    My SmartDisplay
    12 Posts 8 Posters 8.9k Views 11 Watching
      Bense
      this forum has inspired me to build a SmartDisplay for our family based on the MagicMirror. I use the following modules:
      • Default Clock
      • MMM-Todoist
      • MMM-SolarEdge
      • MMM-SynologySurveillance
      • MMM-OpenWeatherMapForecast
      • MMM-Buienradar
      • MMM-DWD-WarnWeather
      The Screen is a Lenovo ThinkVision P27h-20
      JalibuJ M 2 Replies Last reply Reply Quote 5
      • JalibuJ Offline
        Jalibu Module Developer @Bense
        @Bense cool!
        Does the screen allow you to power the Raspi via USB or how do you manage that?
          Bense @Jalibu
          @Jalibu
          Yep, the screen supplies power to the Raspi. So I only need one cable to the screen.
          I just see your Rain Map module, I have installed it directly. Looks very good!
          • C Offline
            Chazzer @Bense
            @Bense Looks really good. :-) Thanks for sharing.
            Also wanted to use the weather app.
            I’ve also been working on my own MM for a few days.
            Do you have any idea why the weather app MMM-OpenWeatherMapForecast does not load?
            Default weather with the Api works.
            The latest MM version also works.
            Do you know if it is related to the module width?
            C B 2 Replies Last reply Reply Quote 0
            • C Offline
              Chazzer @Chazzer
              @Chazzer said in My SmartDisplay:
              Kannst du mal dein Modul aus der Config für openweathermap posten.
              mein Modul lädt nicht
                Socrates
                Where are u hiding your RPI?
                  Michelle.H2020 @Bense
                  @Bense
                  Can you tell me how you get 4 modules on the right side without overlap?
                    bebetter14 @Chazzer
                    @Chazzer Did you ever find out why OpenWeather wasnt working? I have a very similar issue.
                    S R 3 Replies Last reply Reply Quote 0
                      sdetweil @bebetter14
                      @bebetter14 usually it’s the wrong key for the configuration
                        RobertV 0 @bebetter14
                        @bebetter14 me too having problem
                          @bebetter14 open the developers window, ctrl-shift-i on the browser keyboard, select the console tab and put weath in the filter field to see messages from the weather module.
                          pretty sure the error is 401, unauthorized
                            bebetter14 @sdetweil
                            @sdetweil Thank you Sam for the assitance once again! You are correct there was an error. I tried to copy the sample config and replaced my API Key from Openweather and entered in my lat and long.
                              module: "MMM-OpenWeatherMapForecast",
                              header: "Weather",
                              classes: "default everyone",
                              disabled: false,
                                apikey: "SUPER SECRET!!!",
                                latitude: "51.506130",
                                longitude: "-0.090270",
                                iconset: "4c",
                                concise: false,
                                forecastLayout: "table"
                            The error Im getting is saying Verify styleshhet URLs, Affected Resource Localhost/:0
                            The weird thing I can use the API key for the default weather map no problem. Maybe I’m entering it in in the wrong format. Your help is much appreciated!
