    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 538.4k Views 58 Watching
    • Wilco89W Offline
      Wilco89 @sarthak18593
      @sarthak18593 I could figure it out myself. But i knew some people already working with this module. So they would know that. Only need to activate my camera now.
      • Wilco89W Offline
        Wilco89
        All things are working @ the moment just have to start the training but it’s a bit dark at the moment, so i will wait until tomorrow.
        • KirAsh4K Offline
          KirAsh4 Moderator
          Turn on a light? :)
          Wilco89W 1 Reply Last reply Reply Quote 0
          • Wilco89W Offline
            Wilco89 @KirAsh4
            @KirAsh4 in my coding cave it’s a bit dark :P and totally not the same condition as the kitchen (the place to hang the mirror)
            • KirAsh4K Offline
              KirAsh4 Moderator
              In that case, you need to go up to the kitchen to grab a beer … and do the training. :)
              • Wilco89W Offline
                Wilco89
                then the mirror will only recognize when i’m in the kitchen with a beer:P
                first off all we need to fix @paviro his PIR Sensor module. When everything is working I can/will create the case and hang it on the wall.
                Otherwise my son will destroy it tomorrow morning or my grumpy old cat will play with the cables.
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  PIR Sensor module doesn’t work? I don’t know, I don’t have one … never tried it.
                  • Wilco89W Offline
                    Wilco89
                    When activate it gives a whit screen before startup of the mirror.
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      Oh cool, special effects courtesy the PIR sensor … love it. :)
                      Maybe @paviro should set a delay before activating the sensor reading. I assume that’s wha tit does, like I said, I don’t have a PIR sensor to play with … figured there are enough folks out there doing that already. :)
                      • Wilco89W Offline
                        Wilco89
                        don’t even got to the MM, after the automatic stat of MM the screen is just white :P
                        But when @paviro has some time he will defintly look into it.
                        oder ist das schwierig @paviro ?
                        paviroP 1 Reply Last reply Reply Quote 0
                        • KirAsh4K Offline
                          KirAsh4 Moderator
                          Yeah, I don’t know that module, or where it’s actually failing. But I can imagine if MM is initializing and the sensor is also doing something, things can go wrong. That’s why I suggested a delay.
                          The touch sensor I’m playing with has a built-in 4 seconds delay before it becomes active, then it spends 5 to (no more than) 10 seconds calibrating itself. So plenty of time for MM to start up completely before the sensor starts “talking” to the rpi.
                          • paviroP Offline
                            paviro @Wilco89
                            @Wilco89 No will do but I have so much stuff on my hand at the moment… Moving to Berlin in August etc…
                            We're all stories in the end. Just make it a good one, eh?
                            – The Doctor
                            • Wilco89W Offline
                              Wilco89
                              @paviro wir warten noch ein Moment. Viel Spaß im Berlin.
                              I hope everything is going well with the move to Berlin. So everybody will be happy in a few weeks.
                              • X Offline
                                xdker
                                why?
                                ^CTraceback (most recent call last):
                                  File "capture.py", line 35, in <module>
                                    capture.capture()
                                  File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 53, in capture
                                    if is_letter_input('c'):
                                  File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 23, in is_letter_input
                                    input_char = raw_input()
                                KeyboardInterrupt
                                Note from admin: Please use Markdown on shell snippets!
                                • X Offline
                                  xdker
                                  This post is deleted!
                                  • paviroP Offline
                                    paviro
                                    Looks like you terminated the process by pressing ctrl-C or strg-C, just press c and then enter and no other key with the c.
                                    – The Doctor
                                    X 1 Reply Last reply Reply Quote 0
                                    • X Offline
                                      xdker @paviro
                                      @paviro
                                      Oh sorry, I’m sorry I didn’t notice.
                                      But there are the following tips.
                                      where is capture.pgm not in the name of the folder.
                                      Could not detect single face!  Check the image in capture.pgm to see what was captured and try again with only one face visible.
                                      • P Offline
                                        plumcraft
                                        Hi everyone,
                                        I have the same issue.
                                        What do you want to do?
                                        [1] Capture training images from webcam
                                        [2] Convert ‘*.jpg’ pictures from other cameras to training images
                                        –> 1
                                        Enter the name of the person you want to capture or convert images for.
                                        –> olifier
                                        Images will be placed in ./training_data/olifier
                                        Starting process…
                                        Capturing positive training images.
                                        Type c (and press enter) to capture an image.
                                        Press Ctrl-C to quit.
                                        c
                                        Capturing image…
                                        Thanks a lot
                                          sarthak18593 @plumcraft
                                          @plumcraft Are you using the Pi camera module or a usb webcam ?
                                          • P Offline
                                            plumcraft @sarthak18593
                                            @sarthak18593
                                            I’m using the pi camera module. It’s correctly enable from the raspi config tool.
                                            • 10
                                            • 11
                                            • 3 / 11
