Execute bash command/Turn off GPIO (LED) from mirror
11 Posts 5 Posters 1.8k Views 4 Watching
    BKeyport Module Developer
    I’m looking for a quick and dirty way to turn off an LED once the mirror fully loads - basically getting around the slowness in Electron from all the random little errors on startup and waiting for systems that will never start.
    I don’t care if it’s a quick module I build myself, or something else.
    I’m assuming it can be done with all the abilities to read system info etc - just not sure how to do it myself.
    Thanks!
    R 1 Reply Last reply May 13, 2024, 3:55 PM Reply Quote 0
      bugsounet Banned
      tip: try to use gpiozero ;)
      B 1 Reply Last reply May 12, 2024, 12:53 AM Reply Quote 0
        BKeyport Module Developer @bugsounet
        @bugsounet I actually have the bash command I need to run. Just the part of interfacing through the Mirror is what I need help with.
        B M 2 Replies Last reply May 12, 2024, 8:41 AM Reply Quote 0
          bugsounet Banned @BKeyport
          ah sorry, so exec your code it when all modules are started.
          with ALL_MODULES_STARTED incoming system notification, you can send a notification to node_helper for exec your bash script
          For execute it in node_helper, you can use exec command of child_process library
          See:
          • system notification: about all system notification
          • sendSocketNotification for send a notification to node_helper
          • socketNotificationReceived for read notification in node_helper
            MMRIZE @BKeyport
            @BKeyport
            MMM-NotificationTrigger for that purpose.
            W 1 Reply Last reply May 12, 2024, 7:02 PM Reply Quote 0
            • W Online
              wishmaster270 Module Developer @MMRIZE
              @MMRIZE
              Or https://github.com/Tom-Hirschberger/MMM-Notification-To-Command
              B 1 Reply Last reply May 12, 2024, 9:37 PM Reply Quote 0
                BKeyport Module Developer @wishmaster270
                @wishmaster270 @MMRIZE I figured one of you wizards already figured it out. I had forgotten about the all modules notification, and then I would have realized all the pieces are already there.
                B 1 Reply Last reply May 12, 2024, 10:41 PM Reply Quote 0
                  BKeyport Module Developer @BKeyport
                  FWIW, MMM-Notification-To-Command is exactly what I was aiming for.
                  • B BKeyport has marked this topic as solved on May 13, 2024, 1:41 AM
                    Ray @BKeyport
                    @BKeyport you might want to look at raspberry pi 5 I use it to turn LEDs on and off
                    I also use believers are not Dragon NaturallySpeaking which is pretty cool because I can write a letter and also turn LEDs on and off just by voice
                    B 1 Reply Last reply May 13, 2024, 8:57 PM Reply Quote 0
                      BKeyport Module Developer @Ray
                      @Ray pinctrl 17 op dl does the work behind the scenes, I just needed a way to call it from the mirror, which I got with MMM-Notification-to-command.
                      R 1 Reply Last reply May 14, 2024, 9:13 AM Reply Quote 0
