    MMM-MyCommute
    286 Posts 80 Posters 709.5k Views 77 Watching
      beck0r
      Hey there,
      very nice looking module! I only have a very little issue with my train icon.
      When the MM loads for the first time I can see the train icon but only as long as the driving time is being retrieved from google, then it disappears…
      Before
      0_1495808995559_upload-478cdab7-c23e-423b-8599-00022c06b7ed
      After
      0_1495809045044_upload-5ca0c570-9c7e-48d2-ac3f-47ed05620364
      I have already switched the order of the destinations to check that out, but it only concentrates on the train icon.
      Can you support me on that?
      Thank you Kind Regards
        j.e.f.f Project Sponsor Module Developer @beck0r
        @beck0r Sure. Can you provide your config? Hide your API key, of course.
          beck0r @j.e.f.f
          @j.e.f.f
          Of course… here it comes
            				module: 'MMM-MyCommute',
            				position: 'top_left',
              					showHeader: true,
              					headerText: 'Verkehr',
             					apikey: '...',
              					origin: '...',
              					startTime: '05:00',
              					endTime: '17:00',
              					destinations: [
                  						destination: '...',
                 	 						label: 'Auto zur Arbeit',
                  						mode: 'driving',
                  						color: '#82E5AA'
                  						destination: '...',
                  						label: 'Fahrrad zur Arbeit',
                  						mode: 'bicycling',
          							color: '#FFB444'
                  						destination: '...',
                  						label: 'RMV zur Arbeit',
                  						mode: 'transit'
            @beck0r Can you try doing a git pull in your MMM-MyCommute directory and restarting your mirror? I think I found your issue – I didn’t have an icon definition for High-speed rail.
            EDIT Maybe not… I need to add definitions for all sorts of possible transit vehicle types. Stay tuned…
            EDIT OK fixed for real this time. I added definitions for all of the transit modes listed here: https://developers.google.com/maps/documentation/directions/intro#VehicleType
            Note: You’ll see the tram icon while the route is loading, as that is the default icon used when no transitMode is specified. But you’ll see it change to the train icon after your travel times are retrieved.
              BlackTalon @j.e.f.f
              @j.e.f.f This is perfect! Thank you so much!
                beck0r
                once again for everybody with the same issue. It’s working now! Thumbs up for j.e.f.f, thank you!
                • joela85J Offline
                  joela85
                  One more question. I want to make a route going via different roads, can that be done in this config file?
                  For example:
                  Destination: X
                  Via: A1
                  Destination: X
                  Via: A2
                  J 3 Replies Last reply Reply Quote -1
                    j.e.f.f Project Sponsor Module Developer @joela85
                    @joela85 so the google API doesn’t allow that specifically, but there are a couple of ways we could accomplish something similar:
                    1. I can have Google return alternative routes, and they can be listed out. No garantee you’re going to get any of the routes you’re interested, but they will be the fastest.
                    2. you can provide a list of waypoints and Google will return your route passing through those specific places. So if you put specific landmark addresses that are on the highways you’re interested in then you would more or less get the result you’re looking for.
                    Both of these options seem fairly straightforward to add so I might just do both :)
                      @joela85 I added the first of the above two options. You can specify alternatives:true for any of your destinations to get alternative routes. showSummary must be set to true for this to work.
                      Will be working on the second option soon.
                        @joela85 I’ve added the second option too. You can now specify a waypoints parameter for any of the destinations to influence the route Google will find.
                        T 1 Reply Last reply Reply Quote 1
                        • T Offline
                          tidus5 @j.e.f.f
                          @j.e.f.f Hey Jeff
                          can you add the time for the next metro/tram/bus ?
                          is it possible to catch the adress in the agenda ? and if its blank just used the definited adress in destination ? :-)
                          J 2 Replies Last reply Reply Quote 0
                            j.e.f.f Project Sponsor Module Developer @tidus5
                            @tidus5 I’ll have to see what the API gives me. Not sure that info is available.
                            I wrote a transit-specific module that does that but it is for TTC (Toronto transit). However it is based in the NextBus API which supports many systems. It could easily be modified to work with a number of transit systems. Which is yours?
                              @tidus5 I’ve added a param showNextVehicleDeparture that you can specify for destinations with mode:'transit'. This will show you the next available vehicle factoring your walking time to the stop. It will only show the departure time for the first vehicle on your route to save summary space (and really once you’ve departed, you’ll either make your connections on time or you won’t. So the departure time is kind of moot.) My thinking is that you’ll want to know of you have enough to walk to the stop to catch the next vehicle.
                              There is a limit of 2500 requests per day to the Google API using the free service. Since each entry in your destinations list requires its own request, I’ve kept the poll frequency to a conservative 10 minute interval to avoid hitting this limit. As such, it is possible that you’ll see a next vehicle time that is unrealistic to walk to in time, or in some cases, the next vehicle time will be in the past. Keep it in mind that the next vehicle time may be a bit stale.
                              The time is shown as follows (see the last entry labelled “Airport”):
                              T J 2 Replies Last reply Reply Quote 0
                              • T Offline
                                tidus5 @j.e.f.f
                                @j.e.f.f Perfect!!!
                                  jon11a @j.e.f.f
                                  Hi @j.e.f.f
                                  Just wanted to say, thanks so much for spending your time building this module! I have just finished my MagicMirror build and this module is by far the best and most used. I love how much I’m able to customise it to thanks to your hard work.
                                  Now, I wondered if it was easy to add the following… My commute is always over an hour, would it be possible to format the commute time to show 1h 30 min rather than 90 min for example? It would still show just ‘min’ if under an hour (20 min for example).
                                  If it’s not all that easy and you’d rather not alter the code, then that’s fine, I may have a bash at editing the code on my Pi myself.
                                  Thanks again!
                                    j.e.f.f Project Sponsor Module Developer @jon11a
                                    @jon11a It’s certainly possible. But it takes up considerably more space to render “1h 30 min” than it does to render “90 min”. The space that the travel time uses takes away from the space used for the text to its left. That is why I chose to render it that way. Even an extremely long commute of over 2 hours would only take up an extra 8 pixels or so. By doing it this way, it should be more or less the same width for everyone, with less chance of truncating the label.
                                    If you want to change this yourself, it’s a fairly trivial change to the formatTime function in MMM-MyCommute.js. Google returns the travel time in the number of seconds. I’ve just done a simple division by 60 to get the number of minutes. You can just do a little more math and re-jig the formatting as you’d like.
                                    Happy to hear that you like the module!
                                    -Jeff
                                      jon11a @j.e.f.f
                                      @j.e.f.f Thanks for your quick response Jeff. I thought that might be the reason behind your decision to just use mins. It does make sense to me.
                                      I think I will have a go at changing mine, will be a good little challenge for me as I’m learning more and more programming skills!
                                      Thanks again and I look forward to see what you come up with next ;)
                                        @jon11a Fair warning: this module was also the result of me wanting to change a thing or two to suit my own needs ;). Before I knew I had something completely new! It shares little resemblance with the module I originally forked from mrx-work-traffic.
                                        Have fun. I can’t wait to see how it evolves!
                                        -Jeff
                                          jon11a @j.e.f.f
                                          @j.e.f.f
                                          Managed to do it and pretty pleased with myself :)
                                          Here’s what it looks like:
                                          I had to edit the css file to move the destination-label slightly as you mentioned:
                                          margin-right: 70px;
                                          I edited your formatTime function to format the time in hours and minutes or just minutes if it’s less than an hour in total.
                                          Below is the code for that function with my bits added, I am sure it could be better but I think I did ok!
                                          formatTime: function(time, timeInTraffic) {
                                              var timeEl = document.createElement("span");
                                              timeEl.classList.add("travel-time");
                                              if (timeInTraffic != null) {
                                                var minutes = Math.floor(Number(timeInTraffic) /60);
                                                var h = Math.floor(minutes /60);
                                                var m = Math.floor(minutes %60);
                                                if (h == 0) {
                                                  timeEl.innerHTML = m + " min";
                                                } else {
                                                  timeEl.innerHTML = h + "h " + m + " min";
                                                var variance = timeInTraffic / time;
                                                if (this.config.colorCodeTravelTime) {
                                                  if (variance > this.config.poorTimeThreshold) {
                                                    timeEl.classList.add("status-poor");
                                                  } else if (variance > this.config.moderateTimeThreshold) {
                                                    timeEl.classList.add("status-moderate");
                                                  } else {
                                                    timeEl.classList.add("status-good");
                                              } else {
                                                var minutes = Math.floor(Number(time) /60);
                                                if (h == 0) {
                                                } else {
                                          Thanks for your help Jeff, learned some more programming skills too so I’m happy! :)
                                          • joela85J Offline
                                            joela85
                                            startTime & endTime query.
                                            I’ve tried setting these times up for the morning time before going to work and after testing it hides itself but it never re-appeared this morning?
                                            Has anyone else had this issue?
                                              position: 'bottom_right',
                                                showHeader: true,
                                                headerText: 'Traffic',
                                                apikey: 'API_KEY_FROM_GOOGLE',
                                                origin: 'My Address',
                                                startTime: '06:00',
                                                endTime: '09:00',
                                                destinations: [
                                                               etc...
                                            It would also be good if you could set it to run on Mon-Fri as well.
                                            If not possible I could use the MMM-Scheduler to do this instead, it’s just a bit tidier in this module.
                                            • 14
                                            • 15
                                            • 2 / 15
