    Finally finished
    17 Posts 5 Posters 11.9k Views 5 Watching
      bluecaka69
      Magic mirror is complete and hanging!!! Ran
      electric wires to plug in behind the mirror to conceal them. Then I integrated the motion sensor into the gang box so you really don’t see it!! Overall I love it
      Mykle1M johnnyboyJ T 3 Replies Last reply Reply Quote 2
        Mykle1 Project Sponsor Module Developer @bluecaka69
        @bluecaka69 That’s good work. Go get yourself a beer. :beer:
        • yawnsY Offline
          yawns Moderator
          Nice work. More pictures and details please
            Mykle1 Project Sponsor Module Developer @yawns
            @yawns said in Finally finished:
            Yeah, I’d like a story, too. And, at the very least, the dimensions and type of mirror glass you used and where you purchased it. (planning my next mirror) :-)
            johnnyboyJ 1 Reply Last reply Reply Quote 0
            • johnnyboyJ Offline
              johnnyboy @bluecaka69
              This post is deleted!
                johnnyboy @Mykle1
                  Mykle1 Project Sponsor Module Developer @johnnyboy
                  @johnnyboy said in Finally finished:
                  Lets hope support for MM lasts eh?
                  By then, “you’ll” be the support.
                    bluecaka69
                    So here’s a break down I used a 19" insignia tv monitor
                    The mirror is a two way smart mirror from http://www.twowaymirrors.com/smart-mirror/
                    The receptacle I used was a combo USB outlet. Is runs 5v 3.6a and powers the tv
                    From
                    http://m.homedepot.com/p/Leviton-15-Amp-Decora-Tamper-Resistant-Combination-Receptacle-and-USB-Charger-White-R02-T5631-00W/205730876?MERCH=REC-_-mobileweb_pip_rr-4-_-205092277-_-205730876-_-N
                    Raspberry pi3 to run magic mirror
                    Pir sensor from adafruit
                    https://www.adafruit.com/product/189
                    I used a three gang outlet box and since I only needed two spaces it allowed me to use a blank insert to mount the pir sensor in.
                    As for the leviton USB outlet I spliced into an outlet I had already installed I spliced into it to run the wires to a gang box behind the mirror. Leaving a seamless look.
                    I made the frame from poplar wood and stained it in ebony color
                    As for modules
                    I am using Wunderground
                    Random quotes
                    Flikr
                    Compliments
                    Date time
                    I kept it simply because i am really new at this but overall I love it
                    Sorry I don’t have more pics I didn’t even think about taking any during the process
                    Mykle1M johnnyboyJ 2 Replies Last reply Reply Quote 1
                      @bluecaka69 said in Finally finished:
                      Again, nice work! take more pictures on your next build. You know you’re gonna build another one.
                        Mykle1 Project Sponsor Module Developer @Mykle1
                        @Mykle1 Is that glass or acrylic? And, 6mm or 3mm?
                          bluecaka69 @Mykle1
                          @Mykle1 this is what I got it is glass and 1/4 in (6mm)
                          http://www.twowaymirrors.com/product/14x18-smart-mirror-sanded-edges/
                              bluecaka69 @johnnyboy
                              @johnnyboy it was rather simply. I used https://github.com/paviro/MMM-PIR-Sensor
                              To run it just remember to use bcm numbering instead of gpio numbering
                              I did extend the wires and I used a ferrite bead to ensure there would be no interference…
                              Since me tv doesn’t have a true power saving I used
                              https://github.com/phrazelle/mm-pir-hide-all
                              To create the illusion it shuts off basically turns the screen black until the pir senses motion
                              johnnyboyJ 1 Reply Last reply Reply Quote 1
                                  @johnnyboy works as expected it is sensitive but there are adjustments on the back of the unit I have my sentivity just a smidge past minimum
                                  • T Offline
                                    Timeeee @bluecaka69
                                    Looks gorgeous! Awesome wood, I love the dark color. :)
                                    Whats the exact glas-size you ordered for the mirror? You mentioned a 19" monitor, so my question basically is how much bigger the mirror glas is.
                                      bluecaka69 @Timeeee
                                      @Timeeee I used a 18x14 glass it’s a the 19 in monitor is about 17.5 inches long so it’s a nice clean yet tight fit
