    MMM-MLB
    Scheduled Pinned Locked Moved Sport
    35 Posts 10 Posters 28.4k Views 10 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer
      Without further delay and a HUGE HUGE Thanks to @strawberry-3-141 I proudly give you ‘focus_on’ ability!!
      You can see all the games in a rotating fashion or just see your favorite team[s]!!
      IF you have the first version installed simply go to your MagicMirror/modules/MMM-MLB directory in a terminal window and type:
      git pull
      New config option:
      focus_on: [“Braves”,“Yankees”]
      Please make sure you put in brackets, capitalize and double quotes if you have more than one team separated by a coma like above.
      See here for complete instructions and ENJOY!!
      Download:
      [card:cowboysdude/MMM-MLB]
      R ooom416354O Mykle1M D 4 Replies Last reply Reply Quote 1
        rodleland @cowboysdude
        @cowboysdude WORKS LIKE A CHARM. AMPED. thank you!
        • ooom416354O Offline
          ooom416354 @cowboysdude
          @cowboysdude love it!!! amazing work!
            Mykle1 Project Sponsor Module Developer @cowboysdude
            @cowboysdude
            You’re a freakin magician and a guru! :clap_tone1:
            cowboysdudeC 1 Reply Last reply Reply Quote 1
              cowboysdude Module Developer @Mykle1
              @Mykle1 said in MMM-MLB:
              @cowboysdude
              Yes with a lot of help from a very good guy! :baseball:
                jimmrr
                @cowboysdude
                Hi, i’ve tried to install this on my magicmirror running on a pi zero, the module will not load in the browser. Any ideas? I have node v6.10.0 and npm 3.10.10.
                pi@raspberrypi:~/MagicMirror $ node serveronly
                Starting MagicMirror: v2.1.0
                Loading config ...
                Loading module helpers ...
                No helper found for module: calendar_monthly.
                All module helpers loaded.
                Starting server op port 8080 ...
                Server started ...
                Connecting socket for: MMM-MLB
                Starting module: MMM-MLB
                Ready to go! Please point your browser to: http://localhost:8080
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @jimmrr
                  @jimmrr i guess you use the midori browser, which cant handle es6 and this module makes use of es6 features
                    Durnumosis @cowboysdude
                    @cowboysdude Thank you so much for your work on this module! I was digging through the code to see how you did it and noticed there’s some code for getting the MLB standings. Is this something that you are actively working on? It would be great to see the scores as well as the standings. Thanks again for a great module!
                      cowboysdude Module Developer @Durnumosis
                      @Durnumosis Well yes I am working on that part :) I’m running into snags so it’s going to be a while… still trying to figure it all out :)
                      Of course the standings is part of the voice part [MMM-voice]… I am also working on a standalone standings module… no voice required…
                        ooom416354
                        Question guys, I have the focus_on set to “Yankees” but today they happen to be off so all I see is the header, with the MLB logo and the text MLB Scores 04/20/2017. Is there a way to hide that if the team that is set in the focus_on is not playing that day?
                        • 2 / 4
