    Weather
    28 Posts 7 Posters 16.7k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @Gamble
      @Gamble said in Weather:
      What did you do? mine is doing this
      Post your weather config.js entry here using this guide
      https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
      • G Offline
        Gamble
        var config = {
               port: 8080,
               language: "en",
               timeFormat: 12,
               units: "imperial",
                               module: "updatenotification",
                               position: "top_bar"
                               module: "clock",
                               position: "top_left"
                               header: "US Holidays",
                                                       symbol: "calendar-check-o ",
                               module: "compliments",
                               position: "lower_third"
                               module: "currentweather",
                                       locationID: "4899154",  //ID from http://www.openweathermap.org/help/city_list.txt
                                       appid: "8cfa7d38943405ef3da2456894ea1143"
                               module: "weatherforecast",
                               header: "Weather Forecast",
                               module: "newsfeed",
                               position: "bottom_bar",
                                       feeds: [
                                                       title: "Chicago",
                                                       url: "feeds.foxnews.com/foxnews/latest"
                               position: "bottom_left",
                               module: "newsfeed",
                                       feeds: [
                                                       title: "Chicago",
                                       showSourceTitle: true,
                                       showPublishDate: true
        I still need to add the MMM-trello but for now JSlint.com is giving me an error and I can’t figure it out.
        So for right now it doesn’t even load
        • cowboysdudeC Offline
          cowboysdude Module Developer @Gamble
          @Gamble Here is a valid config… there were a few errors in it… the very end you had },
          should be };
          Happens to the best of us :) Once you get this working as is then make a copy of it and add your Trello module… that way if you have a problem you ALWAYS have a backup of a good working config ;)
          var config = {
          port: 8080,
          language: "en",
          timeFormat: 12,
          units: "imperial",
          modules: [{
                  position: "top_bar"
                  module: "clock",
                      calendars: [{
                  module: "newsfeed",
                      feeds: [{
                          title: "Chicago",
                  module: "newsfeed",
                      feeds: [{
                          title: "Chicago",
          • G Offline
            Gamble
            Thanks but I still have an error and it’s not loading. Can you have a look at 61
            var config = {
            port: 8080,
            language: "en",
            timeFormat: 12,
            units: "imperial",
            modules: [{
                    position: "top_bar"
                    module: "clock",
                        calendars: [{
                    module: "newsfeed",
                        feeds: [{
                            title: "Chicago",
                    module: "newsfeed",
                        feeds: [{
                            title: "Chicago",
            Mykle1M V 2 Replies Last reply Reply Quote 0
              Remove the comma
                You also have 2 newsfeed entries with the same url
                • G Offline
                  Gamble
                  Which comma?
                  I deleted the second newsfeed so now it’s error on line 51 but I don’t see a comma.
                  var config = {
                  port: 8080,
                  language: "en",
                  timeFormat: 12,
                  units: "imperial",
                  modules: [{
                          position: "top_bar"
                          module: "clock",
                              calendars: [{
                          module: "newsfeed",
                              feeds: [{
                                  title: "Chicago",
                          module: "newsfeed",
                              feeds: [{
                                  title: "Chicago",
                    go to line 51 you have it like this
                    SHOULD BE
                    Check the example here:
                    https://github.com/MichMich/MagicMirror/tree/master/modules/default/newsfeed
                      Because you deleted it? :^)
                      You should read this:
                      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                      • G Offline
                        Gamble @cowboysdude
                        @cowboysdude said in Weather:
                        SHOULD BE
                        still not working :(
