    Simple Music Player Module
    19 Posts 11 Posters 18.0k Views 9 Watching
    • KirAsh4K
      KirAsh4 Moderator
      [UNTESTED] For those who don’t (or can’t) use a touch screen, I believe not installing unclutter would give them mouse control.
      • paviroP
        paviro
        No it would not since the css also hides the cursor I think :/
        – The Doctor
        • KirAsh4K
          KirAsh4 Moderator
          Well, certainly installing it won’t help. :) But yeah, if CSS is hiding it too, then it’s a moot point.
          MichMichM EoFE 2 Replies Last reply
          • MichMichM
            MichMich @KirAsh4
            @KirAsh4 You could overwrite that in the custom.css
            EoFE 1 Reply Last reply
            • EoFE
              EoF @MichMich
              @MichMich Yep if you look in the css file in the module, you will see a line at the top that is commented out for displaying the cursor.
              • EoFE
                EoF @KirAsh4
                @KirAsh4 With a touch screen, you wouldn’t need to see the cursor anyways. Which is why I left it as is :)
                Edit: I’m also getting my mirror film today, so I can finally test later whether or not it will work on a capacitive based touch screen.
                I’ll post results!
                KirAsh4K N 2 Replies Last reply
                • KirAsh4K
                  KirAsh4 Moderator @EoF
                  @EoF, correct. That’s why I said, for those who can’t or don’t want to just a touchscreen. They will need a different method to interact with the display.
                  • EoFE
                    EoF @KirAsh4
                    @KirAsh4 Ah okay, yep that is correct. If we had a reliable way to do voice recognition, then I would gladly implement it into this.
                    M 1 Reply Last reply
                    • KirAsh4K
                      KirAsh4 Moderator
                      Where there’s a will, there’s a way.
                      • EoFE
                        EoF @KirAsh4
                        @KirAsh4 Amen to that
                        • M
                          MechMatt @EoF
                          @EoF I saw a guy posted on reddit his magic mirror with voice control (he is using this build of MM). He posted this link for how he set up the voice activation part:
                          https://howchoo.com/g/yti5mmq0ntu/add-voice-controls-to-your-raspberry-pi-using-jasper
                          don’t know if this helps, but maybe worth looking at. It would definitely be cool to say “MM Play Classic Rock” and it loads up.
                          Also, is it possible to, instead of loading all the music on the pi itself, have it stream from a pandora/spotify type site?
                          • EoFE
                            EoF @MechMatt
                            @MechMatt Alright cool I can take a look at it.
                            As far as the steaming goes, you may want to check out PtrBld’s module. He has streaming working in his module.
                            I may look into building a new module that uses Pandora in the future.
                            • N
                              nobiryu @EoF
                              @EoF have you been able to use the reflective film and still retain the touch ability on your screen?
                              If so what kind are you using. I’m looking at using the same type that you can find for car window tinting.
                              • EoFE
                                EoF @nobiryu
                                @nobiryu Hello! Please see this post.
                                https://forum.magicmirror.builders/topic/166/eof-s-touch-screen-magic-mirror-testing-phase
                                • D
                                  denalove
                                  I am experiencing a black blank screen after installing the music player code. Here is my code
                                  Loading config ...
                                  Loading module helpers ...
                                  No helper found for module: mm-music-player.
                                  All module helpers loaded.
                                  Starting server op port 8080 ...
                                  Server started ...
                                  Starting module: newsfeed
                                  Launching application.
                                  I’ve only customized the calendar so far, haven’t messed with the other modules just yet. Anyone know what I’m doing wrong?
                                  Edit from admin: Please use Markdown on shell output so it is easier to read!
                                  D 1 Reply Last reply
                                  • D
                                    denalove @denalove
                                    @denalove I got it, found the solution. I added the module to the defaultmodules.js file and it didn’t need to be there.
                                    • EoFE
                                      EoF @denalove
                                      @denalove Happy to hear it, hope you enjoy the module :)
                                      • D
                                        dbaler
                                        Would you be able to pull files from a server using this module? What would I need to do to change that?
                                        • F
                                          fabrang
                                          @EoF I updated my Magic Mirror on 2.1.1. I wanted to try your modul but after copying it into my modules folder and adding the module in the config, I started the mirror and get a blackscreen. I’ve read that more people got the same issue.
                                          Got an Idea what’s the problem? :)
