    Total n00b and can't get this thing to work. Please help!
    35 Posts 8 Posters 26.6k Views 7 Watching
    • E Offline
      EttVenter @yawns
      @yawns I ran it with sudo
      Here’s the result of sudo apt-get upgrade after I ran sudo apt-get update:
      pi@raspberrypi:~ $ sudo apt-get upgrade
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      Calculating upgrade... The following packages were automatically installed and are no longer required:
        libc-ares2 libv8-3.14.5
      Use 'apt-get autoremove' to remove them.
      Done
      The following packages have been kept back:
        chromium-browser libgl1-mesa-dri pprompt rpi-chromium-mods sonic-pi
        xserver-xorg-input-all
      0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
      Then, if I do:
      git clone https://github.com/MichMich/MagicMirror
      cd ~/MagicMirror
      npm install && npm start
      as suggested above, I’m met with:
      pi@raspberrypi:~/MagicMirror $ npm install && npm start
      npm http GET https://registry.npmjs.org/electron
      npm http GET https://registry.npmjs.org/express
      npm http GET https://registry.npmjs.org/express-ipfilter
      npm http GET https://registry.npmjs.org/feedme
      npm http GET https://registry.npmjs.org/helmet
      npm http GET https://registry.npmjs.org/iconv-lite
      npm http GET https://registry.npmjs.org/moment
      npm http GET https://registry.npmjs.org/request
      npm http GET https://registry.npmjs.org/simple-git
      npm http GET https://registry.npmjs.org/valid-url
      npm http GET https://registry.npmjs.org/socket.io
      npm http GET https://registry.npmjs.org/walk
      npm http GET https://registry.npmjs.org/rrule
      npm http GET https://registry.npmjs.org/grunt
      npm http GET https://registry.npmjs.org/grunt-eslint
      npm http GET https://registry.npmjs.org/grunt-jsonlint
      npm http GET https://registry.npmjs.org/grunt-markdownlint
      npm http GET https://registry.npmjs.org/grunt-stylelint
      npm http GET https://registry.npmjs.org/grunt-yamllint
      npm http GET https://registry.npmjs.org/stylelint-config-standard
      npm http GET https://registry.npmjs.org/time-grunt
      npm http 304 https://registry.npmjs.org/express
      npm http 304 https://registry.npmjs.org/feedme
      npm http 304 https://registry.npmjs.org/electron
      npm http 304 https://registry.npmjs.org/express-ipfilter
      npm http 304 https://registry.npmjs.org/helmet
      npm ERR! Error: No compatible version found: electron@'^1.4.7'
      npm ERR! Valid install targets:
      npm ERR! ["0.1.0","0.1.1","0.1.2","0.2.0","0.2.1","0.3.0","0.4.0","0.4.1","1.3.1","1.3.2","1.3.3","1.3.4","1.3.5","1.3.6","1.4.0","1.4.1","1.3.7","1.4.2","1.4.3","1.4.4","1.3.8","1.4.5","1.4.6","1.4.7","1.3.9","1.3.10","1.4.8","1.3.12","1.4.10","1.3.13","1.4.11","1.4.12","1.4.13","1.4.14","1.4.15","1.5.0","1.5.1","1.6.0","1.6.1"]
      npm ERR!     at installTargetsError (/usr/local/lib/node_modules/npm/lib/cache.js:563:10)
      npm ERR!     at /usr/local/lib/node_modules/npm/lib/cache.js:478:10
      npm ERR!     at saved (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:138:7)
      npm ERR!     at /usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:218:7
      npm ERR!     at Object.oncomplete (fs.js:297:15)
      npm ERR! If you need help, you may report this log at:
      npm ERR!
      npm ERR! or email it to:
      npm ERR!
      npm ERR! System Linux 4.4.34-v7+
      npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v0.8.16
      npm ERR! npm -v 1.1.69
      npm WARN package.json feedme@0.3.3 No README.md file found!
      npm http 304 https://registry.npmjs.org/moment
      npm http 304 https://registry.npmjs.org/iconv-lite
      npm WARN package.json express-ipfilter@0.2.3 No README.md file found!
      npm WARN package.json moment@2.17.1 No README.md file found!
      npm WARN package.json iconv-lite@0.4.15 No README.md file found!
      npm http 304 https://registry.npmjs.org/request
      npm http 304 https://registry.npmjs.org/simple-git
      npm http 304 https://registry.npmjs.org/valid-url
      npm http 304 https://registry.npmjs.org/socket.io
      npm http 304 https://registry.npmjs.org/walk
      npm http 304 https://registry.npmjs.org/rrule
      npm http 304 https://registry.npmjs.org/grunt
      npm http 304 https://registry.npmjs.org/grunt-eslint
      npm http 304 https://registry.npmjs.org/grunt-jsonlint
      npm http 304 https://registry.npmjs.org/grunt-markdownlint
      npm http 304 https://registry.npmjs.org/grunt-stylelint
      npm http 304 https://registry.npmjs.org/grunt-yamllint
      npm http 304 https://registry.npmjs.org/stylelint-config-standard
      npm http 304 https://registry.npmjs.org/time-grunt
      npm WARN package.json rrule@2.1.0 No README.md file found!
      npm WARN package.json walk@2.3.9 No README.md file found!
      npm WARN package.json grunt-eslint@19.0.0 No README.md file found!
      npm WARN package.json grunt@1.0.1 No README.md file found!
      npm WARN package.json grunt-jsonlint@1.1.0 No README.md file found!
      npm WARN package.json grunt-stylelint@0.7.0 No README.md file found!
      npm WARN package.json stylelint-config-standard@16.0.0 No README.md file found!
      npm WARN package.json grunt-yamllint@0.2.0 No README.md file found!
      npm WARN package.json time-grunt@1.4.0 No README.md file found!
      npm ERR!
      npm ERR! not ok code 0
      • yawnsY Offline
        yawns Moderator
        Very weird indeed. Did you install Jessie or Jessie Lite?
        If I run the version commands, I get this on my pi:
        npm -v: 3.10.8
        node -v: 6.9.1
        nodejs -v: 6.9.1
        Please try this:
        sudo apt-get remove nodered -y
        sudo apt-get remove nodejs nodejs-legacy -y
        sudo apt-get remove npm -y
        sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
        sudo apt-get install -y nodejs
        node -v
        npm -v
        and then try to run the npm install && npm start again in your MagicMirror folder
        • E Offline
          EttVenter @yawns
          @yawns
          Ok, I ran all of that. Once I ran the node -v and npm -v commands I was met with:
          pi@raspberrypi:~ $ node -v
          v0.8.16
          pi@raspberrypi:~ $ npm -v
          1.1.69
          So I’m assuming I’m still on super old versions. Any idea why that’s happening? Because if I run npm install && npm start, I’m getting the same errors I was getting before.
          Also - Jessie, not Jessie lite.
          • yawnsY Offline
            yawns Moderator
            But you did not receive any error message during removal and installation?
            • E Offline
              EttVenter @yawns
              @yawns Nope, no errors there.
              • E Offline
                EttVenter
                Anyone else got any ideas? Really want to get this thing going. I bought the Pi yesterday specifically for this :(
                • brobergB Offline
                  broberg Project Sponsor @EttVenter
                  @EttVenter I would suggest a total reformatting of the SD card, get the Jessie lite image and put that on your sd card.
                  Then follow these instructions : https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
                  E 2 Replies Last reply Reply Quote 1
                  • E Offline
                    EttVenter @broberg
                    @broberg
                    I’ll give that a shot!
                    • E Offline
                      EttVenter @broberg
                      @broberg
                      Ok, so that all went well until I got to:
                      Get and install MagicMirror with the Automatic Installer:
                      curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
                      At which point, I get “No such file or directory”.
                      That feels like a small error that I should be able to figure out, but I just can’t seem to get past that point :/
                      • brobergB Offline
                        @EttVenter and if you run curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh
                        Without the bash cd command?
                        • 2 / 4
