    Bad question
    64 Posts 5 Posters 72.0k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Mykle1
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: 'en',
      	timeFormat: 24,
      	units: 'metric',
      			module: 'alert',
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar',
      			header: 'US Holidays',
      			position: 'top_left',
      						symbol: 'calendar-check-o ',
      			module: 'compliments',
      			position: 'lower_third'
      			module: 'currentweather',
      			position: 'top_right',
      				locationID: 'GOES HERE',  //ID from http://www.openweathermap.org
      				appid: 'YOUR_OPENWEATHER_API_KEY'
      			module: 'weatherforecast',
      			header: 'Weather Forecast',
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Copy the entire message
        • F
          Fonfon
          thanks mikle i copied the entire message i paste it
          rename my config file like config.js
          go to command
          npm start
          allways the message in a black screen
          please create a config file
          magic mirror2
          see readme for more information…
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Fonfon
            @Fonfon your config.js file that you just pasted the code into is inside your config folder, yes?
            • F
              Fonfon
              yes but i think the copie/pasted is not correct i re-try
              • F
                Fonfon
                yes he’s inside the folder
                he don’t work…
                • cowboysdudeC
                  To save yourself time and double check do this…
                  go to your MagicMirror/config directory
                  type in terminal window:
                  cp config.js.sample config.js
                  Then restart your mirror… lets make sure it’s working first :)
                  • F
                    Fonfon
                    it’s ok !! now i have the starting config file
                    thanks !!!
                    Mykle1M 2 Replies Last reply
                    • Mykle1M
                      @Fonfon I got him going bro. See? I can do things! (Godfather reference)
                      • Mykle1M
                        @Fonfon said in Bad question:
                        thanks
                        You’re welcome :thumbsup:
                        F 1 Reply Last reply
                        • F
                          Fonfon @Mykle1
                          • F
                            Fonfon
                            Ok i try to the change clock
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: 'en',
                            	timeFormat: 24,
                            	units: 'metric',
                            			module: 'alert',
                            			position: "top_bar"
                            			module: 'clock',
                            				timezone: 'france/paris'
                            			module: 'calendar',
                            				locationID: '',  //ID from http://www.openweathermap.org
                            				locationID: '5128581',  //ID from http://www.openweathermap.org
                            			module: 'newsfeed',
                            				feeds: [
                            is it the great form ?
                            • Mykle1M
                              @Fonfon I think it should be ‘France/Paris’ with capitals, and a comma after ‘top_left’,
                              Also, I think that if you leave the default at ‘none’ it will use your system clock
                              module : ‘clock’,
                              position : 'top_left’,
                              timezone: ‘France/Paris’
                              timezone Specific a timezone to show clock.
                              Possible examples values: America/New_York, America/Santiago, Etc/GMT+10
                              Default value: none
                              • F
                                Fonfon
                                That’s right capitals and comma needed
                                you are the boss thanks !!
                                • Mykle1M
                                  Just trying to be helpful. You’re welcome :thumbsup:
                                  • cowboysdudeC
                                    @Fonfon
                                    Just a suggestion that I give all new people… before you make changes to a working config.js make a copy of it… that way if you can’t figure out or you need something to compare it to you have your backup :)
                                    • Mykle1M
                                      @cowboysdude said in Bad question:
                                      Excellent advice, and I agree. We were just trying to get him a working config.js in the first place
                                      • F
                                        Fonfon
                                        Is it necessary to rename the config.js to config.js.sample every time you want to modify it?
                                        Or is there a simpler manipulation.
                                        yes now i do this !! i have a copy of my config.js ;)
                                        • Mykle1M
                                          @Fonfon - No, you don’t have to rename your config.js file to edit it but you might want to back it up BEFORE you edit it. This way, if anything goes wrong you’re safe
                                          • F
                                            Fonfon @Mykle1
                                            @Mykle1 for sure i understand how i can do for editing file without rename it ?
                                            • 2 / 4
