    Weather
    28 Posts 7 Posters 16.7k Views 6 Watching
    • G Offline
      Gamble
      var config = {
             port: 8080,
             language: "en",
             timeFormat: 12,
             units: "imperial",
                             module: "updatenotification",
                             position: "top_bar"
                             module: "clock",
                             position: "top_left"
                             header: "US Holidays",
                                                     symbol: "calendar-check-o ",
                             module: "compliments",
                             position: "lower_third"
                             module: "currentweather",
                                     locationID: "4899154",  //ID from http://www.openweathermap.org/help/city_list.txt
                                     appid: "8cfa7d38943405ef3da2456894ea1143"
                             module: "weatherforecast",
                             header: "Weather Forecast",
                             module: "newsfeed",
                             position: "bottom_bar",
                                     feeds: [
                                                     title: "Chicago",
                                                     url: "feeds.foxnews.com/foxnews/latest"
                             position: "bottom_left",
                             module: "newsfeed",
                                     feeds: [
                                                     title: "Chicago",
                                     showSourceTitle: true,
                                     showPublishDate: true
      I still need to add the MMM-trello but for now JSlint.com is giving me an error and I can’t figure it out.
      So for right now it doesn’t even load
      • cowboysdudeC Offline
        cowboysdude Module Developer @Gamble
        @Gamble Here is a valid config… there were a few errors in it… the very end you had },
        should be };
        Happens to the best of us :) Once you get this working as is then make a copy of it and add your Trello module… that way if you have a problem you ALWAYS have a backup of a good working config ;)
        var config = {
        port: 8080,
        language: "en",
        timeFormat: 12,
        units: "imperial",
        modules: [{
                position: "top_bar"
                module: "clock",
                    calendars: [{
                module: "newsfeed",
                    feeds: [{
                        title: "Chicago",
                module: "newsfeed",
                    feeds: [{
                        title: "Chicago",
        • G Offline
          Gamble
          Thanks but I still have an error and it’s not loading. Can you have a look at 61
          var config = {
          port: 8080,
          language: "en",
          timeFormat: 12,
          units: "imperial",
          modules: [{
                  position: "top_bar"
                  module: "clock",
                      calendars: [{
                  module: "newsfeed",
                      feeds: [{
                          title: "Chicago",
                  module: "newsfeed",
                      feeds: [{
                          title: "Chicago",
          Mykle1M V 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @Gamble
            @Gamble said in Weather:
            Remove the comma
              You also have 2 newsfeed entries with the same url
              • G Offline
                Gamble
                Which comma?
                I deleted the second newsfeed so now it’s error on line 51 but I don’t see a comma.
                var config = {
                port: 8080,
                language: "en",
                timeFormat: 12,
                units: "imperial",
                modules: [{
                        position: "top_bar"
                        module: "clock",
                            calendars: [{
                        module: "newsfeed",
                            feeds: [{
                                title: "Chicago",
                        module: "newsfeed",
                            feeds: [{
                                title: "Chicago",
                  go to line 51 you have it like this
                  SHOULD BE
                  Check the example here:
                  https://github.com/MichMich/MagicMirror/tree/master/modules/default/newsfeed
                    Because you deleted it? :^)
                    You should read this:
                    https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                    • G Offline
                      Gamble @cowboysdude
                      @cowboysdude said in Weather:
                      SHOULD BE
                      still not working :(
                        Just repost your entire config minus api keys…
