    Cant use showEnd icloud cal
    30 Posts 3 Posters 3.8k Views 3 Watching
      blvk
      Hey,
      hopefully you can help me. If already tryed to try this fix but it dont work for me.
      https://github.com/MagicMirrorOrg/MagicMirror/issues/2629
      My problem, i got a Calendar form my icloud cal. I already got every informations i want.
      This is my ics
      BEGIN:VEVENT
      CREATED:20240922T101541Z
      DTEND;VALUE=DATE:20250104
      DTSTAMP:20240922T101542Z
      DTSTART;VALUE=DATE:20241216
      LAST-MODIFIED:20240922T101541Z
      SEQUENCE:0
      SUMMARY:Urlaub Jan
      UID:66E9674A-B97F-41DC-B25E-DE2D2C4DFF3B
      URL;VALUE=URI:
      X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
      X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
      TRANSP:OPAQUE
      END:VEVENT
                              "module": "calendar",
                              "header": "Urlaub",
                              "position": "top_left",
                              "config": {
                                      showEnd: true,
                                      showEndsOnlyWithDuration: true,
                                      maximumEntries: 8,
                                      "calendars": [
                                                      "symbol": "calendar",
                                                      "url": "http://192.168.178.3:8080/modules/calendars/3920BBAD-278C-4EAB-AF16-9442B82D2459.ics"
      The showEnd dont work, i got only the start date of my holidays.
      What do i wrong?
      • evroomE Offline
        evroom @sdetweil
        My Google Calendar remark was more aimed at the basic.ics we get from it.
        I see now it added an unnecessary discussion.
        However it did take me some time to find out that the screen you showed is only seen after clicking the More Options button; my bad.
        Your evaluation of showEnd and showEndsOnlyWithDuration is quite useful.
        Btw, one time in the Dutch parliament there was a big confusion about voting for something.
        If you do not want XXX, then vote yes, if you want XXX then vote no.
        Of course this went wrong.
        Concluding: all my tests passed, meaning it works as designed.
        I will raise an issue for a feature request, but you can either reject it or put it on the bottom of your list of todo’s.
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
          sdetweil @blvk
          @blvk also need
          tineFornat:"absolute"
            blvk @sdetweil
            @sdetweil said in Cant use showEnd icloud cal:
            @blvk also need
            Nothing changed
              sdetweil @blvk
              @blvk turn off showOnlyWithDuration
              this is a whole day, multiday event
              duration is tor a short term event
                blvk @sdetweil
                set to false, no changes, do you need some more informations i can share?
                  sdetweil @blvk
                  @blvk sorry, didn’t think it thru
                  because your events are full day (no time)
                  there is no duration
                  we do not show end for full day events
                  we could, but don’t
                  if (this.config.showEnd) {
                  	if (this.config.showEndsOnlyWithDuration && event.startDate === event.endDate) {
                  	    // no duration here, don't display end
                  	} else {
                  //----- we do this
                  		timeWrapper.innerHTML += "-";
                  			timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
                  	// For full day events we use the fullDayEventDateFormat
                  	if (event.fullDayEvent) {
                          	//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 on the next day
                  	       event.endDate -= ONE_SECOND;
                  /// then change the display of both to just the start
                                 timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
                    sdetweil @blvk
                    @blvk I just added this to the next release calendar
                    you can get my test version and try it out
                    see https://forum.magicmirror.builders/topic/19070/call-for-testers-updated-calendar-module
                    if showEnd:true, and start date is different then end date, then
                    add end date on using dateEndFormat
                    — this (dateEndFormat) might collide with dateEndFormat on events WITH time… need feedback
                    evroomE 1 Reply Last reply Reply Quote 0
                    • evroomE Offline
                      evroom @sdetweil
                      At first sight I do not like it too much.
                      Daily repeating events have an end time now that does not make really sense (23:59) and the Holliday end time only makes sense when the dateEndFormat is extended to see the date.
                      And that makes it pretty crowded in the date/time column.
                      IMHO :-)
                      timeFormat: "absolute",
                      showEnd: true,
                      //dateEndFormat: "HH:mm",
                      dateEndFormat: "dddd MMM D - HH:mm",
                      I currently have
                      but
                      showEndsOnlyWithDuration: false,
                      does not seem to do anything.
                      showEnd: false,
                      //dateEndFormat: "dddd MMM D - HH:mm",
                      Regards,
                      E.J.
                      Test environment:
                        sdetweil @evroom
                        @evroom thanks… that was what I was afraid of
                        can you change line calendar.js 439 to be like this, use the FullDayEventFormat, so not different that begin
                        							timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
                        • evroomE Offline
                          evroom @sdetweil
                          calendar.js
                          ~/MagicMirror/modules/default/calendar/calendar.js
                          showEnd: true,
                          showEnd: false,
                          Test environment:
                          • 1 / 3
