    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 89.8k Views 16 Watching
    • brobergB Offline
      broberg Project Sponsor @Mykle1
      @Mykle1 humm, okey, probably because the function to round it up thinks it’s more than 0.5 days left and thus rounds it up to 1 instead of down to zero.
      Have to adjust the code a bit
        Jopyth Moderator @Mykle1
        @Mykle1 My advent module? Even though @broberg hasn’t mentioned it, it seems he based his work on that module.
        A feature suggestion from my side: It would feel more like an urgent thing closing in, if it could also show hours/minutes/seconds, too. Maybe use a formatting string for a moment.js duration? If I have some time, I might make a PR.
        Helpful sticky: How to troubleshoot
        brobergB Mykle1M 2 Replies Last reply Reply Quote 0
        • brobergB Offline
          @Mykle1 Okey, I changed up some variables and I’m not able to test them myself, when you get home, could do a git pull on the doomsday module and test it out for me?
          • brobergB Offline
            broberg Project Sponsor @Jopyth
            @Jopyth Yes, I stripped out that module for this one, kept the start function and removed the rest since It was a bit over my head at the moment :)
            Took me a lot longer than I’m willing to admit just to get the code to compare dates!
            Actually thought about the hour/minute countdown as well, but decided to keep it real basic.
            I figured you don’t really put that many hours in front of the mirror that it would be that important to see so much detail of the countdown. (And if you look the update interval is set to 5 hours just to keep it in the ballpark)
              Mykle1 Project Sponsor Module Developer @Jopyth
              @Jopyth said in MMM-doomsDay - The countdown module,:
              My advent module?
              Yes, that was it. :thumbsup_tone1:
                Mykle1 Project Sponsor Module Developer @broberg
                @broberg said in MMM-doomsDay - The countdown module,:
                when you get home, could do a git update on the doomsday module and test it out for me?
                This is what I get when I attempted a git update as you suggested.
                pi@Pi3:~/MagicMirror/modules/MMM-doomsDay $ git update
                git: ‘update’ is not a git command. See ‘git --help’.
                Did you mean this?
                update-ref
                I don’t want to mess anything up so I’ll wait till you advise further, thanks
                strawberry 3.141S brobergB 2 Replies Last reply Reply Quote 0
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @Mykle1
                  @Mykle1 git pull
                  • brobergB Offline
                    @Mykle1 sorry my bad mixing up stuff, git pull is the command to use in the Mmm-doomsday folder
                    • brobergB Offline
                      A second to slow,@strawberry-3-141 beat me to it :)
                        A photo finish? Thanks to both of you. :thumbsup_tone1:
                            			module: 'MMM-doomsDay',
                            			position: 'top_left', // This can be any of the regions, best results in center regions
                                			doomsDay: "2017-02-24 24:00:00",  // the end day of the countdown, format is YYYY-MM-DD HH:MM:SS,
                                			toWhat: 'Open the pool!',  // the title of your countdown event
                        				present: 'We are gonna rock',  //  What it should say on doomsDay date
                        				singular: `Day Left`, // what it should say when it's only one day left, default is `Day Left`
                        				plural: 'Days Left', // what it should say when it's more days left, default is `Days Left`
                        Ok, now the display says, “Open the pool!”, but underneath is says, “0 Days Left”
                        • 6
                        • 7
                        • 8
                        • 5 / 8
