    Bonding glass and MDF
    12 Posts 5 Posters 9.7k Views 4 Watching
    • O Offline
      ontheway16
      Hello all, I am planning to build my first magic mirror but unfortunately all build examples are based on a wooden frame. My magic mirror is planned as frameless. I want to someway glue a mdf backplate to twoway mirror, and want to hear your opinions about glue choices.
      My first idea is using a 3m double sided tape (black). Do you know/advise any other options to hang 140cm x 50 cm mirror to wall, without using an outer frame? Thanks,
      Alp
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @ontheway16
        This post is deleted!
        • O Offline
          ontheway16
          I am afraid I have no other choices. Was looking around and found these;
          http://www.doityourself.com/stry/how-to-glue-wood-to-glass
          http://audiokarma.org/forums/index.php?threads/best-way-to-glue-glass-to-mdf.329230/
          http://www.woodweb.com/knowledge_base/Gluing_Painted_Glass_to_Wood_or_MDF.html
          johnnyboyJ B 2 Replies Last reply Reply Quote 0
              broberg Project Sponsor @ontheway16
              @ontheway16 as @johnnyboy mentioned, the 2 way mirrors often has the mirror coating on one side which can react to the glue and/or seperate from the glass. If you’re not sure do consult the manufacturer of the mirror you are using!
              • O Offline
                ontheway16 @broberg
                @broberg @johnnyboy Thanks for the replies, I will ask the manufacturer whether its a first or second surface mirror (https://spectrumscientifics.wordpress.com/2011/07/13/first-and-second-surface-mirrors/)
                Best thing I can do will be testing glue alternatives on a piece of 2way mirror I am going to use, I think…
                • G Offline
                  Goldjunge_Chriz
                  There are special double-sided mounting adhesive tapes for different material combinations. For example, I built an aluminum frame and glued the glass with a glass / aluminum strip from Würth. Holds bombproof and gives no problems with my mirror and the surface. ;)
                  • Y Offline
                    yawns Moderator @Goldjunge_Chriz
                    @Goldjunge_Chriz
                    So your (and also mine) mirror glass can be glued to a surface?
                    • G Offline
                      Goldjunge_Chriz @yawns
                      @yawns
                      Absolutely ;) you can see that on my pictures too :)
                      O Y 2 Replies Last reply Reply Quote 1
                      • O Offline
                        ontheway16 @Goldjunge_Chriz
                        @Goldjunge_Chriz said in Bonding glass and MDF:
                        @yawns
                        Can you please post a link about it?
                        Is it the tape below?
                        https://eshop.wuerth.de/Product-categories/Mirror-adhesive-tape/14013004040301.cyid/1401.cgid/en/US/EUR/
                        • Y Offline
                          @yawns
                          :heart: :thumbsup:
                          • G Offline
                            Goldjunge_Chriz @ontheway16
                            @ontheway16 said in Bonding glass and MDF:
                            @yawns
                            I took the adhesive tape from my company warehouse, we are engaged in glass / aluminum facade construction. Therefore, I do not know the exact order number. The adhesive tape is called “Würth Montageband Power”
