    Weather
    28 Posts 7 Posters 19.0k Views 6 Watching
      relluts
      Nevermind. Got it resolved.
      • G Offline
        Gamble
        What did you do? mine is doing this
          Mykle1 Project Sponsor Module Developer @Gamble
          @Gamble said in Weather:
          Post your weather config.js entry here using this guide
          https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
          • G Offline
            Gamble
            var config = {
                   port: 8080,
                   language: "en",
                   timeFormat: 12,
                   units: "imperial",
                                   module: "updatenotification",
                                   position: "top_bar"
                                   module: "clock",
                                   position: "top_left"
                                   header: "US Holidays",
                                                           symbol: "calendar-check-o ",
                                   module: "compliments",
                                   position: "lower_third"
                                   module: "currentweather",
                                           locationID: "4899154",  //ID from http://www.openweathermap.org/help/city_list.txt
                                           appid: "8cfa7d38943405ef3da2456894ea1143"
                                   module: "weatherforecast",
                                   header: "Weather Forecast",
                                   module: "newsfeed",
                                   position: "bottom_bar",
                                           feeds: [
                                                           title: "Chicago",
                                                           url: "feeds.foxnews.com/foxnews/latest"
                                   position: "bottom_left",
                                   module: "newsfeed",
                                           feeds: [
                                                           title: "Chicago",
                                           showSourceTitle: true,
                                           showPublishDate: true
            I still need to add the MMM-trello but for now JSlint.com is giving me an error and I can’t figure it out.
            So for right now it doesn’t even load
            • cowboysdudeC Offline
              cowboysdude Module Developer @Gamble
              @Gamble Here is a valid config… there were a few errors in it… the very end you had },
              should be };
              Happens to the best of us :) Once you get this working as is then make a copy of it and add your Trello module… that way if you have a problem you ALWAYS have a backup of a good working config ;)
              var config = {
              port: 8080,
              language: "en",
              timeFormat: 12,
              units: "imperial",
              modules: [{
                      position: "top_bar"
                      module: "clock",
                          calendars: [{
                      module: "newsfeed",
                          feeds: [{
                              title: "Chicago",
                      module: "newsfeed",
                          feeds: [{
                              title: "Chicago",
              • G Offline
                Gamble
                Thanks but I still have an error and it’s not loading. Can you have a look at 61
                var config = {
                port: 8080,
                language: "en",
                timeFormat: 12,
                units: "imperial",
                modules: [{
                        position: "top_bar"
                        module: "clock",
                            calendars: [{
                        module: "newsfeed",
                            feeds: [{
                                title: "Chicago",
                        module: "newsfeed",
                            feeds: [{
                                title: "Chicago",
                Mykle1M V 2 Replies Last reply Reply Quote 0
                  Remove the comma
                    You also have 2 newsfeed entries with the same url
                    • G Offline
                      Gamble
                      Which comma?
                      I deleted the second newsfeed so now it’s error on line 51 but I don’t see a comma.
                      var config = {
                      port: 8080,
                      language: "en",
                      timeFormat: 12,
                      units: "imperial",
                      modules: [{
                              position: "top_bar"
                              module: "clock",
                                  calendars: [{
                              module: "newsfeed",
                                  feeds: [{
                                      title: "Chicago",
                              module: "newsfeed",
                                  feeds: [{
                                      title: "Chicago",
                        go to line 51 you have it like this
                        SHOULD BE
                        Check the example here:
                        https://github.com/MichMich/MagicMirror/tree/master/modules/default/newsfeed
                          Because you deleted it? :^)
                          You should read this:
                          https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                          • G Offline
                            Gamble @cowboysdude
                            @cowboysdude said in Weather:
                            SHOULD BE
                            still not working :(
                              Just repost your entire config minus api keys…
                                My suggestion:
                                Start with a new config and get that working first.
                                https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                                Then when you want to add a module:
                                These tutorials walk you through the process. All you have to do is follow them line by line. There’s no guesswork. In the time that it takes you to read them, you’ll already be up and running, and you’ll learn something.
                                • G Offline
                                  Gamble
                                  i think my sample file is jacked up. do we have another one on here i can download or copy/paste the code?
                                    ranger33 @Gamble
                                    @Gamble your sample is corrupted? That’s odd…
                                    https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
                                    Here’s the sample config!
                                    • G Offline
                                      Gamble @ranger33
                                      @ranger33
                                      Thanks. I got it to work as default and started to changes things one by one like the weather and news
                                      But I put the trello app over the compliments module and it says invalid file. i put the compliments back in and now it’s all just a big black blank screen. i’m pretty confused here
                                        ranger33
                                        When you say put the trello app over compliments what do you mean? If you can explain a bit more we can certainly help yah just need to see what you’re seeing.
                                        • G Offline
                                          Gamble
                                          I don’t want the compliments so i replaced the compliments text with the trello text. Every time I add the trello it says it’s not a valid file
                                          So here is what I did. I started from scratch with the sample file and it works or at least it worked the first time. Seems nomatter what changes the weather doesn’t display at all. I also have a nightmare of a time exiting the magic mirror app. I’ll do a control f4 and it closes and reopens right away. Or i’ll go to terminal and do a controlx then alt F4 to close the magic mirror and it freezes EVERY time. i have to reboot this pi every time i want to change something, it’s incredibility slow
                                          For the news. I’ve tried changing the URL to a google news, abc7, or anything else I find and it just says loading. i even tried changing one little thing at at time and it still doesn’t work. i’ll post the code in a min. the pi is still loading the browser.
                                          • G Offline
                                            Gamble
                                            /* Magic Mirror Config Sample
                                            • MIT Licensed.
                                            • For more information how you can configurate this file
                                            • See https://github.com/MichMich/MagicMirror#configuration
                                            var config = {
                                            port: 8080,
                                            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                                            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                                            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                                            language: "en",
                                            timeFormat: 12,
                                            units: "metric",
                                            		module: "alert",
                                            		position: "top_bar"
                                            		module: "clock",
                                            		module: "MMM-Trello",
                                            			api_key: "**************",
                                            			token: "https://trello.com/1/authorize?expiration=never&scope=read&response_type=token&name=Server%20Token&key=**********",
                                            			list: "************"
                                            			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            		module: "newsfeed",
                                            			feeds: [
                                            					title: "Chicago",
                                            if (typeof module !== “undefined”) {module.exports = config;}
