    Bad question
    64 Posts 5 Posters 70.2k Views 4 Watching
    • F Offline
      Fonfon
      ok ok i understand thanks strawberry-3-141
      • F Offline
        Fonfon
        Help me please
         ERR! Linux 4.4.34-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        npm ERR! node v6.9.5
        npm ERR! npm  v3.10.10
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is most likely not a problem with npm itself
        npm ERR! enoent and is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/npm-debug.log
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Fonfon
          @Fonfon you are in the wrong directory cd ~/MagicMirror
          • F Offline
            Fonfon
            for sure i’m so confuse !
            • F Offline
              Fonfon
              Another one !! ;)
              WARNING! Could not find config file. Please create one. Starting with default configuration.
              why he say that ?
              thanks
                Mykle1 Project Sponsor Module Developer @Fonfon
                @Fonfon
                Your config was working and now it’s not? If you just added something to a working config then that’s probably the culprit. Post your config here so we can have a look at it
                • F Offline
                  Fonfon
                  /* Magic Mirror Config Sample
                  • MIT Licensed.
                  var config = {
                  port: 8080,
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.1/24”],
                  language: 'fr',
                  timeFormat: 24,
                  units: 'metric',
                  		module: 'alert',
                  		module: "updatenotification",
                  		position: "top_bar"
                  		module: 'calendar',
                  		header: 'US Holidays',
                  		position: 'top_left',
                  					symbol: 'calendar-check-o ',
                  		module: 'compliments',
                  		position: 'lower_third'
                  		module: 'currentweather',
                  		position: 'top_right',
                  			locationID: '',  //ID from http://www.openweathermap.org
                  			appid: 'YOUR_OPENWEATHER_API_KEY'
                  		module: 'weatherforecast',
                  		header: 'Weather Forecast',
                  			locationID: '5128581',  //ID from http://www.openweathermap.org
                  		module: 'newsfeed',
                  		position: 'bottom_bar',
                  			feeds: [
                  					title: "New York Times",
                  			showSourceTitle: true,
                  			showPublishDate: true
                  if (typeof module !== ‘undefined’) {module.exports = config;}
                      @Fonfon
                      the 2nd { in the calendar module should be deleted for starters
                        Mykle1 Project Sponsor Module Developer @Mykle1
                        Like this
                        	module: 'calendar',
                        • F Offline
                          Fonfon
                          Can you give me a correct config file for starting or where i can find it ?
                          F Mykle1M 2 Replies Last reply Reply Quote 0
                          • F Offline
                            Fonfon @Fonfon
                            @Fonfon and when i start npm , my config file name is config.js or config.js.sample ?
                              @Fonfon said in Bad question:
                              Well, that one should work if you make the correction I noted. Otherwise, in the config folder is a file called config.js.sample. Make a copy of it and rename it to config.js. Then you’ll have to add your other modules and API keys
                                config.js or it won’t work
                                • F Offline
                                  Fonfon
                                  ok i understand my another problem is with the whitelist but i try to solve 1 problem after 1 problem
                                  thank mykle1
                                    @Fonfon yup, one thing at a time. Lets get your config.js working first
                                    • F Offline
                                      Fonfon @Mykle1
                                      @Mykle1 can you give me the original config file please
                                        @Fonfon ok, one sec
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: 'en',
                                          	timeFormat: 24,
                                          	units: 'metric',
                                          			module: 'alert',
                                          			position: "top_bar"
                                          			module: 'clock',
                                          			module: 'calendar',
                                          				locationID: 'GOES HERE',  //ID from http://www.openweathermap.org
                                          			module: 'newsfeed',
                                          				feeds: [
                                            Copy the entire message
                                            • 2 / 4
