OPENWEATHER_API_KEY'
            			module: 'weatherforecast',
            			header: 'Weather Forecast',
            			module: 'newsfeed',
            			position: 'bottom_bar',
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            • Mykle1M
              Copy the entire message
              • F
                Fonfon
                thanks mikle i copied the entire message i paste it
                rename my config file like config.js
                go to command
                npm start
                allways the message in a black screen
                please create a config file
                magic mirror2
                see readme for more information…
                • Mykle1M
                  @Fonfon your config.js file that you just pasted the code into is inside your config folder, yes?
                  • F
                    Fonfon
                    yes but i think the copie/pasted is not correct i re-try
                    • F
                      Fonfon
                      yes he’s inside the folder
                      he don’t work…
                      • cowboysdudeC
                        To save yourself time and double check do this…
                        go to your MagicMirror/config directory
                        type in terminal window:
                        cp config.js.sample config.js
                        Then restart your mirror… lets make sure it’s working first :)
                        • F
                          Fonfon
                          it’s ok !! now i have the starting config file
                          thanks !!!
                          Mykle1M 2 Replies Last reply
                          • Mykle1M
                            @Fonfon I got him going bro. See? I can do things! (Godfather reference)
                            • Mykle1M
                              @Fonfon said in Bad question:
                              thanks
                              You’re welcome :thumbsup:
                              • F
                                Fonfon @Mykle1
                                • F
                                  Fonfon
                                  Ok i try to the change clock
                                   * MIT Licensed.
                                  var config = {
                                  	port: 8080,
                                  	language: 'en',
                                  	timeFormat: 24,
                                  	units: 'metric',
                                  			module: 'alert',
                                  			position: "top_bar"
                                  			module: 'clock',
                                  				timezone: 'france/paris'
                                  			module: 'calendar',
                                  				locationID: '',  //ID from http://www.openweathermap.org
                                  				locationID: '5128581',  //ID from http://www.openweathermap.org
                                  			module: 'newsfeed',
                                  				feeds: [
                                  is it the great form ?
                                  • Mykle1M
                                    @Fonfon I think it should be ‘France/Paris’ with capitals, and a comma after ‘top_left’,
                                    Also, I think that if you leave the default at ‘none’ it will use your system clock
                                    module : ‘clock’,
                                    position : 'top_left’,
                                    timezone: ‘France/Paris’
                                    timezone Specific a timezone to show clock.
                                    Possible examples values: America/New_York, America/Santiago, Etc/GMT+10
                                    Default value: none
                                    • F
                                      Fonfon
                                      That’s right capitals and comma needed
                                      you are the boss thanks !!
                                      • Mykle1M
                                        Just trying to be helpful. You’re welcome :thumbsup:
                                        • cowboysdudeC
                                          @Fonfon
                                          Just a suggestion that I give all new people… before you make changes to a working config.js make a copy of it… that way if you can’t figure out or you need something to compare it to you have your backup :)
                                          • Mykle1M
                                            @cowboysdude said in Bad question:
                                            Excellent advice, and I agree. We were just trying to get him a working config.js in the first place
                                            • 2 / 4
