    MMM-Globe
    118 Posts 32 Posters 189.2k Views 37 Watching
    • F Offline
      Foxy25 @ashishtank
      It works perfect!!!
      Thank you so much for you support!!!
      Greetings from Germany
      Foxy
        ashishtank Module Developer @Foxy25
        @foxy25 you are welcome :)
          damith
          hi everyone, I’ve tried to install on my PI but it won’t work…am getting black screen, here is my config file… any HELP…?
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "Italy Holidays",
          					symbol: "calendar-check",
          					url: "webcal://www.calendarlabs.com/ical-calendar/ics/53/Italy_Holidays.ics"					}
          		module: "compliments",
          		position: "top_center"
          		module: "weather",
          			type: "current",
          			locationID: "3169070", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			apiKey: "492da6299f48937482d3c321215289b0"
          		module: "weather",
          		header: "Weather Forecast",
          			type: "forecast",
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "REPUBBLICA",
          					url: "https://www.repubblica.it/rss/homepage/rss2.0.xml"
          			showSourceTitle: true,
          			showPublishDate: true,
          			broadcastNewsFeeds: true,
          			broadcastNewsUpdates: true
          	module: 'MMM-Globe',
          	position: 'lower_third',	// This can be any of the regions. Best results in lower_third
                      size:"x-small", // Globe size. See configuration options below for more options
          			dayLength: 38, // (Optional) Rotation speed. See configuration options below
          		    viewAngle: 15, // (Optional) Globe tilt. See configuration options below.
          			introLinesDuration: 2000,
          			receiveExternalLocations: 0,
                      locations: [
                          // Fill with location Objects if desired
                          // e.g.
                             {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                             {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                          // Individual values must be seperated by a comma.
                          // You can look up the latitude and longitude for a specific location on Google Maps.
          if (typeof module !== “undefined”) {module.exports = config;}
          thgmirrorT 1 Reply Last reply Reply Quote 0
          • thgmirrorT Offline
            thgmirror @damith
            Hi @damith,
            May be, you have an issue in the config.js.
            You can use the built-in check-tool from within the MagicMirror folder named
            npm run config:check
            Or use an external Website (I use https://esprima.org/demo/validate.html) to see if it is valed.
            Thomas
              damith
              hi@thgmirror
              Thank you very much for you reply, I’ve checked with built in check but no errors …!!
              pi@raspberrypi:~/MagicMirror $ npm run config:check
              magicmirror@2.15.0 config:check /home/pi/MagicMirror
              node js/check_config.js
              [02.05.2021 12:20.01.503] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
              [02.05.2021 12:20.01.719] [INFO] Your configuration file doesn’t contain syntax errors :)
                sdetweil @damith
                @damith did u do the npm install in the module folder after git clone?
                if u look at the startup messages, where u start mm
                npm start
                or pm2 logs --lines=100
                you might see a message, module not found.
                this is the number 1 clue you didn’t do the npm install
                  damith @sdetweil
                  hi @sdetweil
                  Thank you very much for your reply… you are the NUMBER ONE… it works fine… Thanks again.
                  i have done NPM INSTALL… its worked fine…:face_savoring_food: :face_savoring_food:
                    damith
                    hi guys… my GLOBE is woking fine… but there is a problem with City NAMES, i won’t display…, config is ok… can anyone help me …?
                    module: ‘MMM-Globe’,
                    position: ‘lower_third’, // This can be any of the regions. Best results in lower_third
                    size:“x-large”, // Globe size. See configuration options below for more options
                    locations: [
                    // e.g.
                    {lat:37.77493,lng:-122.41942, label:“San Francisco”},
                    {lat:7.58403,lng:80.78798, label:“Sri Lanka”},
                    {lat:-23.5475,lng:-46.63611, label:“Sao Paulo”}
                    • F Offline
                      Foxy25
                      HI
                      here is my working config:
                      Greetings Torsten
                      		position: 'fullscreen_below',	// This can be any of the regions. Best results in lower_third
                                      size:"medium", // Globe size. See configuration options below for more options
                                      dayLength: 43, // (Optional) Rotation speed. See configuration options below
                                      locations: [
                                          // e.g.
                                          // {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                                          // {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                                          {lat:49.6294791,lng:7.8252699, label: "Rockenhausen" },
                                          {lat:40.7223507,lng:-73.9901943, label: "New York" },
                                          {lat:36.1047739,lng:-115.1421297, label: "Las Vegas" },
                                          {lat:13.7544142,lng:100.5020575, label: "Bangkok" },
                      • H Offline
                        hiro.nguyen
                        Hi, may i ask if it is possible to change background to transparent ?
                        Thanks,
                        G S 2 Replies Last reply Reply Quote 0
                        • G Offline
                          greedyvegan @hiro.nguyen
                          in the beginning of this post from 2021, it was recommended NOT to use this with a raspberry pi
                          today, in 2024, I have a raspberry pi 5, does that matter? lol
                          anyway, the left is on my pi 5 and the right is viewing it on a browser on my computer
                          is there an update on a lite version?
                            sdetweil @hiro.nguyen
                            @hiro-nguyen sure, css
                            google search css transparent background
                              sdetweil @greedyvegan
                              @greedyvegan you will need to enable the gpu in the system boot.txt
                              AND
                              tell MagicMirror electron to use it
                              export ELECTRON_ENABLE_GPU=1
                              in the script before
                              npm  start
                              if you used my script to install MagicMirror , that is ~/MagicMirror/installers/mm.sh
                              • G Offline
                                greedyvegan @sdetweil
                                like this?
                                I got this error
                                [PM2][ERROR] File ecosystem.config.js not found
                                  @greedyvegan that pm2 error is usually caused by using sudo sometime when you shouldn’t
                                  what happened before that? is that the first time w pm2
                                  maybe
                                  pm2 status
                                  pm2 delete xxx
                                  where xxx is the name or number on the MagicMirror line
                                  then run my fixuppm2 script
                                  pm2 seems fragile recently. not sure why
                                  • G Offline
                                    i accidently ran pm2 start instead of pm2 start mm
                                    then it returned
                                    then i ran pm2 start mm
                                    then it returned
                                    [PM2][ERROR] Script not found: /home/thecastle/MagicMirror/mm
                                    status
                                    after pm2 delete 0
                                    after pm2 save
                                    update -
                                    it’s currently running (it was always running, it just had a weird error)
                                    and told me to copy/paste
                                    sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                                      @greedyvegan yep, that’s why you run my script. lots of things to do
                                      • G Offline
                                        thank you very much!
                                        • 6
                                        • 6 / 6
