    MMM-cryptocurrency - v1.4
    77 Posts 21 Posters 102.8k Views 25 Watching
    • C Offline
      canadrian @matteodanelli
      @matteodanelli works great, thank you!
      • SvenSommerS Offline
        SvenSommer
        Hey @matteodanelli ,
        thank you for this great module.
        I added an alternative display mode to see the changes within the logo view.
        I made a pull request. Here are the changes:
        • 1 hour , 1 day and 7days changes can be displayed by adding ‘logoWithChanges’ as display type.
        • option and screenshots added to README.md
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
        M foxF 2 Replies Last reply Reply Quote 0
          matteodanelli @SvenSommer
          @SvenSommer Thank you! Great additions!
            rmeskill
            Is there a way to add a custom page within the module? I’m specifically looking to add more coins of my own that you don’t include by default, but every time I do it gets overwritten by a pull.
              matteodanelli @rmeskill
              @rmeskill Hi, sure! You can contribute to the project if you want :)
              You can either create a fork of my repository and develop it with your needs. But you’ll lose my updates.
              Else, to keep updated, fork the repository and then make a pull request to merge your fork with my repository.
              I’ll accept it and everyone will have your useful work :)
              • foxF Offline
                fox @SvenSommer
                @SvenSommer Amazing Changes.
                Thank you both. My question:
                How to change the font size?
                I was in MMM-cryptocurrency.css but there is no font.
                thanks
                edit: i found it
                .mmm-cryptocurrency-icon > tr > td {
                    padding-bottom: 10px;
                    text-align: left;
                	font-size: 80%;
                How can i show other graphs?
                Bild Text
                  matteodanelli @fox
                  @fox Hi,
                  About the graphs, you should add your currency inside sparklineIds array (in Js file), which have to be taken directly from coinmarketcap.com.
                  Let me know if it works!
                  foxF 1 Reply Last reply Reply Quote 1
                  • foxF Offline
                    fox @matteodanelli
                    @matteodanelli thank you.
                    But i dont know where the sparkline Id is written in coinmarketcap.
                    e.g. for IOTA: https://coinmarketcap.com/currencies/iota/#tools ?
                      matteodanelli @fox
                      @fox You can find id in the homepage of coinmarketcap. Just get the link of the image of the graph of the desired currency.
                      EG. For IOTA, link is https://files.coinmarketcap.com/generated/sparklines/1720.png, so id is 1720.
                      • foxF Offline
                        fox @matteodanelli
                        @matteodanelli Thank you! It worked and again - what an amazing module. Thank you very much.
                        • foxF Offline
                          fox
                          @matteodanelli , @Klizzy
                          a portfolio view would be amazing, what do you think?
                          Like on the iOS app delta or on cryptocompare or etc. portfolios.
                          But its harder to implement i think because its the view of each MagicMirror User’s portfolio ?!
                          • C Offline
                            canadrian @fox
                            @fox said in MMM-cryptocurrency - v1.4:
                            alternate way, use maybe coinfolium.com, generate your link and use iframe in the mirror
                            • foxF Offline
                              fox @canadrian
                              @canadrian
                              thank you i will give it a try. But i have to maintain the link after every trade?
                              @matteodanelli
                              what is my problem with bitcoin-gold?
                                currency: [
                                         "bitcoin",
                                          "monero",
                                          "iota",
                                          "eos",
                                           "bitcoin-gold"
                              and the
                                sparklineIds: {
                                  bitcoin: 1,
                                  ethereum: 1027,
                                  ripple: 52,
                                  litecoin: 2,
                                  'ethereum-classic': 1321,
                                  nem: 873,
                                  stratis: 1343,
                                  iota: 1720,
                                  monero: 328,
                                  eos: 1765,
                                  'bitcoin-cash': 1831,
                                  'bitcoin-gold': 2083
                              But is does not appear on my Magic mirror :/
                              M C 2 Replies Last reply Reply Quote 0
                                matteodanelli @fox
                                @fox Because in the ranking is too low. You should change limit from 100 to at least 1000 in getTicker function to get it working.
                                • C Offline
                                  canadrian @fox
                                  @canadrian
                                  Yes, you have to update your portfolio (holdings) and coinfolium url changes.
                                  • foxF Offline
                                    fox @matteodanelli
                                    @matteodanelli thank you. That did it for me
                                    @canadrian
                                    Some of us have still problems with iFrame reloaded :)
                                    https://forum.magicmirror.builders/topic/4607/show-webpage-iframe-and-reload
                                    • foxF Offline
                                      fox
                                      @crypto Friends :-)
                                      possible to use the daily chart instead of the 7days?
                                        Baxer
                                        Is Bitcoin Cash available?
                                        M 1 Reply Last reply Reply Quote -1
                                          matteodanelli @Baxer
                                          @Baxer Yes!
                                          Just add bitcoin-cash to your config file.
                                          foxF 1 Reply Last reply Reply Quote 0
                                          • foxF Offline
                                            fox @matteodanelli
                                            @matteodanelli danke dir nochmal.
                                            Wie kann ich
                                            • die Schriftart (in gelb) und
                                            • Den Abstand (rot)
                                            ändern?
                                            Bild Text
                                            • 3 / 4
