    Weather
    28 Posts 7 Posters 18.4k Views 6 Watching
      relluts
      Lost my weather when i put in location and api
        relluts
        Nevermind. Got it resolved.
        • G Offline
          Gamble
          What did you do? mine is doing this
            Mykle1 Project Sponsor Module Developer @Gamble
            @Gamble said in Weather:
            Post your weather config.js entry here using this guide
            https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
            • G Offline
              Gamble
              var config = {
                     port: 8080,
                     language: "en",
                     timeFormat: 12,
                     units: "imperial",
                                     module: "updatenotification",
                                     position: "top_bar"
                                     module: "clock",
                                     position: "top_left"
                                     header: "US Holidays",
                                                             symbol: "calendar-check-o ",
                                                             url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                     module: "compliments",
                                     position: "lower_third"
                                     module: "currentweather",
                                             locationID: "4899154",  //ID from http://www.openweathermap.org/help/city_list.txt
                                             appid: "8cfa7d38943405ef3da2456894ea1143"
                                     module: "weatherforecast",
                                     header: "Weather Forecast",
                                     module: "newsfeed",
                                     position: "bottom_bar",
                                             feeds: [
                                                             title: "Chicago",
                                                             url: "feeds.foxnews.com/foxnews/latest"
                                     position: "bottom_left",
                                     module: "newsfeed",
                                             feeds: [
                                                             title: "Chicago",
                                             showSourceTitle: true,
                                             showPublishDate: true
              I still need to add the MMM-trello but for now JSlint.com is giving me an error and I can’t figure it out.
              So for right now it doesn’t even load
              • cowboysdudeC Offline
                cowboysdude Module Developer @Gamble
                @Gamble Here is a valid config… there were a few errors in it… the very end you had },
                should be };
                Happens to the best of us :) Once you get this working as is then make a copy of it and add your Trello module… that way if you have a problem you ALWAYS have a backup of a good working config ;)
                var config = {
                port: 8080,
                language: "en",
                timeFormat: 12,
                units: "imperial",
                modules: [{
                        position: "top_bar"
                        module: "clock",
                            calendars: [{
                        module: "newsfeed",
                            feeds: [{
                                title: "Chicago",
                        module: "newsfeed",
                            feeds: [{
                                title: "Chicago",
                • G Offline
                  Gamble
                  Thanks but I still have an error and it’s not loading. Can you have a look at 61
                  var config = {
                  port: 8080,
                  language: "en",
                  timeFormat: 12,
                  units: "imperial",
                  modules: [{
                          position: "top_bar"
                          module: "clock",
                              calendars: [{
                          module: "newsfeed",
                              feeds: [{
                                  title: "Chicago",
                          module: "newsfeed",
                              feeds: [{
                                  title: "Chicago",
                  Mykle1M V 2 Replies Last reply Reply Quote 0
                    Remove the comma
                      You also have 2 newsfeed entries with the same url
                      • G Offline
                        Gamble
                        Which comma?
                        I deleted the second newsfeed so now it’s error on line 51 but I don’t see a comma.
                        var config = {
                        port: 8080,
                        language: "en",
                        timeFormat: 12,
                        units: "imperial",
                        modules: [{
                                position: "top_bar"
                                module: "clock",
                                    calendars: [{
                                module: "newsfeed",
                                    feeds: [{
                                        title: "Chicago",
                                module: "newsfeed",
                                    feeds: [{
                                        title: "Chicago",
                          go to line 51 you have it like this
                          SHOULD BE
                          Check the example here:
                          https://github.com/MichMich/MagicMirror/tree/master/modules/default/newsfeed
                            Because you deleted it? :^)
                            You should read this:
                            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                            • G Offline
                              Gamble @cowboysdude
                              @cowboysdude said in Weather:
                              SHOULD BE
                              still not working :(
                                Just repost your entire config minus api keys…
                                  My suggestion:
                                  Start with a new config and get that working first.
                                  https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                                  Then when you want to add a module:
                                  These tutorials walk you through the process. All you have to do is follow them line by line. There’s no guesswork. In the time that it takes you to read them, you’ll already be up and running, and you’ll learn something.
                                  • G Offline
                                    Gamble
                                    i think my sample file is jacked up. do we have another one on here i can download or copy/paste the code?
                                      ranger33 @Gamble
                                      @Gamble your sample is corrupted? That’s odd…
                                      https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
                                      Here’s the sample config!
                                      • G Offline
                                        Gamble @ranger33
                                        @ranger33
                                        Thanks. I got it to work as default and started to changes things one by one like the weather and news
                                        But I put the trello app over the compliments module and it says invalid file. i put the compliments back in and now it’s all just a big black blank screen. i’m pretty confused here
                                          ranger33
                                          When you say put the trello app over compliments what do you mean? If you can explain a bit more we can certainly help yah just need to see what you’re seeing.
                                          • G Offline
                                            Gamble
                                            I don’t want the compliments so i replaced the compliments text with the trello text. Every time I add the trello it says it’s not a valid file
                                            So here is what I did. I started from scratch with the sample file and it works or at least it worked the first time. Seems nomatter what changes the weather doesn’t display at all. I also have a nightmare of a time exiting the magic mirror app. I’ll do a control f4 and it closes and reopens right away. Or i’ll go to terminal and do a controlx then alt F4 to close the magic mirror and it freezes EVERY time. i have to reboot this pi every time i want to change something, it’s incredibility slow
                                            For the news. I’ve tried changing the URL to a google news, abc7, or anything else I find and it just says loading. i even tried changing one little thing at at time and it still doesn’t work. i’ll post the code in a min. the pi is still loading the browser.
