    v2.24.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 8.7k Views 2 Watching
    • MichMichM
      MichMich
      [2.24.0] - 2023-07-01
      https://github.com/MichMich/MagicMirror/releases/tag/v2.24.0
      Thanks to: @angeldeejay, @bugsounet, @buxxi, @CarJem, @dariom, @DaveChild, @dWoolridge, @eddiehung, @grenagit, @Hirschberger, @ismarslomic, @JakeBinney, @KristjanESPERANTO, @MagMar94, @naveensrinivasan, @nfogal, @oscarb, @OWL4C, @psieg, @rajniszp, @retroflex, @SkySails and @tomzt
      Special thanks to @khassel, @rejas and @sdetweil for taking over most (if not all) of the work on this release as project collaborators. This version would not be there without their effort. Thank you guys! You are awesome!
      Added
      • Added UV Index to hourly and current Weather, with support for Openmeteo
      • Added tests for serveronly
      • Set Timezone Europe/Berlin in unit tests (needed for new formatTime tests)
      • Added no-param-reassign eslint rule and fix warnings
      • updatenotification: Added sendUpdatesNotifications feature. Broadcast update with UPDATES notification to other modules
      • updatenotification: allow force scanning with SCAN_UPDATES notification from other modules
      • Added per-calendar fetchInterval
      Removed
      • Removed unneeded (and unwanted) ‘.’ after the year in calendar repeatingCountTitle (#2896, second attempt …)
      Updated
      • Added support for precipitation probability with openmeteo weather-provider
      • Update electron to v25.2 and other dependencies
      • Use node v20 in github workflow (replacing v14)
      • Refactor formatTime into common util function for default modules
      • Refactor some calendar methods into own class and added tests for them
      • Split install and run commands in github actions
      • Changed fetchInterval of calendar in config.js.sample to 7 days so we not to request example calendar too frequently
      • Changed default calendar fetchInterval to one hour
      • Changed calendar url in sample config
      Fixed
      • Fix envcanada hourly forecast time (#3080)
      • Fix electron not running under windows after async changes (#3083)
      • Fix style issues after eslint-plugin-jsdoc update
      • Fix don’t filter out ongoing full day events (#3095)
      • Fix date not shown when clock in analog mode (#3100)
      • Fix envcanada today percentage-of-precipitation (#3106)
      • Fix updatenotification where no branch is checked out but e.g. a version tag (#3130)
      • MichMichM MichMich locked this topic on
