    MM startup problem after update
    42 Posts 3 Posters 11.1k Views 4 Watching
      manu85340 @sdetweil
      @sdetweil I typed “n” and there is nothing
        sdetweil @manu85340
        @manu85340 ok,
        do
        sudo npm I-g n
        sudo n 20
        then node -v
          manu85340 @sdetweil
          pi@MagicMirror:~ $ sudo npm I-g n
          Unknown command: "I-g"
          To see a list of supported npm commands, run:
            npm help
          pi@MagicMirror:~ $ sudo n 20
            installing : node-v20.15.0
                 mkdir : /usr/local/n/versions/node/20.15.0
                 fetch : https://nodejs.org/dist/v20.15.0/node-v20.15.0-linux-armv7l.tar.x        z
               copying : node/20.15.0
          node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not foun        d (required by node)
          /usr/local/bin/node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3        .4.26' not found (required by /usr/local/bin/node)
             installed :  (with npm )
          pi@MagicMirror:~ $ node -v
          pi@MagicMirror:~ $ node-v
          -bash: node-v : commande introuvable
          pi@MagicMirror:~ $
            sdetweil @manu85340
            @manu85340 grr… that was the problem finding the c++ lib for buster.
            let me research, be a couple hours
              manu85340 @sdetweil
              @sdetweil OK thanks to you
                sdetweil @manu85340
                @manu85340 so, after research. there is no way to get to the latest MagicMirror release on buster.
                unless there is some fix you NEED , I recommend staying where you were til you can plan to upgrade the os.
                now we’ve already tried going forward, so need to jump back.
                can you look in the upgrade log ~/MagicMirror/installers/upgrade.log
                for the string
                upgrading from version
                so we can get you back to that earlier release
                in prep for os migration, and general health backup your MagicMirror system
                see my backup restore
                  manu85340 @sdetweil
                  @sdetweil I’ll give you part of upgrade.log I hope it suits you and I’ll look at the link you provided I hope I’ll manage to understand what to do
                  restoring custom.css
                  removing git alias
                  Upgrade ended - mar. avril 2 10:35:49 CEST 2024
                  Upgrade started - mar. avril 2 10:37:27 CEST 2024
                  system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                  user requested to apply changes
                  doing test run = false
                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                  Node currently installed. Checking version number.
                  Minimum Node version: v18.18.0
                  Installed Node version: v18.18.0
                  Check current Node installation …
                  No Node.js upgrade necessary.
                  Check current NPM installation …
                  NPM currently installed. Checking version number.
                  Minimum npm version: V9.8.1
                  Installed npm version: V9.8.1
                  No npm upgrade necessary.
                  saving custom.css
                  remote name = origin
                  upgrading from version 2.26.0 to 2.27.0
                  fetching latest revisions
                  git fetch rc=0
                  current branch = master
                  On branch master
                  Your branch is behind ‘origin/master’ by 1 commit, and can be fast-forwarded.
                  (use “git pull” to update your local branch)
                  Untracked files:
                  (use “git add …” to include in what will be committed)
                  core
                  css/icons/
                  css/save_custom.css
                  modules/default/currentweather/
                  nohup.out
                  nothing added to commit but untracked files present (use “git add” to track)
                  no files different from github version
                  test merge result rc=‘’ , if empty, no conflicts
                  executing merge, apply specified
                  merge result rc= 0
                  Updating 118e2123…5ea8a346 Fast-forward .eslintignore
                  3 ± .eslintrc.json
                  18 ± .github/codecov.yaml
                  10 - .github/dependabot.yaml
                  15 + .github/workflows/depsreview.yaml
                  2 ± .github/workflows/electronRebuild.yaml
                  20 + .github/workflows/enforce-pullrequest-rules.yaml
                  2 ± .gitignore
                  6 ± .husky/pre-commit
                  2 - .npmrc
                  1 + .prettierignore
                  2 + CHANGELOG.md
                  199 ± Collaboration.md
                  24 ± LICENSE.md
                  2 ± README.md
                  10 ± clientonly/index.js
                  4 ± config/config.js.sample
                  5 ± css/custom.css.sample
                  8 ± fonts/package-lock.json
                  18 ± fonts/package.json
                  11 ± js/animateCSS.js
                  7 - js/app.js
                  42 ± js/check_config.js
                  23 ± js/defaults.js
                  8 ± js/deprecated.js
                  8 - js/electron.js
                  1 + js/loader.js
                  6 - js/logger.js
                  43 ± js/main.js
                  6 - js/module.js
                  6 ± js/node_helper.js
                  6 - js/server.js
                  16 ± js/server_functions.js
                  4 ± js/socketclient.js
                  6 - js/translator.js
                  6 - js/utils.js
                  Bin 0 -> 6947 bytes modules/default/alert/alert.js
                  6 - modules/default/calendar/calendar.js
                  33 ± modules/default/calendar/calendarfetcher.js
                  9 ± modules/default/calendar/calendarfetcherutils.js
                  268 ± modules/default/calendar/calendarutils.js
                  6 - modules/default/calendar/debug.js
                  3 - modules/default/calendar/node_helper.js
                  15 ± modules/default/clock/clock.js
                  11 ± modules/default/compliments/compliments.js
                  8 ± modules/default/defaultmodules.js
                  5 ± modules/default/helloworld/helloworld.js
                  6 - modules/default/newsfeed/newsfeed.js
                  43 ± modules/default/newsfeed/newsfeedfetcher.js
                  13 ± modules/default/newsfeed/node_helper.js
                  7 - modules/default/updatenotification/git_helper.js
                  10 ± …/default/updatenotification/update_helper.js
                  57 ± …/updatenotification/updatenotification.js
                  10 ± modules/default/weather/current.njk
                  56 ± modules/default/weather/providers/envcanada.js
                  8 ± modules/default/weather/providers/openmeteo.js
                  12 ± …/default/weather/providers/openweathermap.js
                  9 ± modules/default/weather/providers/pirateweather.js
                  11 ± modules/default/weather/providers/smhi.js
                  12 ± modules/default/weather/providers/ukmetoffice.js
                  9 ± …/weather/providers/ukmetofficedatahub.js
                  9 ± modules/default/weather/providers/weatherbit.js
                  11 ± modules/default/weather/providers/weatherflow.js
                  10 ± modules/default/weather/providers/weathergov.js
                  10 ± modules/default/weather/providers/yr.js
                  10 ± modules/default/weather/weather.js
                  14 ± modules/default/weather/weatherobject.js
                  12 - modules/default/weather/weatherprovider.js
                  9 ± modules/default/weather/weatherutils.js
                  6 - package-lock.json
                  4180 ++++++++++++±------ package.json
                  60 ± serveronly/index.js
                  2 ± tests/configs/default.js
                  5 - tests/configs/empty_ipWhiteList.js
                  5 - tests/configs/modules/alert/default.js
                  5 - tests/configs/modules/calendar/auth-default.js
                  5 - tests/configs/modules/calendar/bad_rrule.js
                  5 - tests/configs/modules/calendar/basic-auth.js
                  5 - tests/configs/modules/calendar/changed-port.js
                  5 - tests/configs/modules/calendar/custom.js
                  6 ± tests/configs/modules/calendar/default.js
                  5 - …/{exdate.js => exdate_la_at_midnight_dst.js}
                  13 ± …/modules/calendar/exdate_la_at_midnight_std.js
                  37 + …/modules/calendar/exdate_la_before_midnight.js
                  37 + …/modules/calendar/exdate_syd_at_midnight_dst.js
                  37 + …/modules/calendar/exdate_syd_at_midnight_std.js
                  37 + …/modules/calendar/exdate_syd_before_midnight.js
                  37 + tests/configs/modules/calendar/fail-basic-auth.js
                  7 - …/configs/modules/calendar/long-fullday-event.js
                  28 + tests/configs/modules/calendar/old-basic-auth.js
                  5 - tests/configs/modules/calendar/recurring.js
                  5 - tests/configs/modules/calendar/rrule_until.js
                  30 + …/calendar/show-duplicates-in-calendar.js
                  5 - …/modules/calendar/single-fullday-event.js
                  28 + tests/configs/modules/clock/clock_12hr.js
                  5 - tests/configs/modules/clock/clock_24hr.js
                  5 - tests/configs/modules/clock/clock_analog.js
                  4 - …/modules/clock/clock_displaySeconds_false.js
                  5 - …/configs/modules/clock/clock_showDateAnalog.js
                  5 - …/configs/modules/clock/clock_showPeriodUpper.js
                  5 - tests/configs/modules/clock/clock_showSunMoon.js
                  5 - tests/configs/modules/clock/clock_showTime.js
                  5 - tests/configs/modules/clock/clock_showWeek.js
                  5 - tests/configs/modules/clock/es/clock_12hr.js
                  5 - tests/configs/modules/clock/es/clock_24hr.js
                  5 - …/modules/clock/es/clock_showPeriodUpper.js
                  5 - tests/configs/modules/clock/es/clock_showWeek.js
                  6 - …/modules/compliments/compliments_animateCSS.js
                  6 - …/compliments_animateCSS_fallbackToDefault.js
                  7 - …compliments_animateCSS_invertedAnimationName.js
                  6 - …/modules/compliments/compliments_anytime.js
                  5 - …/modules/compliments/compliments_date.js
                  5 - …/compliments/compliments_only_anytime.js
                  5 - …/modules/compliments/compliments_parts_day.js
                  5 - …/modules/compliments/compliments_remote.js
                  5 - tests/configs/modules/display.js
                  5 - tests/configs/modules/helloworld/helloworld.js
                  5 - …/modules/helloworld/helloworld_default.js
                  5 - tests/configs/modules/newsfeed/default.js
                  5 - tests/configs/modules/newsfeed/ignore_items.js
                  4 - tests/configs/modules/newsfeed/incorrect_url.js
                  4 - tests/configs/modules/newsfeed/prohibited_words.js
                  4 - tests/configs/modules/positions.js
                  5 - …/modules/weather/currentweather_compliments.js
                  5 - …/modules/weather/currentweather_default.js
                  6 ± …/modules/weather/currentweather_options.js
                  7 ± …/modules/weather/currentweather_units.js
                  7 ± …/modules/weather/forecastweather_absolute.js
                  5 - …/modules/weather/forecastweather_default.js
                  5 - …/modules/weather/forecastweather_options.js
                  5 - …/modules/weather/forecastweather_units.js
                  5 - …/modules/weather/hourlyweather_default.js
                  5 - …/modules/weather/hourlyweather_options.js
                  5 - …/weather/hourlyweather_showPrecipitation.js
                  5 - tests/configs/noIpWhiteList.js
                  5 - tests/configs/port_8090.js
                  5 - tests/configs/port_variable.js.template
                  5 - tests/configs/without_modules.js
                  5 - tests/e2e/animateCSS_spec.js
                  7 - tests/e2e/fonts_spec.js
                  2 ± tests/e2e/helpers/basic-auth.js
                  2 ± tests/e2e/modules/calendar_spec.js
                  31 + tests/e2e/modules/weather_current_spec.js
                  16 ± tests/e2e/serveronly_spec.js
                  2 ± tests/e2e/template_spec.js
                  2 ± tests/e2e/translations_spec.js
                  4 ± tests/electron/env_spec.js
                  2 ± tests/electron/helpers/global-setup.js
                  6 ± tests/electron/modules/calendar_spec.js
                  105 ± tests/mocks/calendar_test_exdate.ics
                  34 - tests/mocks/calendar_test_full_day_events.ics
                  33 + …/calendar_test_multi_day_starting_today.ics
                  33 + tests/mocks/exdate_la_at_midnight_dst.ics
                  15 + tests/mocks/exdate_la_at_midnight_std.ics
                  15 + tests/mocks/exdate_la_before_midnight.ics
                  15 + tests/mocks/exdate_syd_at_midnight_dst.ics
                  15 + tests/mocks/exdate_syd_at_midnight_std.ics
                  15 + tests/mocks/exdate_syd_before_midnight.ics
                  15 + tests/mocks/rrule_until.ics
                  24 + tests/unit/classes/class_spec.js
                  2 ± tests/unit/classes/translator_spec.js
                  2 ± tests/unit/classes/utils_spec.js
                  35 ± tests/unit/functions/cmp_versions_spec.js
                  2 ± tests/unit/functions/updatenotification_spec.js
                  22 ± tests/unit/global_vars/defaults_modules_spec.js
                  4 ± tests/unit/global_vars/root_path_spec.js
                  4 ± tests/utils/weather_mocker.js
                  13 ± translations/et.json
                  31 ± translations/translations.js
                  7 - vendor/package-lock.json
                  10 ± vendor/package.json
                  9 ± vendor/vendor.js
                  6 - 173 files changed, 4108 insertions(+), 2557 deletions(-) delete mode 100644 .github/codecov.yaml
                  create mode 100644 .github/workflows/electronRebuild.yaml
                  create mode 100644 mm2.png rename tests/configs/modules/calendar/{exdate.js => exdate_la_at_midnight_dst.js} (50%)
                  create mode 100644 tests/configs/modules/calendar/exdate_la_at_midnight_std.js
                  create mode 100644 tests/configs/modules/calendar/exdate_la_before_midnight.js
                  create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_dst.js
                  create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_std.js
                  create mode 100644 tests/configs/modules/calendar/exdate_syd_before_midnight.js
                  create mode 100644 tests/configs/modules/calendar/long-fullday-event.js
                  create mode 100644 tests/configs/modules/calendar/rrule_until.js
                  create mode 100644 tests/configs/modules/calendar/single-fullday-event.js delete mode 100644 tests/mocks/calendar_test_exdate.ics
                  create mode 100644 tests/mocks/calendar_test_full_day_events.ics
                  create mode 100644 tests/mocks/calendar_test_multi_day_starting_today.ics
                  create mode 100644 tests/mocks/exdate_la_at_midnight_dst.ics
                  create mode 100644 tests/mocks/exdate_la_at_midnight_std.ics
                  create mode 100644 tests/mocks/exdate_la_before_midnight.ics
                  create mode 100644 tests/mocks/exdate_syd_at_midnight_dst.ics
                  create mode 100644 tests/mocks/exdate_syd_at_midnight_std.ics
                  create mode 100644 tests/mocks/exdate_syd_before_midnight.ics
                  create mode 100644 tests/mocks/rrule_until.ics
                  processor architecture is armv7l
                  updating MagicMirror runtime, please wait
                  magicmirror@2.27.0 postinstall
                  npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                  magicmirror@2.27.0 install-vendor
                  echo "Installing vendor files …
                  " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  changed 1 package in 3s
                  magicmirror@2.27.0 install-fonts
                  echo "Installing fonts …
                  " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  Installing fonts …
                  changed 2 packages in 6s
                  magicmirror@2.27.0 prepare
                  [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                  no husky installed.
                  added 483 packages in 2m
                  112 packages are looking for funding
                  run npm fund for details
                  npm install completed - mar. avril 2 10:39:31 CEST 2024 on base
                  fixing sandbox permissions
                  Checking for modules with removed libraries
                  downloading dumpactivemodules script
                  updating dependencies for active modules with package.json files
                  processing for module MMM-OneCallWeather please wait
                  added 1 package, and audited 2 packages in 4s
                  found 0 vulnerabilities
                  processing complete for module MMM-OneCallWeather
                  processing for module MMM-ISS-Map please wait
                  added 1 package, and audited 2 packages in 7s
                  processing complete for module MMM-ISS-Map
                  processing for module MMM-ISS-Live please wait
                  up to date, audited 1 package in 2s
                  processing complete for module MMM-ISS-Live
                  removing git alias
                  Upgrade ended - mar. avril 2 10:39:54 CEST 2024
                    sdetweil @manu85340
                    @manu85340 ok, we need to back up to version 2.27 and node 18
                    so, first lets go back to node 18
                    sudo n 18
                    verify
                    node -v
                    should return something like this
                    ~/MagicMirror$ node -v
                    v18.20.3
                    if that is successful, then on to MagicMirror
                    cd ~/MagicMirror
                    git fetch --tags
                    git checkout -b temp v.2.27.0
                    rm package-lock.json
                    rm -rf node_modules
                    npm run install-mm
                    then MagicMirror should start and run
                    npm start
                    and not for startup
                    sudo reboot
                      manu85340 @sdetweil
                      @sdetweil Sam I have an error when I pass the line
                      v18.20.3
                      pi@MagicMirror:~ $ cd ~/MagicMirror
                      pi@MagicMirror:~/MagicMirror $ git fetch --tags
                      remote: Enumerating objects: 4, done.
                      remote: Counting objects: 100% (4/4), done.
                      remote: Compressing objects: 100% (4/4), done.
                      remote: Total 4 (delta 0), reused 0 (delta 0), pack-reused 0
                      D▒paquetage des objets: 100% (4/4), fait.
                      Depuis https://github.com/MagicMirrorOrg/MagicMirror
                      • [nouvelle branche] dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0 -> origin/dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0
                        ! [rejet▒] v2.17.0 -> v2.17.0 (▒craserait l’▒tiquette existante)
                        pi@MagicMirror:~/MagicMirror $ git checkout -b temp v.2.27.0
                        fatal: ‘v.2.27.0’ n’est pas un commit et une branche ‘temp’ ne peut pas en ▒tre cr▒▒e depuis
                      so I’m not going any further, I’m waiting for your instructions
                        sdetweil @manu85340
                        @manu85340 said in MM startup problem after update:
                        my fault (that little dot after the v!..) sorry
                        git checkout -b temp v2.27.0
                          manu85340 @sdetweil
                          @sdetweil I have an error see below, thanks Sam
                          pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0
                          Basculement sur la nouvelle branche ‘temp’
                          pi@MagicMirror:~/MagicMirror $ rm package-lock.json
                          pi@MagicMirror:~/MagicMirror $ rm -rf node_modules
                          pi@MagicMirror:~/MagicMirror $ npm run install-mm
                          magicmirror@2.27.0 install-mm
                          npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                          <— Last few GCs —>
                          [25028:0x4545870] 27358 ms: Mark-sweep (reduce) 226.0 (233.8) -> 225.8 (233.8) MB, 271.2 / 0.0 ms (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed
                          [25028:0x4545870] 27592 ms: Mark-sweep (reduce) 226.3 (233.8) -> 226.2 (234.3) MB, 230.3 / 0.0 ms (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed
                          <— JS stacktrace —>
                          FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                          Aborted
                          • BKeyportB Offline
                            BKeyport Module Developer @manu85340
                            You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…
                              manu85340 @BKeyport
                              @BKeyport ok thank you for your answer I’m waiting to see if @sdetweil sdetweil finds a solution
                                sdetweil @manu85340
                                @manu85340 see this post (and the one before it) in an issue w the same problem
                                https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685
                                  manu85340 @sdetweil
                                  @sdetweil hi Sam if I understand correctly it is not possible to restart the MM with the update that I passed, that’s it,
                                    sdetweil @manu85340
                                    @manu85340 I don’t understand.
                                    we have restored back to 2.27
                                    2.28 will not run on buster
                                    you need the next at least bullseye
                                    bur if you are upgrading, go to current, bookworm
                                      manu85340 @sdetweil
                                      @sdetweil Sam a few posts above I told you that I had a problem passing this line:
                                      so I didn't pass the other command lines
                                      rm -rf node_modules
                                      npm run install-mm
                                        sdetweil @manu85340
                                        @manu85340 yes and I replied with the corrected command
                                        https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update/30?_=1719933486042
                                          manu85340 @sdetweil
                                          @sdetweil Yes, that’s true, sorry, but then I made another comment to let you know that I had an error when I passed the line: ```
                                          npm run install-mm
                                          <— Last few GCs —>
                                          [12543:0x5273870] 17046 ms: Mark-sweep (reduce) 226.7 (234.0) -> 226.5 (234.0 ) MB, 147.4 / 0.0 ms (+ 65.0 ms in 7 steps since start of marking, biggest step 17.7 ms, walltime since start of marking 223 ms) (average mu = 0.854, current m u = 0.346) allo[12543:0x5273870] 17258 ms: Mark-sweep (reduce) 226.9 (234.0) -> 226.9 (234.5) MB, 207.1 / 0.0 ms (average mu = 0.705, current mu = 0.026) al location failure; scavenge might not succeed
                                          <— JS stacktrace —>
                                          FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memor y
                                          Aborted
                                            sdetweil @manu85340
                                            @manu85340 and then i posted another link with instructions for that problem
                                            • 2 / 3
