    Weather
    28 Posts 7 Posters 19.0k Views 6 Watching
      You also have 2 newsfeed entries with the same url
      • G Offline
        Gamble
        Which comma?
        I deleted the second newsfeed so now it’s error on line 51 but I don’t see a comma.
        var config = {
        port: 8080,
        language: "en",
        timeFormat: 12,
        units: "imperial",
        modules: [{
                module: "updatenotification",
                position: "top_bar"
                module: "clock",
                position: "top_left"
                header: "US Holidays",
                    calendars: [{
                        symbol: "calendar-check-o ",
                module: "compliments",
                position: "lower_third"
                module: "currentweather",
                    locationID: "4899154", //ID from http://www.openweathermap.org/help/city_list.txt
                    appid: "8cfa7d38943405ef3da2456894ea1143"
                module: "newsfeed",
                position: "bottom_bar",
                    feeds: [{
                        title: "Chicago",
                        url: "feeds.foxnews.com/foxnews/latest"
                module: "weatherforecast",
                header: "Weather Forecast",
                module: "newsfeed",
                    feeds: [{
                        title: "Chicago",
                    showSourceTitle: true,
                    showPublishDate: true
        • cowboysdudeC Offline
          go to line 51 you have it like this
          SHOULD BE
          Check the example here:
          https://github.com/MichMich/MagicMirror/tree/master/modules/default/newsfeed
            Mykle1 Project Sponsor Module Developer @Gamble
            @Gamble said in Weather:
            Because you deleted it? :^)
            You should read this:
            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
            • G Offline
              Gamble @cowboysdude
              @cowboysdude said in Weather:
              SHOULD BE
              still not working :(
                Just repost your entire config minus api keys…
                  My suggestion:
                  Start with a new config and get that working first.
                  https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                  Then when you want to add a module:
                  These tutorials walk you through the process. All you have to do is follow them line by line. There’s no guesswork. In the time that it takes you to read them, you’ll already be up and running, and you’ll learn something.
                  • G Offline
                    Gamble
                    i think my sample file is jacked up. do we have another one on here i can download or copy/paste the code?
                      ranger33 @Gamble
                      @Gamble your sample is corrupted? That’s odd…
                      https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
                      Here’s the sample config!
                      • G Offline
                        Gamble @ranger33
                        @ranger33
                        Thanks. I got it to work as default and started to changes things one by one like the weather and news
                        But I put the trello app over the compliments module and it says invalid file. i put the compliments back in and now it’s all just a big black blank screen. i’m pretty confused here
                          ranger33
                          When you say put the trello app over compliments what do you mean? If you can explain a bit more we can certainly help yah just need to see what you’re seeing.
                          • G Offline
                            Gamble
                            I don’t want the compliments so i replaced the compliments text with the trello text. Every time I add the trello it says it’s not a valid file
                            So here is what I did. I started from scratch with the sample file and it works or at least it worked the first time. Seems nomatter what changes the weather doesn’t display at all. I also have a nightmare of a time exiting the magic mirror app. I’ll do a control f4 and it closes and reopens right away. Or i’ll go to terminal and do a controlx then alt F4 to close the magic mirror and it freezes EVERY time. i have to reboot this pi every time i want to change something, it’s incredibility slow
                            For the news. I’ve tried changing the URL to a google news, abc7, or anything else I find and it just says loading. i even tried changing one little thing at at time and it still doesn’t work. i’ll post the code in a min. the pi is still loading the browser.
                            • G Offline
                              Gamble
                              /* Magic Mirror Config Sample
                              • MIT Licensed.
                              • For more information how you can configurate this file
                              • See https://github.com/MichMich/MagicMirror#configuration
                              var config = {
                              port: 8080,
                              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                              language: "en",
                              timeFormat: 12,
                              units: "metric",
                              		module: "alert",
                              		position: "top_bar"
                              		module: "clock",
                              		module: "MMM-Trello",
                              			api_key: "**************",
                              			token: "https://trello.com/1/authorize?expiration=never&scope=read&response_type=token&name=Server%20Token&key=**********",
                              			list: "************"
                              			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                              			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                              		module: "newsfeed",
                              			feeds: [
                              					title: "Chicago",
                              if (typeof module !== “undefined”) {module.exports = config;}
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @Gamble
                                @Gamble you have two mistakes
                                1. position: "lower_third" has to be ````position: “lower_third”,``` (comma at the end)
                                has to be
                                missing closing curly bracket at the end
                                • G Offline
                                  Gamble
                                  Thanks.
                                  One step closer!
                                  Weather doesn’t load and neither does trello. So how would I start to figure out why they don’t show up? All the text looks corrrect
                                    @Gamble
                                    In the time it takes to read these, you could be up and running. Or, you could continue the way you have been.
                                    • G Offline
                                      Gamble
                                      I’ve read them a few times. My understanding of them is pretty limited.
                                      Could this be the reason? Although it says no helper module for clock but that still works.
                                      Starting MagicMirror: v2.1.2
                                      Loading config …
                                      Loading module helpers …
                                      No helper found for module: MMM-Trello.
                                      All module helpers loaded.
                                      Starting server on port 8080 …
                                      Server started …
                                      Starting module: newsfeed
                                      Sockets connected & modules started …
                                      Launching application.
                                      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                                      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                        cowboysdude Module Developer @Gamble
                                        @Gamble Well that’s because the clock doesn’t have a node_helper… nor do the weather modules… not sure about Trello…
                                        • G Offline
                                          Gamble
                                          what really blows my mind is that the weather will work then the only thing i do is change the name from New York to chicago then it literally shits the bed. I read the tutorials and still can’t get the weather or trello to work
                                          I also found conflicting things on trello where one says for the list you need the ID and the other says you need the url then add .json to the end. Neither of which work
                                          • V Offline
                                            videogame95 @Gamble
                                            @Gamble the weater open maps isn’t working .
                                            Use a different module . If you configuration isn’t loading delet use the sample copy its rename it as a copy.
                                            Change the sample
                                            Config.js
                                            Start again .
                                            I deleted the weather module
                                            Add found a different on the works modules .
                                            Reinstall everything.
                                            Once you get to a point of things working put an ad card adpter
                                            In the pi with a new sd card make a copy.
                                            This if you get stuck and can’t fix use your backup copy
                                            But remember copy that one.
                                            All bracks with a }, have to line up in your code config file.
                                            .and try to line up module inline with others.
                                            I hope this is some help
                                            as in space x test flight go wrong well learn more evey time we fix it.
                                            Good luck
