    Bad question
    64 Posts 5 Posters 67.7k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @Fonfon
      @Fonfon
      the 2nd { in the calendar module should be deleted for starters
        Mykle1 Project Sponsor Module Developer @Mykle1
        Like this
        	module: 'calendar',
        	header: 'US Holidays',
        	position: 'top_left',
        				symbol: 'calendar-check-o ',
        				url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
        • F Offline
          Fonfon
          Can you give me a correct config file for starting or where i can find it ?
          F Mykle1M 2 Replies Last reply Reply Quote 0
          • F Offline
            Fonfon @Fonfon
            @Fonfon and when i start npm , my config file name is config.js or config.js.sample ?
              @Fonfon said in Bad question:
              Well, that one should work if you make the correction I noted. Otherwise, in the config folder is a file called config.js.sample. Make a copy of it and rename it to config.js. Then you’ll have to add your other modules and API keys
                config.js or it won’t work
                • F Offline
                  Fonfon
                  ok i understand my another problem is with the whitelist but i try to solve 1 problem after 1 problem
                  thank mykle1
                    @Fonfon yup, one thing at a time. Lets get your config.js working first
                    • F Offline
                      Fonfon @Mykle1
                      @Mykle1 can you give me the original config file please
                        @Fonfon ok, one sec
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
                          	language: 'en',
                          	timeFormat: 24,
                          	units: 'metric',
                          			module: 'alert',
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: 'clock',
                          			module: 'calendar',
                          			module: 'compliments',
                          			position: 'lower_third'
                          			module: 'currentweather',
                          			position: 'top_right',
                          				locationID: 'GOES HERE',  //ID from http://www.openweathermap.org
                          				appid: 'YOUR_OPENWEATHER_API_KEY'
                          			module: 'weatherforecast',
                          			header: 'Weather Forecast',
                          			module: 'newsfeed',
                          			position: 'bottom_bar',
                          				feeds: [
                          						title: "New York Times",
                          				showSourceTitle: true,
                          				showPublishDate: true
                            Copy the entire message
                            • F Offline
                              Fonfon
                              thanks mikle i copied the entire message i paste it
                              rename my config file like config.js
                              go to command
                              npm start
                              allways the message in a black screen
                              please create a config file
                              magic mirror2
                              see readme for more information…
                                @Fonfon your config.js file that you just pasted the code into is inside your config folder, yes?
                                • F Offline
                                  Fonfon
                                  yes but i think the copie/pasted is not correct i re-try
                                  • F Offline
                                    Fonfon
                                    yes he’s inside the folder
                                    he don’t work…
                                    • cowboysdudeC Offline
                                      cowboysdude Module Developer
                                      To save yourself time and double check do this…
                                      go to your MagicMirror/config directory
                                      type in terminal window:
                                      cp config.js.sample config.js
                                      Then restart your mirror… lets make sure it’s working first :)
                                      • F Offline
                                        Fonfon
                                        it’s ok !! now i have the starting config file
                                        thanks !!!
                                        Mykle1M 2 Replies Last reply Reply Quote 1
                                          @Fonfon I got him going bro. See? I can do things! (Godfather reference)
                                            thanks
                                            You’re welcome :thumbsup:
                                            F 1 Reply Last reply Reply Quote 1
                                            • 2 / 4
