    MMM-MyCalendar
    109 Posts 40 Posters 152.1k Views 38 Watching
    • F Offline
      fabbr
      alt text
      I can’t find out why the left panel is stretched so much. when I turn this module off it goes back to normal. Any ideas?
      Here’s my code:
      		module: "MMM-MyCalendar",
      		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
      				colored: true,
      				maxTitleLength: 10,
      				maximumEntries: 5,
      				fade: true,
      						url: 'webcal://mycalendar',
      						symbol: 'calendar',
      						color: "#6666ff"
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
      						color: "#ffffcc"
      • N Offline
        ninjabreadman @fabbr
        @fabbr There is nothing (iirc) that really constrains the MM regions … they expand to fit their content. Moreover, I think some modules aren’t written with a landscape orientation in mind. I suggest you try the following in your custom.css:
        .module.MMM-MyCalendar {
        min-width: 200px; /* adjust number as necessary */
        Alternatively, you can try instead using:
        .region.top.left {
        max-width: 30%;
        Problem with config or JavaScript? Copy/paste it into JSHint.
        Check out the detailed walkthroughs on install, config, modules, etc.
        • F Offline
          fabbr @ninjabreadman
          @ninjabreadman Thank, that didn’t work however, I found the file MMM-MyCalendar.css and there I changed this and got my problem solved, thank you !!!
          .MMM-MyCalendar {
            max-width: 250px;  //original was 500
            j.e.f.f Project Sponsor Module Developer @fabbr
            @fabbr you’re better off putting this change in custom.css. If you update the module down the road, the change you made will be overwritten.
            A better solution here is to revert your change and set a width for the container, like as follows:
            region.left,
            region.left .module-content {
              width: 250px;
              max-width: 250px;
              min-width: 250px;
            This will size the entire left column to 250px, including anything you put in top_left, bottom_left, etc. If you want to limit it to just top_left replace region.left with region.top.left.
            F 1 Reply Last reply Reply Quote 2
            • F Offline
              fabbr @j.e.f.f
              @j.e.f.f I agree with you, however for some reason I can’t make that work. Did those changes worked on your custom.css? if yes, would you mind sharing your code with me? I might be doing something wrong.
                @fabbr Try also setting a maximum width for MMM-MyCalendar in your custom.css file as well. Here is exactly what I have in my custom.css file:
                .region.left,
                .region.left .module-content {
                  width: 555px;
                  max-width: 555px;
                  min-width: 555px;
                .MMM-MyCalendar {
                  max-width: 555px;
                Adjust 555px to whatever you like.
                • F Offline
                  fabbr @j.e.f.f
                  @j.e.f.f Very strange mine is completely ignoring the CSS. No change is made on the screen. Here’s my CSS:
                   body {
                    		 .region.left,
                   			  width: 555px;
                  			  max-width: 555px;
                  			  min-width: 555px;
                  		.MMM-MyCalendar {
                  			  max-width: 555px;
                  N F 2 Replies Last reply Reply Quote 0
                  • N Offline
                    @fabbr You can’t nest the braces in CSS. Just take out the body { and last } entirely.
                    • F Offline
                      fabbr @fabbr
                      @fabbr LoL
                      Body {
                      Was there, no I was under the impression all the changed were going to be inside the brackets. Sorry it was always my fault. Thank you so much for the help. It now works perfectly!
                        Mike7400
                        Is it possible to change the color of title and date for each calendar?
                        • H Offline
                          himanshulotia
                          Just newbie over here. I have used MMM-Mycalendar module to show two different calendar on two separate area of the mirror (bottom_left & bottom_right)
                          I want heading on each calendar to have different color and if possible icon as well.
                          Is this possible?
                          • twosquirrelsT Offline
                            twosquirrels
                            This module just won’t display a 2-column layout for me despite it being enabled in the config:
                                    header: "Family Calendar",
                            colored: true,
                            maximumEntries: 6,
                            columns: true,
                            showLocation: false,
                            maxTitleLength: 200,
                            fetchInterval: 120000,
                            fade: false,
                            • N Offline
                              ninjabreadman @twosquirrels
                              @twosquirrels Does MMM-MyCalendar support a column layout? I can’t find any reference to a columns property for its config: https://github.com/jclarke0000/MMM-MyCalendar/blob/master/README.md
                              twosquirrelsT 1 Reply Last reply Reply Quote 0
                                twosquirrels @ninjabreadman
                                @ninjabreadman Page 1 contains an update where it mentions support for 2 columns:
                                https://forum.magicmirror.builders/topic/2559/mmm-mycalendar?page=1
                                alt text
                                • N Offline
                                  ninjabreadman @himanshulotia
                                  @himanshulotia Yes.
                                  First, you can set colored: true in the config, then add color: "#d9b4b2” and color: "#a0cfe2" per the docs.
                                  Second, have a look at the FontAwesome 4 docs. You could likely insert them into your headings. For how to insert images, you could probably use CSS if you can find the right selectors.
                                  • N Offline
                                    @twosquirrels It looks like you need to use the using_nunjucks branch. The default branch is still (it seems to me, on my phone) 1.0 – it doesn’t contain an .njk template file.
                                      @ninjabreadman
                                      Ahh, I see. Silly question - how do I pull from that branch instead of from the master? I googled the differences but it’s not making sense to me.
                                      AHH! I figured it out:
                                      pi@magicmirror:~/MagicMirror/modules $ git clone -b using_nunjucks https://github.com/jclarke0000/MMM-MyCalendar.git
                                      Cloning into 'MMM-MyCalendar'...
                                      remote: Counting objects: 84, done.
                                      remote: Total 84 (delta 0), reused 0 (delta 0), pack-reused 84
                                      Unpacking objects: 100% (84/84), done.
                                      @ninjabreadman thank you for pointing this out!
                                        smreid
                                        Hi
                                        Just wondering if there is anyway I can use custom symbols for calendar entries in place of the ‘day of the month’ logos? Similar to the default calendar module?
                                        Stephen
                                        • C Offline
                                          cola0927
                                          Hi, it’s really a nice module, but got a small issue here. I’m wondering how to make the event contents left-aligned. I tried to modify some parameters in MMM-MyCalendar.css, but didn’t work.
                                          Thanks!
                                          justjim1220J 1 Reply Last reply Reply Quote 0
                                          • justjim1220J Offline
                                            justjim1220 Module Developer @cola0927
                                            @cola0927
                                            change the text-align under title in the css
                                            .MMM-MyCalendar .title {
                                              color: #ff0;
                                              font-size: 55px;
                                              line-height: 115%;
                                              font-weight: 600;
                                              text-align: left;
                                              padding-left: 0;
                                              margin-bottom: 2px;
                                              white-space: nowrap;
                                              text-overflow: ellipsis;
                                              border-radius: 15px;
                                              overflow: hidden;
                                              display: block;
                                              margin-top: 4px;
                                            Jim Hallock - 1995
                                            • 6
                                            • 4 / 6
